电子产品世界 » 论坛首页 » 综合技术 » 通讯及无线技术 » ISO 18000-6c协议
ISO 18000-6c协议
2013-11-04 17:03:45     打赏
做射频识别,遵循的G2标准的是以18000-6c为基础,现在G2标准还在制定中,但是18000-6c已经有中文版,但是,需要用钱去购买。为了方便大家,贡献一个18000-6c协议的英文版!
committee is to prepare International Standards. Draft International
Standards adopted by the joint technical committee are circulated to national bodies for voting. Publication as
an International Standard requires approval by at least 75 % of the national bodies casting a vote.
Attention is drawn to the possibility that some of the elements of this document may be the subject of patent
rights. ISO and IEC shall not be held responsible for identifying any or all such patent rights.
Amendment 1 to ISO/IEC 18000-6:2004 was prepared by Joint Technical Committee ISO/IEC JTC 1,
Information technology, Subcommittee SC 31, Automatic identification and data capture techniques.
Amendment 1 to ISO/IEC 18000-6:2004 covers the extension of ISO/IEC 18000-6 to Type C, to accommodate
the latest development of passive RFID technology in the UHF frequency band from 860 MHz to 960 MHz.
Furthermore, it covers changes in order to achieve an improved collision arbitration and a more robust
protocol for Type A.
见附件
ISO18000-6-C-200611.pdf
关键词: 18000-6c     协议
