【应用笔记】在Stratix和Stratix GX设计中,从异步存储器转到同步存储器(Converting Memory from Asynchronous to Synchronous for Stratix & Stratix GX Designs)
在Stratix和Stratix GX器件系列中提供了被称作TriMatrix存储器的独一无二的存储器结构。
The StratixTM and Stratix GX device families provide a unique memory
architecture called TriMatrixTM memory, consisting of dedicated memory
blocks of three sizes. These blocks provide flexible and effective solutions
for various memory applications. Table 1 lists the TriMatrix memory
block types and their total memory bits.an210.pdf
共1条
共1条
