【应用手册】AN 542: High Definition (HD) Video Monitoring Reference Design (M5)
The Altera® High Definition (HD) Video Monitoring Reference Designs demonstrate the
application of Altera tools and devices to broadcast and video surveillance applications.
The reference designs provide a working template that can be used to rapidly build further
broadcast applications using a flexible, re-usable and parameterizable video framework. All
hardware functions in the reference designs use standard, open interfaces and protocols to
facilitate function re-use and system design.
Specifically, the designs use the Altera Video and Image Processing Suite MegaCore®
functions library, the SDI MegaCore® function, the DDR2 High Performance Memory
Controller MegaCore® function, and supporting development tools.an542.pdf
共1条
共1条
| OrangePiZero2W系统被打赏¥33元 | |
