电子产品世界 » 论坛首页 » DIY与开源设计 » 电子DIY » 【更新USB+ADC+PWM+UART,求各路大神检阅】liuwwei3 Qua
共4条 1/1 1 跳转至页
【更新USB+ADC+PWM+UART,求各路大神检阅】liuwwei3 QuadCopter DIY进程贴
2014-03-31 13:14:19     打赏
今天收到东西开始工作-2014 3.31 1:00pm
经过几个小时的奋战,终于焊好了2014 3.31 10:21pm
焊好第一次试飞就成功了,哈哈,就是非得不太熟练
好久没更新啦,今天跟新一下进度,论坛格式太蛋疼了,学别人用表格:
【手柄:USB+ADC】修改JOYStick实现简易鼠标 http://forum.eepw.com.cn/thread/249367/1#4
【手柄&飞机】串口调试 http://forum.eepw.com.cn/thread/249367/1#5
【飞机:PWM】螺旋桨转速控制 http://forum.eepw.com.cn/thread/249367/1#6
2014-05-04 22:44:21     打赏
更新内容:ADC+USB实现简易USB鼠标
首先USB是根据JOYStick改的。JOYStick源码目录:C:\Keil\ARM\Examples\ST\STM32F10xUSBLib\Demos。不同的安装目录可能有所不同。下面给出修改的内容:
首先修改"hw_config.c",在Set_System中删去一些没用的东西,删除后如下
void Set_System(void)
  GPIO_InitTypeDef GPIO_InitStructure;
  /* SYSCLK, HCLK, PCLK2 and PCLK1 configuration -----------------------------*/
  /* RCC system reset(for debug purpose) */
  RCC_DeInit();
  /* Enable HSE */
  RCC_HSEConfig(RCC_HSE_ON);
  /* Wait till HSE is ready */
  HSEStartUpStatus = RCC_WaitForHSEStartUp();
  if (HSEStartUpStatus == SUCCESS)
    /* Enable Prefetch Buffer */
    FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
    /* Flash 2 wait state */
    FLASH_SetLatency(FLASH_Latency_2);
    /* HCLK = SYSCLK */
    RCC_HCLKConfig(RCC_SYSCLK_Div1);
    /* PCLK2 = HCLK */
    RCC_PCLK2Config(RCC_HCLK_Div1);
    /* PCLK1 = HCLK/2 */
    RCC_PCLK1Config(RCC_HCLK_Div2);
    /* On STICE the PLL output clock is fixed to 72 MHz */
    RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);
    /* Enable PLL */
    RCC_PLLCmd(ENABLE);
    /* Wait till PLL is ready */
    while (RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET)
    /* Select PLL as system clock source */
    RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
    /* Wait till PLL is used as system clock source */
    while (RCC_GetSYSCLKSource() != 0x08)
  /* enable the PWR clock */
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_PWR, ENABLE);
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIO_DISCONNECT, ENABLE);
  /* USB_DISCONNECT used as USB pull-up */
  GPIO_InitStructure.GPIO_Pin = USB_DISCONNECT_PIN;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_OD;
  GPIO_Init(USB_DISCONNECT, &GPIO_InitStructure);
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO, ENABLE);
  /* Connect EXTI Line9 */
  GPIO_EXTILineConfig(GPIO_KEY_PORTSOURCE, GPIO_KEY_PINSOURCE);
  /* Configure EXTI Line9 to generate an interrupt on falling edge */
  EXTI_InitStructure.EXTI_Line = GPIO_KEY_EXTI_Line;
  EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
  EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Falling;
  EXTI_InitStructure.EXTI_LineCmd = ENABLE;
  EXTI_Init(&EXTI_InitStructure);
  EXTI_ClearITPendingBit(EXTI_Line18);
  EXTI_InitStructure.EXTI_Line = EXTI_Line18; // USB resume from suspend mode
  EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Rising;
  EXTI_ClearITPendingBit(GPIO_KEY_EXTI_Line);
可能删的不够干净,不过不会影响我的程序,就不管了,下一步配置ADC,为了省事,我配置了八路ADC
手柄上共七个ADC,分别为ADC0~7,除ADC4之外,ADC0~7对应PA0~7
0,中间微调
1,右边微调
2,左边微调
3,没用,用于控制喇叭
4,左边上下
5,左边左右
6,右边左右
7,右边上下
ADC配置如下,我也不是很懂配置过程,找网上的教程搞定的,上代码:
void ADC_Configuration()
	//UART and DMA clock
	RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_AFIO |RCC_APB2Periph_ADC1 ,
ENABLE);
	RCC_ADCCLKConfig(RCC_PCLK2_Div6); //72M/6=12,ADC最大时间不能超过14M
	RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE); //使能DMA传输
	//ADC pins config
	GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1|GPIO_Pin_2 | GPIO_Pin_3|
								  GPIO_Pin_4 | GPIO_Pin_5|GPIO_Pin_6
| GPIO_Pin_7;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;
    GPIO_Init(GPIOA, &GPIO_InitStructure);
	//ADC config
	ADC_DeInit(ADC1);
	ADC_InitSturature.ADC_Mode = ADC_Mode_Independent;
	ADC_InitSturature.ADC_ScanConvMode =ENABLE; //模数转换工作在扫描模式
	ADC_InitSturature.ADC_ContinuousConvMode = ENABLE; //模数转换工作在连续转换模式
	ADC_InitSturature.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None; //外部触发转换关闭
	ADC_InitSturature.ADC_DataAlign = ADC_DataAlign_Right; //ADC数据右对齐
	ADC_InitSturature.ADC_NbrOfChannel = M; //顺序进行规则转换的ADC通道的数目
	ADC_Init(ADC1, &ADC_InitSturature); //根据ADC_InitStruct中指定的参数初始化外设ADCx的寄存器
	ADC_RegularChannelConfig(ADC1, ADC_Channel_0, 1, ADC_SampleTime_239Cycles5 );
	ADC_RegularChannelConfig(ADC1, ADC_Channel_1, 2, ADC_SampleTime_239Cycles5 );
	ADC_RegularChannelConfig(ADC1, ADC_Channel_2, 3, ADC_SampleTime_239Cycles5 );
	ADC_RegularChannelConfig(ADC1, ADC_Channel_3, 4, ADC_SampleTime_239Cycles5 );
	ADC_RegularChannelConfig(ADC1, ADC_Channel_4, 5, ADC_SampleTime_239Cycles5 );
	ADC_RegularChannelConfig(ADC1, ADC_Channel_5, 6, ADC_SampleTime_239Cycles5 );
	ADC_RegularChannelConfig(ADC1, ADC_Channel_6, 7, ADC_SampleTime_239Cycles5 );
	ADC_RegularChannelConfig(ADC1, ADC_Channel_7, 8, ADC_SampleTime_239Cycles5 );
	ADC_DMACmd(ADC1, ENABLE);
	ADC_Cmd(ADC1, ENABLE);
	ADC_ResetCalibration(ADC1);
	while(ADC_GetResetCalibrationStatus(ADC1)); //获取ADC1复位校准寄存器的状态,设置 状态则等待
	ADC_StartCalibration(ADC1);  //开始指定ADC1的校准状态
	while(ADC_GetCalibrationStatus(ADC1));   //获取指定ADC1的校准程序,设置状态则 等待
	ADC_SoftwareStartConvCmd(ADC1, ENABLE);
	//DMA config
	DMA_DeInit(DMA1_Channel1);   //将DMA的通道1寄存器重设为缺省值
	DMA_InitStructure.DMA_PeripheralBaseAddr =  (u32)&ADC1->DR;  //DMA外设ADC基地址
	DMA_InitStructure.DMA_MemoryBaseAddr = (u32)&AD_Value;  //DMA内存基地址
	DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;  //内存作为数据传输的目的地
	DMA_InitStructure.DMA_BufferSize = N*M;  //DMA通道的DMA缓存的大小
	DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;  //外设地址寄存器 不变
	DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;  //内存地址寄存器递增
	DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;  //数据宽度为16位
	DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord; //数据宽度 为16位
	DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;  //工作在循环缓存模式
	DMA_InitStructure.DMA_Priority = DMA_Priority_High; //DMA通道 x拥有高优先级
	DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;  //DMA通道x没有设置为内存到内存传输
	DMA_Init(DMA1_Channel1, &DMA_InitStructure);  //根据DMA_InitStruct中指定的参数初始化DMA的通道
	DMA_Cmd(DMA1_Channel1, ENABLE);  //启动DMA通道
代码有点长,里面包括ADC和DMA配置,要事先定义几个全局变量
#define N 50
#define M 8
vu16 AD_Value[N][M]; //用来存放ADC转换结果,也是DMA的目标地址
vu16 After_filter[M]; //用来存放求平均值之后的结果
这里是采用每个值采样50次然后求平均值作为该次采样的值,求平均的函数如下
void filter()
	vu32  sum = 0;
	u8  count;
	u8 index ;
	for(index=0;index<M;index++)
		for (count=0;count<N;count++)
			sum = sum + AD_Value[count][index];
		After_filter[index]=sum/N;
		sum=0;
下面给出mian
int main(void)
#ifdef DEBUG
  debug();
#endif
  bool bflag = TRUE;
  u16 value[M];
  u8 i;
  Set_System();
  USB_Interrupts_Config();
  Set_USBClock();
  USB_Init();
  USART_Configuration();
  ADC_Configuration();
  //printf("UART SUCCESS!!!");
  while (1)
    Delay(0xEFFFFF);
	filter();
    if ((JoyState() != 0) & (bDeviceState == CONFIGURED))
      Joystick_Send(JoyState());
	if(bflag)
  		{GPIO_SetBits(GPIOB,GPIO_Pin_11);bflag = FALSE;}
  	else
  	 	{GPIO_ResetBits(GPIOB,GPIO_Pin_11);bflag = TRUE;}
	for(i=0;i<M;i++)
		value[i]= GetVolt(After_filter[i]);
		printf("%d.%d\t",value[i]/100,value[i]%100);
		Delay(0x1EFF);
	printf("\n");
中间有两句是PB11的闪烁效果,以显示正在正常工作,最后修改"hw_config.c"中的Joy_State
u8 JoyState(void)
  /* "right" key is pressed */
  if (GetVolt(After_filter[5])/100>2)
    return RIGHT;
  /* "left" key is pressed */
  if (GetVolt(After_filter[5])/100<1)
    return LEFT;
  /* "up" key is pressed */
  if (GetVolt(After_filter[4])/100>2)
    return UP;
  /* "down" key is pressed */
  if (GetVolt(After_filter[4])/100<1)
    return DOWN;
  /* No key is pressed */
  else
    return 0;
其中GetVolt是对采样结果进行十进制转化
u16 GetVolt(u16 advalue)
	return (u16)(advalue * 330 / 4096);   //求的结果扩大了100倍,方便下面求出小数
为了让上述程序正常运行,"hw_config.c"中添加外部变量声明:
extern vu16 After_filter[8];
extern u16 GetVolt(u16 advalue);
2014-05-04 22:59:10     打赏
这楼来更一下串口:
首先串口配置如下
void USART_Configuration(void)                       //串口初始化函数
	//UART and LED clock
	RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB , ENABLE);
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA , ENABLE);
	RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1 | RCC_APB2Periph_AFIO , ENABLE);//打开串口时钟
	//GPIOB led
	GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11 | GPIO_Pin_12 ; //管脚位置定义,标号可
	GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;//输出速度50MHz
	GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
	GPIO_Init(GPIOB, &GPIO_InitStructure);//B 组GPIO 初始化
	GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);	 //  no use!!!
	//UART pins
	GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;//管脚9
	GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //复用推挽输出
	GPIO_Init(GPIOA, &GPIO_InitStructure); //TX初始化
	GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;//管脚10
	GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; //浮空输入
	GPIO_Init(GPIOA, &GPIO_InitStructure);//RX初始化
	//UART mode
    USART_InitStructure.USART_BaudRate = 9600;                                   //波特率2400
    USART_InitStructure.USART_WordLength = USART_WordLength_8b; //字长8位
    USART_InitStructure.USART_StopBits = USART_StopBits_1;                  //1位停止字节
    USART_InitStructure.USART_Parity = USART_Parity_No;                    //无奇偶校验
    USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//无流控制
    USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;//打开Rx接收和Tx发送功能
	USART_Init(USART1, &USART_InitStructure);                                          //初始化
    USART_Cmd(USART1, ENABLE);                                                        //启动串口
上面的配置代码是针对手柄的,其中包含了配置手柄上两个LED的代码,串口的波特率是9600,在调试串口时出了一些问题。见 http://forum.eepw.com.cn/thread/250241/1
mian函数和上层一样,main函数其中有一部分代码是让一个led闪烁,这样做的目的是直观的看到机器有没有死机。
飞机上的串口比较蛋疼,因为飞机上的晶振是16M的,所以要配置时钟,串口才能正常,我不会配置(会的大牛求指导啊),我有一个简单的方法,就是配置串口波特率为9600,然后电脑上串口工具使用19200接收,这样完全正常。
2014-05-04 23:34:08     打赏
这楼把飞机上的代码全部拿出来,重点就是PWM啦,其它的就是串口的问题,上层已经说明,上全部代码
RCC
void RCC_Configuration(void)
  RCC_DeInit();
  /* Enable HSE */
  if(HSEStartUpStatus == SUCCESS)
    /* HCLK = SYSCLK */
    /* PCLK2 = HCLK */
    /* PLLCLK = 8MHz * 9 = 72 MHz */
    RCC_PLLConfig(RCC_PLLSource_HSE_Div2, RCC_PLLMul_9);//这一句DIV2貌似不管用,对串口没影响
    /* Enable PLL */
    RCC_PLLCmd(ENABLE);
    while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET)
    while(RCC_GetSYSCLKSource() != 0x08)
	RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC , ENABLE);
	RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);
    /* GPIOA and AFIO clock enable */
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_AFIO  , ENABLE);
	RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1 , ENABLE);//打开串口时钟
所有引脚的配置
void GPIO_Configuration(void)
	//GPIOC	pin13 normal leds
	GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13; //管脚位置定义,标号可
	GPIO_Init(GPIOC, &GPIO_InitStructure);//B 组GPIO 初始化
	//PWM
	GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_0 | GPIO_Pin_1|GPIO_Pin_2 | GPIO_Pin_3;
	//UART
UART配置,正如上层说的,波特率配置9600,PC用19200接收才正常,蛋疼
PWM,借鉴了snake的代码,版权归snake
void PWMchannel_config(int t1,int t2,int t3,int t4)
  TIM_TimeBaseStructure.TIM_Period = 665;
  TIM_TimeBaseStructure.TIM_Prescaler = 10;
  TIM_TimeBaseStructure.TIM_ClockDivision = 0;
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
  TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);
  TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
  TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
  TIM_OCInitStructure.TIM_Pulse = t1;
  TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
  TIM_OC1Init(TIM2, &TIM_OCInitStructure);
  TIM_OC1PreloadConfig(TIM2, TIM_OCPreload_Enable);
  TIM_OCInitStructure.TIM_Pulse = t2;
  TIM_OC2Init(TIM2, &TIM_OCInitStructure);
  TIM_OC2PreloadConfig(TIM2, TIM_OCPreload_Enable);
  TIM_OCInitStructure.TIM_Pulse = t3;
  TIM_OC3Init(TIM2, &TIM_OCInitStructure);
  TIM_OC3PreloadConfig(TIM2, TIM_OCPreload_Enable);
  TIM_OCInitStructure.TIM_Pulse = t4;
  TIM_OC4Init(TIM2, &TIM_OCInitStructure);
  TIM_OC4PreloadConfig(TIM2, TIM_OCPreload_Enable);
  TIM_ARRPreloadConfig(TIM2, ENABLE);
NVIC
void NVIC_Configuration(void)
#ifdef  VECT_TAB_RAM
  /* Set the Vector Table base location at 0x20000000 */
  NVIC_SetVectorTable(NVIC_VectTab_RAM, 0x0);
#else  /* VECT_TAB_FLASH  */
  /* Set the Vector Table base location at 0x08000000 */
  NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0);
#endif
主函数
int main(void)
#ifdef DEBUG
  debug();
#endif
	bool bflag = TRUE;
	u16 value[8];
	u8 i;
	RCC_Configuration();
	NVIC_Configuration();
	GPIO_Configuration();
  	TIM_Cmd(TIM2, ENABLE);
  	while (1)
		sleep(0x1EFFFFF);
		for(i=0;i<8;i++)
			value[i]= i;
			sleep(0x1EFF);
		printf("\n");
	  	if(bflag)
  			{GPIO_SetBits(GPIOC,GPIO_Pin_13);bflag = FALSE;
			 PWMchannel_config(100,100,100,100);}
  		else
  	 		{GPIO_ResetBits(GPIOC,GPIO_Pin_13);bflag = TRUE;
			 PWMchannel_config(0,0,0,0);}
废话不多说,这段程序的效果就是:螺旋桨转一下停一下,灯也一闪一闪的
共4条 1/1 1 跳转至页
