【应用笔记】DDR和DDR2 SDRAM纠错码参考设计(DDR and DDR2 SDRAM ECC Reference Design)
本应用笔记描述了一种使用AlteraDDR和DDR2 SDRAM控制器MegaCore功能函数实现的纠错码(error-correcting code,ECC)模块。
This application note describes an error-correcting code (ECC) block for
use with the Altera DDR and DDR2 SDRAM controller MegaCore
functions. Altera also supplies an ECC reference design, which uses the
ECC block with the DDR2 SDRAM controller MegaCore function and a
Micron MT9HTF3272AY-53EB3 DIMM at 200 MHz. The reference design
runs on a Stratix® II High-Speed Development Board.an415.pdf
共1条
共1条
