关键词: Initial, accuracy, digital, pots, potentiometer, end-to-end, tolerance, resistance, voltage, dividers, ratiometric, ratio, steps, LSB, taps, error, temperature, coefficient, series, resistor, noise, change, reference, buffer, amplifier, NPN, PNP, low, pass
摘要:本应用笔记介绍了三个设计,使用与数字电位器调整电压的参考。由于设计的复杂性和引用的数量增加,电压可以调整,甚至更高。数字电位器MAX5436系列作为示例设备。
