电子产品世界 » 论坛首页 » DIY与开源设计 » 电子DIY » LED功能实现
LED功能实现
2013-09-16 23:19:45     打赏
每个开发板的LED就仿佛“Hello World”一样,可以方便快速的了解初步开发流程,在学习了官方的教程后,我也奉上我的LED,哈哈,看~
程序是用VHDL编写的:
--库声明
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
USE IEEE.STD_LOGIC_ARITH.ALL;
USE IEEE.STD_LOGIC_UNSIGNED.ALL;
--实体
ENTITY led_run IS
    PORT(
            SYS_CLK  : IN STD_LOGIC;--时钟输入
            SYS_RSTN : IN STD_LOGIC;--复位输入
            LED_OUT  : OUT STD_LOGIC_VECTOR(3 downto 0)--LED输出
END ENTITY led_run;
--结构体
ARCHITECTURE behav OF led_run IS
--信号声明
signal led_out_i : std_logic_vector(3 downto 0):= (others=>'0');
signal clk_cnt : std_logic_vector(24 downto 0):= (others=>'0');
signal led_cnt : std_logic_vector(2 downto 0) := (others=>'0');
BEGIN
    LED_OUT <= led_out_i;
    --对50MHz时钟计数,并控制led_cnt计数器
    clk_cnt_proc : process(SYS_RSTN,SYS_CLK)
    begin
        if SYS_RSTN = '0' then
            clk_cnt <= (others => '0');
            led_cnt <= (others => '0');
        elsif rising_edge(SYS_CLK) then
            --50MHz下延时0.5s
            if clk_cnt = conv_std_logic_vector(24999999,25) then
                clk_cnt <= conv_std_logic_vector(0,25);
                led_cnt <= led_cnt + '1';
            else
                clk_cnt <= clk_cnt + '1';
                led_cnt <= led_cnt;
            end if;
        end if;
    end process clk_cnt_proc;
    --根据led_cnt的值,输出相应LED状态
    led_flicker_proc : process(SYS_RSTN,SYS_CLK)
    begin
            led_out_i <= "1111";
            case(led_cnt) is
                when "000" => led_out_i <= "0111";
                when "001" => led_out_i <= "1011";
                when "010" => led_out_i <= "1101";
                when "011" => led_out_i <= "1110";
                when "100" => led_out_i <= "1101";
                when "101" => led_out_i <= "1011";
                when "110" => led_out_i <= "0111";
                when "111" => led_out_i <= "1111";
            end case;
        end if;
    end process led_flicker_proc;
END ARCHITECTURE behav;
关键词: 功能     实现
2013-09-17 11:42:55     打赏
学校学的VHDL
