电子产品世界 » 论坛首页 » DIY与开源设计 » 电子DIY » 数码管篇作业
共4条 1/1 1 跳转至页
数码管篇作业
2014-06-10 22:13:10     打赏
只有晚上才有时间研究和敲代码。熬夜敲代码的孩纸悲催呀。
以下是使用4位拨码开关控制数码管并进行0~F显示源代码,经过testbench 验证和下载调试。
`timescale 1ns / 1ps
// Company:
// Engineer: Charles Wang
// Create Date:    06/08/2014
// Design Name: 	led_display_dip
// Module Name:   led_display_dip
// Project Name: 	led_display_dip
// Target Devices: EP4CE6E22C8
// Tool versions: Quartus II 13.1 & Modelsim 10.1c
// Description: 使用4位拨码开关控制数码管并进行0~F显示
// Dependencies:
// Revision:
// Revision 0.01 - File Created
// Additional Comments:
module led_display_dip(clk,rst_n,sw,led_seg,led_bit);
input clk;//50MHz 总线时钟
input rst_n;//异步复位,低电平复位
input [3:0]sw;//4位拨码开关
output [7:0]led_seg;//8段LED数码管段选,共阳极数码管
output [7:0]led_bit;//8位LED 位选,低电平选中数码管
reg [7:0]led_seg;
parameter
			seg0 = 8'hc0,   // "0"
			seg1 = 8'hf9,   // "1"
			seg2 = 8'ha4,   // "2"
			seg3 = 8'hb0,   // "3"
			seg4 = 8'h99,   // "4"
			seg5 = 8'h92,   // "5"
			seg6 = 8'h82,   // "6"
			seg7 = 8'hf8,   // "7"
			seg8 = 8'h80,   // "8"
			seg9 = 8'h90,   // "9"
			sega = 8'h88,   // "a"
			segb = 8'h83,   // "b"
			segc = 8'hc6,   // "c"
			segd = 8'ha1,   // "d"
			sege = 8'h86,   // "e"
			segf = 8'h8e;   // "f"
reg [7:0]led_seg_r;
always@(posedge clk or negedge rst_n)
	begin
		if(!rst_n)
			led_seg <= 8'hff;
		else
			led_seg <= led_seg_r;
	end
always@(sw)
	begin  //数码管显示
		case(sw)
			4'b0000: led_seg_r <= seg0;
			4'b0001: led_seg_r <= seg1;
			4'b0010: led_seg_r <= seg2;
			4'b0011: led_seg_r <= seg3;
			4'b0100: led_seg_r <= seg4;
			4'b0101: led_seg_r <= seg5;
			4'b0110: led_seg_r <= seg6;
			4'b0111: led_seg_r <= seg7;
			4'b1000: led_seg_r <= seg8;
			4'b1001: led_seg_r <= seg9;
			4'b1010: led_seg_r <= sega;
			4'b1011: led_seg_r <= segb;
			4'b1100: led_seg_r <= segc;
			4'b1101: led_seg_r <= segd;
			4'b1110: led_seg_r <= sege;
			4'b1111: led_seg_r <= segf;
			default: led_seg_r <= 8'hff;//默认不点亮LED数码管
		endcase
	end
assign led_bit = 8'b1111_1110;//只选中一个LED数码管
endmodule
testbench
// Company:
// Design Name: 	led_display_dip_tb
// Module Name:   led_display_dip_tb
// Project Name: 	led_display_dip_tb
// Tool versions: Quartus II 13.1 & Modelsim 10.0c
// Description: ??4?????????????0~F?? testbench
// Dependencies:
// Revision:
module led_display_dip_tb();
reg clk;
reg rst_n;
reg [3:0]sw;
wire [7:0]led_seg;
wire [7:0]led_bit;
reg [3:0]i;
led_display_dip display_dip(clk,rst_n,sw,led_seg,led_bit);
initial
  begin
    sw = 4'b0000;
    clk = 1'b0;
    #10 rst_n = 1'b0;
    #20 rst_n = 1'b1;
    #260 sw = 4'b1011;
    forever
      #10 clk = ~clk;
  end
endmodule
模为60的计数器,计数结果动态显示在数码管上作业源代码,代码经过功能仿真和下载到开发板调试
// Company:
// Create Date:    06/10/2014
// Design Name: 	led_counter60
// Module Name:   led_counter60
// Project Name: 	led_counter60
// Description: 模为60的计数器,计数结果动态显示在数码管上
// Dependencies:
// Revision:
module led_counter60(clk,rst_n,led_bit,led_seg);
input clk;//50Mhz总线时钟
output [7:0]led_seg;//LED 数码管段选
output [7:0]led_bit;//LED 数码管位选
reg [7:0]led_seg;
reg [7:0]led_bit;
reg [15:0]delay_sel;//位选计数寄存器
always@(posedge clk or negedge rst_n) //动态扫描分频模块,50MHZ → 1Khz
	begin
		if(!rst_n)
			delay_sel <= 16'h0000;
		else if(delay_sel == 16'd49999)
		else
			delay_sel <= delay_sel + 1'b1;
	end
reg [27:0]delay_cnt;//计数器分频寄存器
always@(posedge clk or negedge rst_n)//计数器分频模块,50MHz → 1Hz
	begin
		if(!rst_n)
			delay_cnt <= 28'h0000000;
		else if(delay_cnt == 28'd49999999)
		else
			delay_cnt <= delay_cnt + 1'b1;
	end
reg bit_select;//位选寄存器
always@(posedge clk or negedge rst_n)//LED 数码管位选模块
	begin
		if(!rst_n)
			bit_select <= 1'b0;
			bit_select <= bit_select + 1'b1;
		else
			bit_select <= bit_select;
	end
always@(bit_select)
	begin
		case(bit_select)
			1'b0: led_bit <= 8'b1111_1110;
			1'b1: led_bit <= 8'b1111_1101;
			default: led_bit <= 8'b1111_1111;
		endcase
	end
reg [2:0]decade_cnt;//模60计数器的十位计数寄存器
reg [3:0]unit_cnt;//模60计数器的个位计数寄存器
always@(posedge clk or negedge rst_n)//模60计数器计数模块
	begin
		if(!rst_n)
			begin
				decade_cnt <= 3'b000;
				unit_cnt <= 4'b0000;
			end
		else if(decade_cnt == 3'b101 && unit_cnt == 4'b1001 && delay_cnt == 28'd49999999)
			begin
			end
		else if(unit_cnt == 4'b1001 && delay_cnt == 28'd49999999)
			begin
				decade_cnt <= decade_cnt + 1'b1;
			end
			begin
				decade_cnt <= decade_cnt;
				unit_cnt <= unit_cnt + 1'b1;
			end
		else
		   begin
		     unit_cnt <= unit_cnt;
		   end
	end
parameter //数码管定义
reg [7:0]led_seg_r;//数码管段选寄存器
reg [7:0]led_seg_unit;//数码管个位段选寄存器
reg [7:0]led_seg_decade;//数码管十位段选寄存器
	begin
		if(!rst_n)
			led_seg <= 8'hff;
		else
	end
always@(led_bit)
	begin
		case(led_bit)
			8'b1111_1110: led_seg_r <= led_seg_unit;
			8'b1111_1101: led_seg_r <= led_seg_decade;
			default     : led_seg_r <= 8'hff;
		endcase
	end
always@(unit_cnt)//数码管个位显示模块
	begin
		case(unit_cnt)
			4'b0000: led_seg_unit <= seg0;
			4'b0001: led_seg_unit <= seg1;
			4'b0010: led_seg_unit <= seg2;
			4'b0011: led_seg_unit <= seg3;
			4'b0100: led_seg_unit <= seg4;
			4'b0101: led_seg_unit <= seg5;
			4'b0110: led_seg_unit <= seg6;
			4'b0111: led_seg_unit <= seg7;
			4'b1000: led_seg_unit <= seg8;
			4'b1001: led_seg_unit <= seg9;
			default: led_seg_unit <= 8'hff;
		endcase
	end
always@(decade_cnt)//数码管十位显示模块
	begin
		case(decade_cnt)
			3'b000: led_seg_decade <= seg0;
			3'b001: led_seg_decade <= seg1;
			3'b010: led_seg_decade <= seg2;
			3'b011: led_seg_decade <= seg3;
			3'b100: led_seg_decade <= seg4;
			3'b101: led_seg_decade <= seg5;
			default: led_seg_decade <= 8'hff;
		endcase
	end
endmodule
 testbench代码:
// Company:
// Design Name: 	led_counter60_tb
// Module Name:   led_counter60_tb
// Project Name: 	led_counter60_tb
// Description: ??60????,????????????? testbench
// Dependencies:
// Revision:
module led_counter60_tb();
reg clk;
reg rst_n;
wire [7:0]led_bit;
wire [7:0]led_seg;
led_counter60 counter60(.clk(clk),.rst_n(rst_n),.led_bit(led_bit),.led_seg(led_seg));
initial
  begin
    #10 clk = 1'b0;
    #20 rst_n= 1'b0;
    #10 rst_n= 1'b1;
    forever
    #10 clk = ~clk;
  end
endmodule
关键词: 数码     管篇     作业
2014-06-10 22:23:45     打赏
顺便问51FPGA 大大几个在做实验过程中遇到的问题:
1,对于数码管篇的第一个实验,如您所看,我的测试激励中    #260 sw = 4'b1011; 必须是时间延时要比较大才能看到所想要的结果,我这里是260个时间单位,一开始我做功能仿真时,总是得不到自己想要的仿真结果,可是检查代码很多遍都没有问题,后来才发现是时间延时太短了,这是为什么呢?是不是跟时序设置有关哦?
2,一般在什么时候我们才会考虑Set-up time 和 Holding time 呢?比如我们最近这几次的实验,感觉对时序收敛这一块都没有要求,当然可能是我们这几个实验本身自己的时序是已经得到满足了,所以不需要再进行时许收敛设置,这样理解对么?
感谢您抽时间看我这个夜猫子罗里巴嗦说那么多。谢谢
2014-06-10 22:29:30     打赏
上传60进制数码显示的部分图片
57585900
2014-06-10 22:34:51     打赏
还有个问题就是,在功能仿真时总会遇到这么一个问题:
比如我们这个数码管篇第一个实验,我的工程源代码名字是led_display_dip 而 testbench 工程名字是led_project_dip_tb, 在modelsim 导入这两个代码文件时,软件老是显示led_display_dip 是testbench 的顶层文件,当然我有把testbench 工程名字设置成led_project_dip_tb,每次遇到这个问题,总要关了软件重开才行,不知道是我哪里操作出了问题?
望51FPGA 大大指点,谢谢
共4条 1/1 1 跳转至页
