电子产品世界 » 论坛首页 » DIY与开源设计 » 电子DIY » SPI启动无线收发模块的问题(检测不到nrf模块)
共5条 1/1 1 跳转至页
2014-05-12 20:38:46     打赏
首先,我用的是手柄做的无线模块的检测,通过写入一个地址然后读出,来检测无线收发模块是否存在。
spi配置:
void SPI_Configuration()
	SPI_InitTypeDef  SPI_InitStructure;
	RCC_APB2PeriphClockCmd(RCC_APB1Periph_SPI2|
						   RCC_APB2Periph_GPIOA|
						   RCC_APB2Periph_GPIOB|
						   RCC_APB2Periph_GPIOC|RCC_APB2Periph_AFIO, ENABLE);
	GPIO_InitStructure.GPIO_Pin = GPIO_Pin_15|GPIO_Pin_13; //PB13-SCK PB15-MOSI
	GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;
	GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
	GPIO_Init(GPIOB, &GPIO_InitStructure);
	GPIO_InitStructure.GPIO_Pin = GPIO_Pin_14;//PB14-MISO
	GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
	GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13|GPIO_Pin_14;//PC13-CSN PC14-CE
	GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
	GPIO_Init(GPIOC, &GPIO_InitStructure);
	GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_15; //PC15-IPU
	GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
	/*  配置SPI1模块 初始化*/
   	SPI_I2S_DeInit(SPI2);
   	SPI_Cmd(SPI2, DISABLE); //必须先禁用,才能改变MODE
   	SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;  //两线全双工
   	SPI_InitStructure.SPI_Mode = SPI_Mode_Master;       //主
   	SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;      //8位
   	SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low;        //CPOL=0 时钟悬空低
   	SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge;       //CPHA=0 数据捕获第1个
   	SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;        //软件NSS
   	SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_4 ; //256分频
   	SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_LSB;      //高位在前
   	SPI_InitStructure.SPI_CRCPolynomial = 7;        //CRC7
   	SPI_Init(SPI2, &SPI_InitStructure);
   	SPI_Cmd(SPI2, ENABLE);
   	//SPI_ReadWriteByte(0xff);   //启动传输
nrf init
//24L01片选信号
#define CE_H()   GPIO_SetBits(GPIOC, GPIO_Pin_14)
#define CE_L()   GPIO_ResetBits(GPIOC, GPIO_Pin_14)
//SPI片选信号
#define CSN_H()  GPIO_SetBits(GPIOC, GPIO_Pin_13)
#define CSN_L()  GPIO_ResetBits(GPIOC, GPIO_Pin_13)
void  NRF24L01_Init(void)
   CE_L();          //使能24L01
   CSN_H();        //SPI片选取消
spi 字节收发
u8 SPI_ReadWriteByte(u8 data)
	u8 temp;
	printf("  Enter SPIRW%d\n  ",data);
	while (SPI_I2S_GetFlagStatus(SPI2, SPI_I2S_FLAG_TXE) == RESET);
    /* Send SPI2 data */
    SPI_I2S_SendData(SPI2, data);
	printf("  send ok   ");
	while (SPI_I2S_GetFlagStatus(SPI2, SPI_I2S_FLAG_RXNE) == RESET);
    /* Read SPI2 received data */
    temp = SPI_I2S_ReceiveData(SPI2);
	printf("  Leave SPIRW%d\n  ",temp);
	return temp;          //返回收到的数据
每次都会死在这一句
mian 函数相关部分
 SPI_Configuration();
  NRF24L01_Init();
  //printf("aaaUART SUCCESS!!!");Delay(0x1EFF);
  if(NRF24L01_Check()==0)
	printf("  nrf check success");
  while (1)
其中NRF24L01_Check:
u8 NRF24L01_Check(void)
	u8 buf[5]={0XA5,0XA5,0XA5,0XA5,0XA5};
	u8 i;
	SPI2_SetSpeed(SPI_SPEED_8); //spi速度为9Mhz(24L01的最大SPI时钟为10Mhz)
	NRF24L01_Write_Buf(WRITE_REG+TX_ADDR,buf,5);//写入5个字节的地址.
	NRF24L01_Read_Buf(TX_ADDR,buf,5); //读出写入的地址
	for(i=0;i<5;i++)if(buf[i]!=0XA5)break;
	if(i!=5)return 1;//检测24L01错误
	return 0; //检测到24L01
 每次spi发送就会死机,求大神解答!!!
2014-05-12 23:12:27     打赏
手柄上不是使用的spi2吗?我现在还只是检测无线模块存不存在,就死在发送等待那句话了,悲剧。刚才我看了你分享的代码,发送那个工程里使用的是spi1,这让我很困惑,难道我理解有误?
2014-05-12 23:19:20     打赏
哦哦,我知道了,应该用RCC_APB1PeriphClockCmd(RCC_APB1Periph_SPI2)对不对,傻逼了,我试试。
2014-05-13 00:52:33     打赏
还是没搞定,不会死在那个地方了,现在状况是这样的:我写TX_ADDR然后读取,读出来全是0。详情再下一层
2014-05-13 00:59:31     打赏
代码:
	u8 i;
	printf("i=%d\n",i);
u8 NRF24L01_Read_Buf(u8 reg,u8 *pBuf,u8 len)
	u8 status,u8_ctr;
	CSN_L();                             //使能SPI传输
	status=SPI_ReadWriteByte(reg);       //发送寄存器值(位置),并读取状态值
	for(u8_ctr=0;u8_ctr<len;u8_ctr++)
		pBuf[u8_ctr]=SPI_ReadWriteByte(0XFF);//读出数据
	CSN_H();                             //禁止SPI传输
	return status;                       //返回读到的状态值
u8 NRF24L01_Write_Buf(u8 reg, u8 *pBuf, u8 len)
	u8 status,u8_ctr;
	CSN_L();                        //使能SPI传输
	status = SPI_ReadWriteByte(reg);//发送寄存器值(位置),并读取状态值
	for(u8_ctr=0; u8_ctr<len; u8_ctr++)
		SPI_ReadWriteByte(*pBuf++);     //写入数据
	CSN_H();                        //关闭SPI传输
	u8 temp;
	printf("  W%d \n  ",data);
	printf("  R%d \n  ",temp);
现在调用NRF24L01_Check,打印消息如下
W48
    R112
    W165
    R195
    W165
    R195
    W165
    R195
    W165
    R195
    W165
    R195
    W16
    R112
    W255
    R0
    W255
    R0
    W255
    R0
    W255
    R0
    W255
    R0
  i=0
就是写进去的地址跟读出来的不一样
共5条 1/1 1 跳转至页
