电子产品世界 » 论坛首页 » 嵌入式开发 » MCU » SD卡与SD卡控制器的关系
共10条 1/1 1 跳转至页
SD卡与SD卡控制器的关系
2012-12-26 16:34:52     打赏
最近看sd协议,想知道SD卡大小为4G,要想arm处理器全部识别SD卡大小,那么是不是与SD控制器协议版本有关系啊??
关键词: 卡与     控制器     关系
2012-12-26 17:06:45     打赏
没人答啊,自己顶个!!
2012-12-26 19:36:58     打赏
难道米有人知道吗???
2012-12-26 21:04:00     打赏
SD卡协议规范看了,SD卡控制器协议规范看了,没找到!!
2012-12-26 21:32:58     打赏
那为啥手机上标注最大支持32G SD卡??
2013-01-18 13:34:18     打赏
官方文档,都是英文的很蛋疼,你要是要,我就发给你~~
2013-03-18 15:41:07     打赏
Only hosts that are compliant to the Physical Layer Specification Version 2.00 or later and the File
System Specification Ve r2.00 or higher can access High Capacity SD Memory Cards and Extended
Capacity SD Memory Cards. Other hosts fail to initialize High Capacity SD Memory Cards and
Extended Capacity SD Memory Cards.
Only hosts that are compliant to  the Physical Layer Specification Version 3.00 or higher and the File
System Specification Ver3.00 or later (exFAT supported) can access Extended Capacity SD Memory.
与sd卡主的协议版本和sd卡的文件系统都有关系,以上是英文资料!!!
High Capacity SD Memory Card (SDHC) : More than 2GB and up to and including 32GB
Extended Capacity SD Memory Card (SDXC): More than 32GB and up to and including 2TB
2013-03-18 20:31:36     打赏
擦,协议上说的!!
你不信,去找个8G SD卡,放在兼容1.1协议上边,能全部寻址吗??
2013-03-18 20:31:57     打赏
擦,协议上说的!!
2013-03-18 20:37:18     打赏
谁不文明了??
共10条 1/1 1 跳转至页
