电子产品世界 » 论坛首页 » 嵌入式开发 » MCU » LM3S811学习笔记(步进电机)
共8条 1/1 1 跳转至页
LM3S811学习笔记(步进电机)
2012-11-11 10:43:17     打赏
实验内容:上电后,按下启动按键,步进电机开始运转
实验目的:掌握简单的步进电机的控制,熟悉其工作原理
不足之处:电机步进无法调速
下一步优化:使用PWM对电机进行控制
#include "Type.h"
#include "inc\hw_ints.h"
#include "inc\hw_memmap.h"
#include "inc\hw_types.h"
#include "driverlib\sysctl.h"
#include "driverlib\gpio.h"
#define  KEY               GPIO_PIN_4
#define  PHRA1             GPIO_PIN_0
#define  PHRA2             GPIO_PIN_1
#define  PHRB1             GPIO_PIN_2
#define  PHRB2             GPIO_PIN_3
#define  PHLA1             GPIO_PIN_4
#define  PHLA2             GPIO_PIN_5
#define  PHLB1             GPIO_PIN_6
#define  PHLB2             GPIO_PIN_7
/* jtag protect key */
#define PROTECT_KEY_PERIPH SYSCTL_PERIPH_GPIOC
#define PROTECT_KEY_PORT   GPIO_PORTC_BASE
#define PROTECT_KEY_PIN    GPIO_PIN_4
struct motor  //电机的状态和方向
    int8    cState;
    int8    cDir;
typedef struct motor MOTOR;
static int8 cStep=0;
void delay (uint32  uiD) //延时函数
    for (; uiD; uiD--);
void rightMotor(void)  //右电机时序
    switch (cStep) {
    case 0:                                                             /*  A2B2                        */
        GPIOPinWrite(GPIO_PORTD_BASE,
                     PHRA1 | PHRA2 | PHRB1 | PHRB2,
                     PHRA1 | PHRA2 | PHRB1 | PHRB2);
        break;
    case 1:                                                             /*  A2                          */
                     PHRA1 | PHRA2);
        break;
    case 2:                                                             /*  A2B1                        */
                     PHRA1 | PHRA2 | PHRB2);
        break;
    case 3:                                                             /*  B1                          */
                     PHRB2);
        break;
    case 4:                                                             /*  A1B1                        */
                     PHRA2 | PHRB2);
        break;
    case 5:                                                             /*  A1                          */
                     PHRA2);
        break;
    case 6:                                                             /*  A1B2                        */
        break;
    case 7:                                                             /*  B2                          */
                     PHRB1 | PHRB2);
        break;
    default:
        break;
void leftMotor(void) //左电机时序
    switch (cStep) {
    case 0:                                                             /*  A2B2                        */
                     PHLA1 | PHLA2 | PHLB1 | PHLB2,
                     PHLA1 | PHLA2 | PHLB1 | PHLB2);
        break;
    case 1:                                                             /*  B2                          */
                     PHLB1 | PHLB2);
        break;
    case 2:                                                             /*  A1B2                        */
        break;
    case 3:                                                             /*  A1                          */
                     PHLA2);
        break;
    case 4:                                                             /*  A1B1                        */
                     PHLA2 | PHLB2);
        break;
    case 5:                                                             /*  B1                          */
                     PHLB2);
        break;
    case 6:                                                             /*  A2B1                        */
                     PHLA1 | PHLA2 | PHLB2);
        break;
    case 7:                                                             /*  A2                          */
                     PHLA1 | PHLA2);
        break;
    default:
        break;
uint8 keyCheck (void) //检测按键
    if (GPIOPinRead(GPIO_PORTC_BASE, KEY) == 0) {
        delay(50);
        while(GPIOPinRead(GPIO_PORTC_BASE, KEY) == 0);
        return(true);
    }else {
        return(false);
void StepMotor_Iint (void) //步进电机初始化
    GPIODirModeSet(GPIO_PORTD_BASE,
                   PHRA1 |
                   PHRA2 |
                   PHRB1 |
                   PHRB2 |
                   PHLA1 |
                   PHLA2 |
                   PHLB1 |
                   PHLB2,
                   GPIO_DIR_MODE_OUT);
void keyInit (void)  //按键初始化
    GPIODirModeSet(GPIO_PORTC_BASE, KEY, GPIO_DIR_MODE_IN);
void ProtectJtag(void)  //JTAG保护函数
  SysCtlPeripheralEnable(PROTECT_KEY_PERIPH);
  GPIOPadConfigSet(PROTECT_KEY_PORT, PROTECT_KEY_PIN, GPIO_STRENGTH_2MA, GPIO_PIN_TYPE_STD_WPU);
  GPIODirModeSet(PROTECT_KEY_PORT, PROTECT_KEY_PIN, GPIO_DIR_MODE_IN);
  while(GPIOPinRead(PROTECT_KEY_PORT, PROTECT_KEY_PIN) == 1)
//主函数 循环调用电机的驱动时序,使电机连续步进
main (void)
    ProtectJtag();
    SysCtlClockSet( SYSCTL_SYSDIV_4 | SYSCTL_USE_PLL | SYSCTL_OSC_MAIN |
                    SYSCTL_XTAL_6MHZ );
    SysCtlPeripheralEnable( SYSCTL_PERIPH_GPIOC );
    SysCtlPeripheralEnable( SYSCTL_PERIPH_GPIOD );
    keyInit();
    StepMotor_Iint();
    while(!keyCheck ())
      delay(5000);
    cStep=0;
    while(1)
      rightMotor();
      leftMotor();
    //  delay(1250000);  //0.025s 50Hz
      delay(1250000*1/32);  //781.25us
      cStep = (cStep + 1) % 8;
/*关于延时时间的计算经历了无数的试验,起初未加延时函数,
发现电机能够进行单步调试,
一旦连续运行则电机无反应,且迅速升温,
此时期驱动芯片温度亦立即飙升,
试想可能是其驱动时序变换太快,后随加上一秒钟的延时函数,
发现此时能正常运作,只是动作过于缓慢,
接下来就是调试延时函数的问题了,
几经试验终于找到满意的延时值*/
关键词: LM3S811     学习     笔记     步进     电机     #defi
2012-11-12 20:21:59     打赏
我用的两相四线制步进电机,其步距角是1.8度,考虑到稳定性和功耗的影响,我用的半步驱动,步进焦为0.9度,还可以通过细分驱动来改变其值。
2012-11-12 20:27:35     打赏
劳驾给推荐一款呗,以后还会用到控制步进电机的,我这方面了解的不多,谢谢了
2012-11-12 20:28:34     打赏
加油 亲
2012-11-12 20:31:53     打赏
2012-11-13 09:18:48     打赏
好的,我目前用的步进电机驱动芯片是BA6845FS,多谢指教
2012-12-31 14:02:15     打赏
可以,不过参数要求会比较高
2012-12-31 14:03:27     打赏
我没做过类似的实验,你可以试试,哪有问题大家可以一块讨论不是
共8条 1/1 1 跳转至页
