电子产品世界 » 论坛首页 » 综合技术 » PCB与EMC » 原理图编译警告“XX has no driving source”?
共9条 1/1 1 跳转至页
2013-06-29 19:47:28     打赏
如题,在原理图编译后出现警告“XX has no driving source”?
他是个警告,可以不予理会,但我想知道他出现的原因?还望各位予以指教。
上图:
Class Document Source Message Time Date No.
[Warning] DBRsch.Sch Compiler Net COM_G has no driving source (Pin R35-1,Pin R36-2,Pin U20-1,Pin U20-19) 19:01:16 2013/6/29 1
[Warning] DBRsch.Sch Compiler Net DIN0 has no driving source (Pin C100-1,Pin R68-1,Pin U27-4,Pin UL1-2) 19:01:16 2013/6/29 2
[Warning] DBRsch.Sch Compiler Net DIN1 has no driving source (Pin C101-1,Pin R69-1,Pin U28-4,Pin UL1-4) 19:01:16 2013/6/29 3
[Warning] DBRsch.Sch Compiler Net DIN2 has no driving source (Pin C109-1,Pin R77-1,Pin U30-4,Pin UL1-6) 19:01:16 2013/6/29 4
[Warning] DBRsch.Sch Compiler Net DIN3 has no driving source (Pin C110-1,Pin R78-1,Pin U31-4,Pin UL1-8) 19:01:16 2013/6/29 5
[Warning] DBRsch.Sch Compiler Net DIN4 has no driving source (Pin C120-1,Pin R84-1,Pin U33-4,Pin UL1-11) 19:01:16 2013/6/29 6
[Warning] DBRsch.Sch Compiler Net DIN5 has no driving source (Pin C121-1,Pin R85-1,Pin U34-4,Pin UL1-13) 19:01:16 2013/6/29 7
[Warning] DBRsch.Sch Compiler Net DIN6 has no driving source (Pin C133-1,Pin R94-1,Pin U38-4,Pin UL1-15) 19:01:16 2013/6/29 8
[Warning] DBRsch.Sch Compiler Net DIN7 has no driving source (Pin C134-1,Pin R95-1,Pin U39-4,Pin UL1-17) 19:01:16 2013/6/29 9
[Warning] DBRsch.Sch Compiler Net PE8/DO1 has no driving source (Pin TVS8-1,Pin U12-39,Pin U20-2) 19:01:16 2013/6/29 10
[Warning] DBRsch.Sch Compiler Net PE9/DO2 has no driving source (Pin TVS8-3,Pin U12-40,Pin U20-4) 19:01:16 2013/6/29 11
[Warning] DBRsch.Sch Compiler Net PE10/DO3 has no driving source (Pin TVS8-6,Pin U12-41,Pin U20-6) 19:01:16 2013/6/29 12
[Warning] DBRsch.Sch Compiler Net PE11/DO4 has no driving source (Pin TVS8-4,Pin U12-42,Pin U20-8) 19:01:16 2013/6/29 13
[Warning] DBRsch.Sch Compiler Net PE12/DO5 has no driving source (Pin TVS10-1,Pin U12-43,Pin U20-11) 19:01:16 2013/6/29 14
[Warning] DBRsch.Sch Compiler Net PE13/DO6 has no driving source (Pin TVS10-3,Pin U12-44,Pin U20-13) 19:01:16 2013/6/29 15
[Warning] DBRsch.Sch Compiler Net PE14/DO7 has no driving source (Pin TVS10-6,Pin U12-45,Pin U20-15) 19:01:16 2013/6/29 16
[Warning] DBRsch.Sch Compiler Net PE15/DO8 has no driving source (Pin TVS10-4,Pin U12-46,Pin U20-17) 19:01:16 2013/6/29 17
[Info] dianbanre2013 6 6.PrjPcb Compiler Compile successful, no errors found. 19:01:16 2013/6/29 18
检查了管脚连接都是完好的,并且封装也没有问题,所以对他的出现比较疑惑,还请大侠指点。。。
关键词: 警告     has no driving source
2013-06-30 19:27:52     打赏
再次检查了封装,并且导入到PCB之中,都没有问题,到底是哪的原因呢。。。
2013-06-30 19:53:08     打赏
在protell99中做的芯片封裝引腳如果定義為輸入而原理圖中沒有輸入信號的話就有這種報告出現 一般的解決方法就是在封裝中把它改為無源引腳。
2013-06-30 19:53:56     打赏
这个和制作封装时的管脚的属性的定义(比如,输入,输出,电源等)和原理图的具体连接方式有关.如果一个芯片的某个管脚定义为输入脚,而另一个芯片的一个脚的属性你没定义,把这两个脚连接,就会出现这个警告.没关系的,如果确认没错的话无视于他好了,继续做下去
2013-06-30 19:54:15     打赏
刚出现这样的问题,现在改好了,是这样的,两个互相连在一起的拐脚的性质不一样,比如说一个拐脚是passive,而跟它连在一起的脚为output,那么就出现这样的错误。要把它改为一个是output,另一个为input,那就行了。这种错误在dxp,altium designer里比较好改,直接双击元件,左下角的按钮edit pins里面该type就行了,在99se里可能麻烦点。
2013-06-30 21:54:38     打赏
我直接忽略了,知道是怎么回事就OK了
2013-09-24 21:19:34     打赏
2013-09-24 23:06:57     打赏
正解,多谢赐教啊
2013-09-24 23:19:13     打赏
以前追究过,改太麻烦啦,索性就直接略过,简单实效,嘿嘿嘿
共9条 1/1 1 跳转至页
