//ADS1.2下编译使用
void TestFun(char* fmt,...)
int ch;
char selch = 0;
va_list ap = NULL;
va_start(ap, fmt);
do
selch = *fmt;
if (selch!='%')
putchar(*fmt);
else
selch = *++fmt;
switch(selch)
case 'c':
ch = va_arg(ap, int);
printf(%c,ch);
break;
case 'd':
ch = va_arg(ap,int);
printf(%d,ch);
break;
case 'x':
printf(%#x,ch);
break;
++fmt;
}while(*fmt!='');
va_end(ap);
//调用
TestFun((char*)this is %d,%c,%x,1234,'6',0x12345);
//WIN-TC编译通过
#i nclude
typedef void *va_list;
#define va_start(ap, parmN) (ap = ...)
#define va_arg(ap, type) (*((type *)(ap))++)
#define va_end(ap)
void TestFun(cosnt char* fmt,...)
int ch;
long i32value = 0;
char selch = 0;
va_list ap = 0;
va_start(ap, fmt);
do
selch = *fmt;
if (selch!='%')
putch(*fmt);
else
selch = *++fmt;
switch(selch)
case 'c':
printf(%c,ch);
break;
case 'd':
printf(%d,ch);
break;
case 'x':
printf(%#x,ch);
break;
case 'l':
if(*++fmt== 'd')
i32value = va_arg(ap, long);
printf(%ld,i32value);
else
putch('l');
if(*fmt!=0)
putch(*fmt);
break;
default:
break;
++fmt;
}while(*fmt!='');
va_end(ap);
void main(void)
TestFun(this is %d,%c,%x,%ld,1234,'6',0x2345,(long)12345678);
getch();
void main(void)
TestFun(this is %d,%c,%x,%ld,1234,(char)'6',0x2345,(long)12345678);
getch();
上述的example使用宏定义, var_start(ap, pareN),var_arg(ap,type),var_end(ap).
var_start(ap, pareN) //是ap指向第一个变参.
var_arg(ap,type),//返回变参的实际值.
var_end(ap).//是ap指向空指针.
具体的实现,在不同的编译环境下有所不同.
扩展阅读:单片机C语言编程心得
