电子产品世界 » 论坛首页 » DIY与开源设计 » 电子DIY » FPGA DIY 的管教配置书写!!!
FPGA DIY 的管教配置书写!!!
2012-09-08 19:40:57     打赏
当时实验是就是这样的格式的书写的,没啥问题,宫大家参考一下!
set_global_assignment -name RESERVE_ALL_UNUSED_PINS "AS INPUT TRI-STATED"
set_location_assignment PIN_17 -to clk
set_location_assignment PIN_26 -to rst
set_location_assignment PIN_50 -to seg[0]
set_location_assignment PIN_40 -to seg[1]
set_location_assignment PIN_42 -to seg[2]
set_location_assignment PIN_47 -to seg[3]
set_location_assignment PIN_49 -to seg[4]
set_location_assignment PIN_41 -to seg[5]
set_location_assignment PIN_39 -to seg[6]
set_location_assignment PIN_38 -to en
set_location_assignment PIN_37 -to shi
set_location_assignment PIN_36 -to bai
set_location_assignment PIN_35 -to qian
关键词: 管教     配置     书写     assignment     locat
2012-09-09 15:33:04     打赏
不是不可以配置,二十写成配置文件的话以后再建立新的工程的话就不用那么麻烦了
