电子产品世界 » 论坛首页 » DIY与开源设计 » 电子DIY » 基于STM32的四轴飞行器DIY可行性讨论
共24条 1/3 1 2 3 › 跳转至页
2013-10-14 21:01:12     打赏
jackwang发的帖子,http://forum.eepw.com.cn/thread/240423/1
这个调查我看了,当时我这样回复的:
空心杯电机2块钱一个×4
桨2块钱一个 × 6(两个备用桨你懂得)
2.4G模块15一个×2
三轴陀螺仪×1 20
加速度计×1 15
空心杯电机电流不大,电池可以用手机电池或者买18650电池。
遥控空板+飞控空板   EEPW打样的话 可以控制到20以内
其他零件:STM32F103C8 10块 + 其他  约需要30块
总价150以内
我计划150块钱之内,使用最简单的东西:空心杯电机加传感器。外带一个主控芯片STM32F1。
希望弟兄们有力的出力有想法的出想法,看看有没有实现这个东西的可能。
关键词: 基于     STM32     四轴     飞行器     可行性     讨论
2013-10-15 06:53:57     打赏
直接飞pcb。
2013-10-15 09:10:58     打赏
比较担心的有两个,一是超重飞不起来,二是算法做不出来
2013-10-15 17:56:45     打赏
还真找到一个,跟我的想法差不多的。三个瑞典人做的。看看人家的特性吧
Crazyflie features
  • Small and lightweight, around 19g and about 90mm motor to motor
  • Flight time up to 7 minutes with standard 170mAh Li-Po battery
  • Standard micro-USB connector for charging which takes ~20min for the stock 170mAh Li-Po battery
  • On-board low-energy radio@1mW based on the nRF24L01+ chip. Up to 80m range (environment dependent) when using the Crazyradio USB dongle
  • Radio bootloader which enabled wireless update of the firmware
  • Powerful 32 bit MCU: STM32F103CB @ 72 MHz (128kb flash, 20kb RAM)
  • 3-axis high-performance MEMs gyros with 3-axis accelerometer: Invensense MPU-6050
  • 3-axis magnetometer HMC5883L (compass)
  • High precision altimeter MS5611-01BA03
  • Expansion header 2×10 pins 1.27mm (0.05”) pitch including power, I2C/UART, SPI/ADC. Header also contains ARM Cortex 10-pin JTAG (header not included)
  • 4-layer low noise PCB design with separate voltage regulators for digital and analog supply
  Crazyradio features
  • 2.4GHz radio communication
  • 0dBm output power (1mW)
  • 125 radio channels
  • 2Mbps, 1Mbps and 250Kps communication data-rate
  • Sends and receives data packets of up to 32 bytes
  • Automatically handles addresses and packet ACK
  • Hardware support for PPM input (no software support yet)
  • Can be powered with up to 16V via header
  • Tested up to ~80m range at 250Kbps
  Kit includes
  • 1 x Crazyflie control board
  • 1 x Crazyradio
  • 1 x Duck antenna 2 dBi
  • 5 x Motor mounts
  • 5 x Coreless DC motors
  • 5 x CW propeller
  • 5 x CCW propeller
  • 1 x LiPo battery
  • 1 x 2*5 pins 1.27mm (0.05”) pitch header.
2013-10-15 17:58:16     打赏
六轴加速度和陀螺传感器,外加一个磁阻传感器:
2013-10-16 21:06:52     打赏
网上找到的使用STM32+MPU6050+空心杯的原理图。
看来我的想法已经被人实现了。。。。
CrazeFlie.rar
2013-10-16 21:07:38     打赏
此原理图还包含了板载电池的充电管理部分。
2013-10-17 12:17:10     打赏
上边那个开源的四轴成品。我前两天在一期航空知识杂志上看到的。
体积很小,外加空心点击。是个NMOS管驱动
电池容量170mAH
能飞7分钟左右
2013-10-17 12:18:33     打赏
遥控器掠影
2013-10-17 12:22:15     打赏
看来讨论是我一个人在说了。
却定了,就是这么整了。
716电机+STM32+传感器。
