| 型号 | 材料 | 最高电压 | 最大电流 | 最大功率 | 频率 | 沟道电阻 |
| 2SK30ATM | N-FET | 50 V | 6,5 mA | - | - | - |
| 2SK33 | N-FET | 20 V | 20 mA | 0,15 W | - | - |
| 2SK40 | N-FET | 50 V | 6,5 mA | - | - | - |
| 2SK55 | N-FET | 18 V | 14 mA | - | - | - |
| 2SK68 | N-FET | 50 V | 0,5 mA | - | - | - |
| 2SJ72 | P-FET | 25 V | 30 mA | 0,6 W | - | - |
| 2SK73 | N-FET | 200 V | 0,1 A | 5 W | - | - |
| 2SJ74 | P-FET | 25 V | 1 mA | - | - | - |
| 2SJ77 | P-FET | 160 V | 0,5 A | 30 W | - | - |
| 2SJ79 | P-FET | 200 V | 0,5 A | 30 W | - | - |
| 2SK83 | N-FET | 25 V | 10 mA | 0,1 W | - | - |
| 2SJ103 | P-FET | 50 V | 2,6 mA | - | - | - |
| 2SK107 | N-FET | 9 V | 20 mA | 250 mW | - | - |
| 2SK108 | N-FET | 50 V | 20 mA | 0,3 W | - | 70 Ohm |
| 2SJ109 | P-FET | DUAL | 30 V | - | - | - |
| 2SJ113 | P-FET | 100 V | 10 A | 100 W | - | O,35 Ohm |
| 2SJ117 | P-FET | 400 V | 2 A | 40 W | - | - |
| 2SK117 | N-FET | 50 V | 5 mA | - | - | - |
| 2SK118 | N-FET | 50 V | 0,3 mA | 0,1 W | - | - |
| 2SK125 | N-FET | 25 V | 0,1 A | 0,3 W | - | - |
| 2SK152 | N-FET | 15 V | 9,5 mA | - | - | - |
| 2SK161 | N-FET | 18 V | 0,01 A | 0,2 W | - | - |
| 2SJ162 | P-FET | 160 V | 7 A | 100 W | - | 1 Ohm |
| 2SK163 | N-FET | 50 V | 0,03 A | 0,4 W | - | - |
| 2SK168 | N-FET | 30 V | 20 mA | 0,2 W | - | - |
| 2SK170 | N-FET | 40 V | 20 mA | 0,4 W | - | - |
| 2SJ174 | P-FET | 60 V | 20 A | 75 W | - | - |
| 2SJ175 | P-FET | 60 V | 10 A | 25 W | - | O,25 Ohm |
| 2SJ177 | P-FET | 60 V | 20 A | 75 W | - | 0,085 Ohm |
| 2SJ182 | P-FET | 60 V | 3 A | 20 W | - | O,28 Ohm |
| 2SK184 | N-FET | 50 V | 0,6 mA | - | - | - |
| 2SK192 | N-FET | 18 V | 3 mA | - | - | - |
| 2SJ200 | P-FET | 180 V | 10 A | 120 W | - | - |
| 2SJ201 | P-FET | 200 V | 12 A | 150 W | - | - |
| 2SK212 | N-FET | 20 V | 0,6 mA | 0,2 W | - | - |
| 2SK214 | N-FET | 160 V | 0,5 A | 30 W | - | - |
| 2SK216 | N-FET | 200 V | 0,5 A | 30 W | - | - |
| 2SK223 | N-FET | 80 V | 1,2 mA | 0,4 W | - | - |
| 2SK240 | N-FET | 40 V | 2,6 mA | - | - | - |
| 2SK246 | N-FET | 50 V | 1,2 mA | - | - | - |
| 2SK301 | N-FET | 55 V | 20 mA | 0,25 W | - | - |
| 2SK303 | N-FET | 30 V | 0,6 mA | - | - | - |
| 2SK304 | N-FET | 30 V | 0,6 mA | - | - | - |
| 2SJ306 | P-FET | 250 V | 3 A | 25 W | - | 2,0 Ohm |
| 2SJ307 | P-FET | 250 V | 6 A | 2 W | - | 1,0 Ohm |
| 2SK315 | N-FET | 20 V | 2,5 mA | 0,2 W | - | - |
| 2SK320 | N-FET | 450 V | 5 A | 50 W | - | 1,83 Ohm |
| 2SK330 | N-FET | 50 V | 14 mA | 0,2 W | - | 320 Ohm |
| 2SK332 | N-FET | 40 V | 12 mA | - | - | - |
| 2SJ353 | P-FET | 60 V | 1,5 A | 1 W | - | 0,37 Ohm |
| 2SK357 | N-FET | 150 V | 5 A | 40 W | - | 0,9 Ohm |
| 2SK359 | N-FET | 20 V | 30 mA | 0,4 W | - | - |
| 2SK363 | N-FET | 40 V | 5 mA | - | - | - |
| 2SK364 | N-FET | 40 V | 2,6 mA | - | - | - |
| 2SK367 | N-FET | 100 V | 0,6 mA | - | - | - |
| 2SK369 | N-FET | 40 V | 5 mA | - | - | - |
| 2SK373 | N-FET | 100 V | 0,6 mA | - | - | - |
| 2SK374 | N-FET | 55 V | 1 mA | - | - | - |
| 2SK381 | N-FET | 50 V | 0,3 mA | 0,3 W | - | - |
| 2SK386 | N-FET | 450 V | 10 A | 120 W | - | - |
| 2SK400 | N-FET | 200 V | 8 A | 100 W | - | 0,7 Ohm |
| 2SK404 | N-FET | 20 V | 1,2 mA | 0,2 W | - | - |
| 2SK415 | N-FET | 800 V | 3 A | 100 W | - | 6 Ohm |
| 2SK423 | N-FET | 100 V | 0,5 A | 0,9 W | - | - |
| 2SK427 | N-FET | 15 V | 2,5 mA | - | - | - |
| 2SK430 | N-FET | 150 V | 3 A | 20 W | - | 0,8 Ohm |
| 2SK439 | N-FET | 20 V | 30 mA | 0,3 W | - | - |
| 2SJ449 | P-FET | 250 V | 6 A | 35 W | - | 0,8 Ohm |
| 2SK511 | N-FET | 250 V | 0,3 A | 8 W | - | - |
| 2SK513 | N-FET | 800 V | 3 A | 60 W | - | - |
| 2SK526 | N-FET | 250 V | 10 A | 40 W | - | 0,6 Ohm |
| 2SK537 | N-FET | 900 V | 1 A | 60 W | - | - |
| 2SK538 | N-FET | 900 V | 3 A | 100 W | - | 4,5 Ohm |
| 2SK544 | N-FET | 20 V | 30 mA | 0,3 W | - | - |
| 2SK553 | N-FET | 500 V | 5 A | 50 W | - | 1,5 Ohm |
| 2SK555 | N-FET | 500 V | 7 A | 60 W | - | 0,85 Ohm |
| 2SK557 | N-FET | 500 V | 12 A | 100 W | - | 0,6 Ohm |
| 2SK559 | N-FET | 450 V | 15 A | 100 W | - | 0,36 Ohm |
| 2SK583 | N-FET | 50 V | 0,2 A | 0,6 W | - | 20 Ohm |
| 2SK606 | N-FET | 30 V | 20 mA | - | - | - |
| 2SK611 | N-FET | 100 V | 1 A | 10 W | - | 6 Ohm |
| 2SK612 | N-FET | 100 V | 2 A | 20 W | - | - |
| 2SK685 | N-FET | 1000 V | 5 A | 100 W | - | 2 Ohm |
| 2SK701 | N-FET | 60 V | 2 A | 15 W | - | 0,6 Ohm |
| 2SK703 | N-FET | 100 V | 5 A | 35 W | - | 0,5 Ohm |
| 2SK719 | N-FET | 900 V | 5 A | 120 W | - | - |
| 2SK725 | N-FET | 500 V | 15 A | 125 W | - | 0,38 Ohm |
| 2SK727 | N-FET | 900 V | 5 A | 125 W | - | 2,5 Ohm |
| 2SK735 | N-FET | 450 V | 10 A | 100 W | - | 0,8 Ohm |
| 2SK754 | N-FET | 160 V | 10 A | 50 W | - | 0,22 Ohm |
| 2SK758 | N-FET | 250 V | 5 A | 40 W | - | O,7 Ohm |
| 2SK769 | N-FET | 500 V | 10 A | 100 W | - | 1 Ohm |
| 2SK786 | N-FET | 20 V | 3 A | 50 W | - | 7,5 Ohm |
| 2SK787 | N-FET | 900 V | 8 A | 120 W | - | - |
| 2SK790 | N-FET | 500 V | 15 A | 150 W | - | - |
| 2SK791 | N-FET | 850 V | 3 A | 100 W | - | 4,5 Ohm |
| 2SK792 | N-FET | 900 V | 3 A | 100 W | - | 4,5 Ohm |
| 2SK793 | N-FET | 850 V | 5 A | 150 W | - | 2,5 Ohm |
| 2SK794 | N-FET | 900 V | 5 A | 150 W | - | 2,5 Ohm |
| 2SK806 | N-FET | 600 V | 3 A | 50 W | - | 2,7 Ohm |
| 2SK817 | N-FET | 60 V | 26 A | 35 W | - | 0,08 Ohm |
| 2SK851 | N-FET | 200 V | 30 A | 150 W | - | - |
| 2SK856 | N-FET | 60 V | 45 A | 125 W | - | 0,03 Ohm |
| 2SK872 | N-FET | 900 V | 6 A | 150 W | - | 2,5 Ohm |
| 2SK875 | N-FET | 450 V | 12 A | 120 W | - | 0,6 Ohm |
| 2SK890 | N-FET | 200 V | 10 A | 75 W | - | 0,4 Ohm |
| 2SK891 | N-FET | 100 V | 18 A | 125 W | - | 0,18 Ohm |
| 2SK899 | N-FET | 500 V | 18 A | 125 W | - | 0,33 Ohm |
| 2SK902 | N-FET | 250 V | 30 A | 150 W | - | - |
| 2SK903 | N-FET | 800 V | 3 A | 40 W | - | 4 Ohm |
| 2SK904 | N-FET | 800 V | 3 A | 80 W | - | 4 Ohm |
| 2SK940 | N-FET | 60 V | 0,8 A | 0,9 W | - | 1,1 Ohm |
| 2SK943 | N-FET | 60 V | 25 A | 40 W | - | 0,046 Ohm |
| 2SK951 | N-FET | 800 V | 2,5 A | 40 W | - | 7 Ohm |
| 2SK952 | N-FET | 800 V | 0,5 mA | - | - | - |
| 2SK955 | N-FET | 800 V | 5 A | 125 W | - | 2 Ohm |
| 2SK956 | N-FET | 800 V | 9 A | 150 W | - | 1,5 Ohm |
| 2SK962 | N-FET | 900 V | 0,5 mA | - | - | - |
| 2SK1010 | N-FET | 500 V | 6 A | 80 W | - | 1,5 Ohm |
| 2SK1036 | N-FET | 250 V | 1 A | 2 W | - | - |
| 2SK1057 | N-FET | 140 V | 7 A | 100 W | - | - |
| 2SK1058 | N-FET | 160 V | 7 A | 100 W | - | 1 Ohm |
| 2SK1081 | N-FET | 800 V | 7 A | 125 W | - | - |
| 2SK1082 | N-FET | 900 V | 6 A | 125 W | - | 2,8 Ohm |
| 2SK1101 | N-FET | 450 V | 10 A | 50 W | - | 0,65 Ohm |
| 2SK1102 | N-FET | 500 V | 10 A | 50 W | - | - |
| 2SK1113 | N-FET | 120 V | 3 A | 20 W | - | - |
| 2SK1117 | N-FET | 600 V | 6 A | 100 W | - | 1,25 Ohm |
| 2SK1118 | N-FET | 600 V | 6 A | 45 W | - | 1,25 Ohm |
| 2SK1119 | N-FET | 100 V | 4 A | 100 W | - | - |
| 2SK1120 | N-FET | 1000 V | 8 A | 150 W | - | 1,8 Ohm |
| 2SK1170 | N-FET | 500 V | 20 A | 120 W | - | 0,27 Ohm |
| 2SK1181 | N-FET | 500 V | 13 A | 85 W | - | 0,4 Ohm |
| 2SK1190 | N-FET | 60 V | 22 A | 35 W | - | 0,05 Ohm |
| 2SK1191 | N-FET | 60 V | 30 A | 40 W | - | 0,03 Ohm |
| 2SK1198 | N-FET | 700 V | 2 A | 35 W | - | 3,2 Ohm |
| 2SK1213 | N-FET | 600 V | 6 A | 125 W | - | - |
| 2SK1217 | N-FET | 900 V | 8 A | 100 W | - | - |
| 2SK1221 | N-FET | 250 V | 10 A | 80 W | - | 0,4 Ohm |
| 2SK1257 | N-FET | 60 V | 40 A | 45 W | - | 0,05 Ohm |
| 2SK1271 | N-FET | 1400 V | 5 A | 240 W | - | 4 Ohm |
| 2SK1275 | N-FET | 900 V | 2 A | 30 W | - | 7 Ohm |
| 2SK1296 | N-FET | 60 V | 30 A | - | - | 0,024 Ohm |
| 2SK1299 | N-FET | 100 V | 3 A | 20 W | - | 0,45 Ohm |
| 2SK1317 | N-FET | 1500 V | 2,5 A | 100 W | - | 12 Ohm |
| 2SK1338 | N-FET | 900 V | 2 A | 50 W | - | 7 Ohm |
| 2SK1341 | N-FET | 900 V | 6 A | 100 W | - | 3 Ohm |
| 2SK1342 | N-FET | 900 V | 8 A | 100 W | - | 1,6 Ohm |
| 2SK1345 | N-FET | 60 V | 20 A | 40 W | - | 0,055 Ohm |
| 2SK1350 | N-FET | 200 V | 15 A | 45 W | - | 0,14 Ohm |
| 2SK1351 | N-FET | 500 V | 5 A | 40 W | - | 1,5 Ohm |
| 2SK1356 | N-FET | 900 V | 3 A | 40 W | - | - |
| 2SK1357 | N-FET | 900 V | 5 A | 125 W | - | - |
| 2SK1358 | N-FET | 900 V | 9 A | 150 W | - | 1,4 Ohm |
| 2SK1363 | N-FET | 900 V | 8 A | 90 W | - | 1,4 Ohm |
| 2SK1377 | N-FET | 500 V | 5,5 A | 40 W | - | - |
| 2SK1378 | N-FET | 400 V | 10 A | 125 W | - | 0,55 Ohm |
| 2SK1379 | N-FET | 60 V | 50 A | 150 W | - | 0,017 Ohm |
| 2SK1388 | N-FET | 30 V | 35 A | 60 W | - | 0,022 Ohm |
| 2SK1400 | N-FET | 300 V | 7 A | 50 W | - | - |
| 2SK1404 | N-FET | 600 V | 5 A | 35 W | - | 1,5 Ohm |
| 2SK1419 | N-FET | 60 V | 15 A | 25 W | - | 0,08 Ohm |
| 2SK1420 | N-FET | 60 V | 25 A |
关键词: 日本晶体 参数大全 共1条
回复 |
共1条
