This application note discusses the Serial Peripheral Interface (SPI) configuration mode introduced in the Virtex®-5 and Spartan®-3E FPGA families. The ISE® Design Suite with iMPACT in-system programming solution with Xilinx cables for prototype designs is also described.
xapp951.pdf
共1条
Configuring Xilinx FPGAs with SPI Serial Flash
关键词: Configuring Xilinx FPGAs
共1条
| OrangePiZero2W系统被打赏¥33元 | |
