Error band is usually defined to be a percentage of the
step 0.1%, 0.05%, 0.01%, etc.
Settling time is non-linear; it may take 30 times as
long to settle to 0.01% as to 0.1%.
OUTPUT
ERROR
BAND
FINAL
SETTLING
RECOVERY
TIME
SLEW
TIME
DEAD
TIME
SETTLING TIME
建立时间
放大器的建立时间是指输出响应输入的阶跃变化,然后进入并保持在规定误差带所需的时
间,参照输入脉冲50%点测得,如下图1所示。
MT-046:运算放大器建立时间.pdf
