【应用笔记】仿真Nios II嵌入式处理器设计(Simulating Nios II Embedded Processor Designs)
本应用笔记描述了使用Nios II设计示例、Qsys和Nios II的Eclipse软件生成工具(Nios II Software Build
Tools (SBT) for Eclipse)生成RTL仿真环境的过程。
This application note describes the process of generating an RTL simulation
environment with Nios? II example designs, Qsys, and the Nios II Software Build
Tools (SBT) for Eclipse. This application note also describes the process of running the
Nios II RTL simulation in the ModelSim?-Altera? Edition simulator.an351.pdf
共1条
共1条
| OrangePiZero2W系统被打赏¥33元 | |
