This application note targets Spartan™-3E devices in applications that require 4-bit or 5-bit transmit data bus widths and operate at rates up to 666 Mbps per line with a forwarded clock at 1/7th the bit rate. This type of interface is commonly used in flat panel displays and automotive applications.
xapp486.pdf
共1条
在Spartan3E/ 3 fpga7:1序列化中速度高达666 Mbps
关键词: Spartan3E fpga7 序列化 速度 高达
共1条
