This application note describes the transformation of multiple synchronous serial data streams to parallel data through a multi-channel serial-to-parallel converter. This document is obsolete/under obsolescence.
xapp194.pdf
共1条
Serial-to-Parallel Converter - Obsolete
关键词: Serial-to-Parallel Conver
共1条
