我现在在做LM4F232的开发板的熟悉工作,我将LM3S的Uart初始化直接拷贝到LM4F上,因为都是调用的Stellaris库,可以直接使用,但是就是通讯失败。使用jtag调试发现根本就无法进入到串口中断中……
初始化源代码如下
void Uart0Init(unsigned long band)
SysCtlPeripheralEnable(SYSCTL_PERIPH_UART0); /* enable the peripherals used by this example */
SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOA);
GPIOPinTypeUART(U0RX_PORT, U0RX_PIN | U0TX_PIN);
UARTConfigSetExpClk(UART0_BASE, SysCtlClockGet(), band, /* config the uart0 for 115,200 8-N-1 */
(UART_CONFIG_WLEN_8 | UART_CONFIG_STOP_ONE | UART_CONFIG_PAR_NONE));
IntEnable(INT_UART0); /* enable the UART interrupt, including receive interrupt and receive timeout interrupt */
UARTIntEnable(UART0_BASE, UART_INT_RX | UART_INT_RT);
UARTFIFOLevelSet(UART0_BASE, UART_FIFO_TX4_8, UART_FIFO_TX4_8); /* config uart0 for half of the fifo buffer using fifo */
UARTFIFOEnable(UART0_BASE);
UARTEnable(UART0_BASE);
我在LM4F中只是使用了Uart5,直接将基地址换成了uart5。
5555……
