【应用手册】AN 589: Using the Design Security Feature in Cyclone III LS Devices
This application note describes the design security feature in Cyclone® III LS devices.
The design security feature is able to decrypt a configuration bitstream using an
industry standard 256-bit advanced encryption standard (AES) key and AES
encryption algorithm to protect your designs from the following unauthorized
activities:
■ Copying
■ Reverse engineering
■ Tampering
The following design features make the solution secure:
■ Cyclone III LS devices do not support configuration file read back. This prevents
attempts to read back the configuration file after it is decrypted.
■ Two user-defined 256-bit sequences are required to generate the 256-bit AES key.
■ The volatile 256-bit AES key is stored in the Cyclone III LS device and cleared
when the external battery is removed.
■ Depending on the security mode, you can configure the Cyclone III LS device
using a configuration file that is encrypted with the same key, or configure with a
normal configuration file for board level testing.
AN589.pdf
共1条
共1条
| 【FreeRtos】FreeRtos + MPU模块的配置使用被打赏¥32元 | |
| 【分享开发笔记,赚取电动螺丝刀】墨水屏文本显示器被打赏¥25元 | |
| 【STEVAL-STWINKT1B】:结合STMcubeMX软件读取HTS221温湿度被打赏¥22元 | |
| M5PAPERESP32EINKDEVKIT评测|使用MicroPython开发M5Paper被打赏¥15元 | |
| OK1126B-S开发板下以导航按键控制云台/机械臂姿态调整被打赏¥29元 | |
| 【树莓派5】便携热成像仪被打赏¥36元 | |
| 【树莓派5】环境监测仪被打赏¥35元 | |
| OK1126B-S开发板下多时段语音提示型电子时钟被打赏¥27元 | |
| OK1126B-S开发板下函数构建及步进电机驱动控制被打赏¥25元 | |
| 【S32K3XX】LPI2C 参数配置说明被打赏¥20元 | |
