电子产品世界 » 论坛首页 » DIY与开源设计 » 设计工具 » ULN2003和ULN2004有哪些区别?
2013-10-25 15:29:01     打赏
The ULN2003A and ULQ2003A have a 2.7-kΩ
series base resistor for each Darlington pair for operation directly with TTL or 5-V CMOS devices. TheULN2004A and ULQ2004A have a 10.5-kΩ series base resistor to allow operation directly from CMOS devices
that use supply voltages of 6 V to 15 V. The required input current of the ULN/ULQ2004A is below that of the
ULN/ULQ2003A, and the required voltage is less than that required by the ULN2002A.
翻译:
ULN2003A和ULQ2003A有一个2.7kΩ的
系列基极电阻每个达林顿对直接与TTL或5-V CMOS器件的操作。该
ULN2004A和ULQ2004A基地10.5kΩ串联电阻允许直接从CMOS器件
6 V到15 V.的所需的输入电流的ULN/ULQ2004A,使用的电源电压低于该
ULN/ULQ2003A,所需的电压是小于ULN2002A要求。
关键词: datasheet中文资料     datasheet p
