电子产品世界 » 论坛首页 » 嵌入式开发 » MCU » 矩阵按键,组合键
矩阵按键,组合键
2014-05-14 17:34:53     打赏
unsigned char Key_Scan(void)
    unsigned char Scan_Code = 0, Read_Code = 0, Key_Value = 0;
   unsigned char Key_Temp = 0;
   DDRC   |= 0x0f;
   PORTC  &= 0xf0; // Row output Low
   DDRD  |= 0xf8;
   PORTD  |= 0xf8;   // Column output High
   DDRD  &= 0x07;
   Key_Temp = PIND & 0xf8;
   if( Key_Temp != 0xf8 )
    Delay_Ms(10);
     Scan_Code = 0xfe;
     while( Scan_Code != 0xff )
     PORTC = ( Scan_Code & 0x0f );
     Key_Temp = PIND & 0xf8; // 再读具体行
      Read_Code = (Key_Temp & 0xf8) | 0x07;
      Key_Value |= ( ~Scan_Code ) + ( ~Read_Code );
     Scan_Code = ( Scan_Code << 1 ) | 0x01;
  PORTC  &= 0x0f;
  return ( Key_Value );
关键词: 矩阵按键     组合键
