【应用笔记】AN341:在Stratix II和Stratix II GX器件中使用设计安全特性(AN 341: Using the Design Security Feature in Stratix II and Stratix II GX Devices)
在充满高度竞争的商业和军事环境中,设计安全对数字设计者来说是一个重要的考量。
In the highly competitive commercial and military environments, design security is
an important consideration for digital designers. As FPGAs start to play a role in
larger and more critical system components, it is imperative to protect designs from
copying, reverse engineering, and tampering. Stratix® II devices are the first FPGAs in
the industry to address thse concerns with the ability to decrypt a configuration
bitstream using the advanced encryption standard (AES) algorithm, an industry
standard encryption algorithm.an341.pdf
共1条
共1条
