linux应用程序堆和栈起始地址问题
通过cat /proc/进程号/maps获得堆栈地址。
005e9000-00603000 r-xp 00000000 fd:00 4228679 /lib/ld-2.5.so
00603000-00604000 r--p 00019000 fd:00 4228679 /lib/ld-2.5.so
00604000-00605000 rw-p 0001a000 fd:00 4228679 /lib/ld-2.5.so
00607000-00747000 r-xp 00000000 fd:00 4228694 /lib/i686/nosegneg/libc-2.5.so
00747000-00749000 r--p 00140000 fd:00 4228694 /lib/i686/nosegneg/libc-2.5.so
00749000-0074a000 rw-p 00142000 fd:00 4228694 /lib/i686/nosegneg/libc-2.5.so
0074a000-0074d000 rw-p 0074a000 00:00 0
00949000-0094a000 r-xp 00949000 00:00 0 [vdso]
08048000-08049000 r-xp 00000000 fd:00 2066890 /home/temp/a.out
08049000-0804a000 rw-p 00000000 fd:00 2066890 /home/temp/a.out
b7ef2000-b7ef3000 rw-p b7ef2000 00:00 0
b7f07000-b7f09000 rw-p b7f07000 00:00 0
bf946000-bf95c000 rw-p bf946000 00:00 0 [stack]
要想获得更具体的信息,可以使用readelf -S 可执行文件名,获得数据放在虚拟内存的什么位置,以及是否可读写等。
获得如下信息:
There are 28 section headers, starting at offset 0x998:
Section Headers:
[Nr] Name Type Addr Off Size ES Flg Lk Inf Al
[ 0] NULL 00000000 000000 000000 00 0 0 0
[ 1] .interp PROGBITS 08048114 000114 000013 00 A 0 0 1
[ 2] .note.ABI-tag NOTE 08048128 000128 000020 00 A 0 0 4
[ 3] .gnu.hash GNU_HASH 08048148 000148 000020 04 A 4 0 4
[ 4] .dynsym DYNSYM 08048168 000168 000050 10 A 5 1 4
[ 5] .dynstr STRTAB 080481b8 0001b8 00004c 00 A 0 0 1
[ 6] .gnu.version VERSYM 08048204 000204 00000a 02 A 4 0 2
[ 7] .gnu.version_r VERNEED 08048210 000210 000020 00 A 5 1 4
[ 8] .rel.dyn REL 08048230 000230 000008 08 A 4 0 4
[ 9] .rel.plt REL 08048238 000238 000018 08 A 4 11 4
[10] .init PROGBITS 08048250 000250 000017 00 AX 0 0 4
[11] .plt PROGBITS 08048268 000268 000040 04 AX 0 0 4
[12] .text PROGBITS 080482b0 0002b0 0002c8 00 AX 0 0 16
[13] .fini PROGBITS 08048578 000578 00001c 00 AX 0 0 4
[14] .rodata PROGBITS 08048594 000594 000110 00 A 0 0 4
[15] .eh_frame PROGBITS 080486a4 0006a4 000004 00 A 0 0 4
[16] .ctors PROGBITS 080496a8 0006a8 000008 00 WA 0 0 4
[17] .dtors PROGBITS 080496b0 0006b0 000008 00 WA 0 0 4
[18] .jcr PROGBITS 080496b8 0006b8 000004 00 WA 0 0 4
[19] .dynamic DYNAMIC 080496bc 0006bc 0000c8 08 WA 5 0 4
[20] .got PROGBITS 08049784 000784 000004 04 WA 0 0 4
[21] .got.plt PROGBITS 08049788 000788 000018 04 WA 0 0 4
[22] .data PROGBITS 080497a0 0007a0 000008 00 WA 0 0 4
[23] .bss NOBITS 080497a8 0007a8 000008 00 WA 0 0 4
[24] .comment PROGBITS 00000000 0007a8 000114 00 0 0 1
[25] .shstrtab STRTAB 00000000 0008bc 0000db 00 0 0 1
[26] .symtab SYMTAB 00000000 000df8 000460 10 27 48 4
[27] .strtab STRTAB 00000000 001258 000266 00 0 0 1
Key to Flags:
W (write), A (alloc), X (execute), M (merge), S (strings)
I (info), L (link order), G (group), x (unknown)
O (extra OS processing required) o (OS specific), p (processor specific)
