| 型号 | 材料 | 最高电压 | 最大电流 | 最大功率 | 频率 | 沟道电阻 | |||||
| BDX11 | SI-NPN | 160 V | 10 A | 117 W | 0,8 MHz | - | |||||
| BDX16A | SI-PNP | 140 V | 3 A | 25 W | 800 kHz | - | |||||
| BDX20 | SI-PNP | 160 V | 10 A | 117 W | 4 MHz | - | |||||
| BDY20 | SI-NPN | 100 V | 15 A | 117 W | 1 MHz | - | |||||
| BDW22C | SI-PNP | 100 V | 10 A | 90 W | 3 MHz | - | |||||
| BDW23C | N-DARL+D | 100 V | 6 A | 50 W | - | - | |||||
| BDY29 | SI-NPN | 100 V | 30 A | 220 W | - | - | |||||
| BDX32 | SI-NPN | 1700 V | 4 A | 40 W | - | - | |||||
| BDX33C | N-DARL | 100 V | 10 A | 70 W | - | - | |||||
| BDX34C | P-DARL | 100 V | 10 A | 70 W | - | - | |||||
| BDX37 | SI-NPN | 80 V | 5 A | 15 W | - | - | |||||
| BDW42 | N-DARL | 100 V | 15 A | 85 W | - | - | |||||
| BDX44 | N-DARL+D | 90 V | 1 A | 5 W | 1,5 us | - | |||||
| BDW46 | P-DARL | 80 V | 15 A | 85 W | - | - | |||||
| BDW47 | P-DARL | 100 V | 15 A | 85 W | - | - | |||||
| BDX47 | P-DARL | 90 V | 1 A | 5 W | - | - | |||||
| BDX50 | SI-NPN | 160 V | 16 A | 150 W | 800 kHz | - | |||||
| BDW51C | SI-NPN | 100 V | 15 A | 125 W | 3 MHz | - | |||||
| BDX53C | N-DARL | 100 V | 6 A | 60 W | - | - | |||||
| BDX53F | N-DARL | 160 V | 6 A | 60 W | - | - | |||||
| BDX54C | P-DARL | 100 V | 6 A | 60 W | - | - | |||||
| BDX54F | P-DARL | 160 V | 6 A | 60 W | - | - | |||||
| BDY56 | SI-NPN | 180 V | 15 A | 115 W | 10 MHz | - | |||||
| BDY58 | SI-NPN | 160 V | 25 A | 175 W | - | - | |||||
| BDT61 | N-DARL+D | 60 V | 4 A | 50 W | 10 MHz | - | |||||
| BDT61C | N-DARL+D | 120 V | 4 A | 50 W | 10 MHz | - | |||||
| BDT61F | N-DARL+D | 60 V | 4 A | - | - | ||||||
| BDT62C | P-DARL | 120 V | 10 A | 90 W | - | - | |||||
| BDX62C | P-DARL | 120 V | 8 A | 90 W | - | - | |||||
| BDT63C | N-DARL | 120 V | 10 A | 90 W | - | - | |||||
| BDX63C | N-DARL | 140 V | 8 A | 90 W | - | - | |||||
| BDT64C | P-DARL | 120 V | 12 A | 125 W | - | - | |||||
| BDV64C | P-DARL+D | 120 V | 20 A | 125 W | - | - | |||||
| BDX64C | P-DARL | 120 V | 12 A | 117 W | - | - | |||||
| BDT65C | N-DARL | 120 V | 12 A | 125 W | - | - | |||||
| BDV65B | N-DARL+D | 100 V | 20 A | 125 W | - | - | |||||
| BDV65C | N-DARL+D | 120 V | 20 A | 125 W | - | - | |||||
| BDX65C | N-DARL | 120 V | 12 A | 117 W | - | - | |||||
| BDV66C | P-DARL+D | 120 V | 16 A | 200 W | 7 MHz | - | |||||
| BDV66D | P-DARL+D | 160 V | 16 A | 200 W | - | - | |||||
| BDX66C | P-DARL | 120 V | 16 A | 150 W | - | - | |||||
| BDX67C | N-DARL | 120 V | 16 A | 150 W | - | - | |||||
| BDX71 | SI-NPN | 70 V | 10 A | 75 W | 0,8 MHz | - | |||||
| BDY73 | SI-NPN | 100 V | 15 A | 115 W | 8 kHz | - | |||||
| BDX75 | SI-NPN | 45 V | 16 A | 75 W | 0,8 MHz | - | |||||
| BDX77 | SI-NPN | 100 V | 8 A | 60 W | 7 MHz | - | |||||
| BDW83C | N-DARL | 100 V | 15 A | 150 W | - | - | |||||
| BDW83D | N-DARL+D | 120 V | 15 A | 150 W | - | - | |||||
| BDY83B | SI-PNP | 50 V | 4 A | 36 W | 3 MHz | - | |||||
| BDW84C | P-DARL | 100 V | 15 A | 150 W | - | - | |||||
| BDW84D | P-DARL+D | 120 V | 15 A | 150 W | - | - | |||||
| BDT85A | SI-NPN | 100 V | 15 A | 125 W | 20 MHz | - | |||||
| BDT86A | SI-PNP | 100 V | 15 A | 125 W | 20 MHz | - | |||||
| BDT87 | SI-NPN | 120 V | 15 A | 125 W | 10 MHz | - | |||||
| BDX87C | N-DARL | 100 V | 12 A | 120 W | - | - | |||||
| BDT88 | SI-PNP | 120 V | 12 A | 117 W | - | - | |||||
| BDX88C | P-DARL | 100 V | 12 A | 120 W | - | - | |||||
| BDY90 | SI-NPN | 120 V | 10 A | 60 W | 0,35 us | - | |||||
| BDW93CF | N-DARL | 100 V | 12 A | 40 W | - | - | |||||
| BDW94C | P-DARL | 100 V | 12 A | 80 W | - | - | |||||
| BDX94 | SI-PNP | 80 V | 8 A | 90 W | 4 MHz | - | |||||
| BDT95A | SI-NPN | 100 V | 10 A | 90 W | 4 MHz | - | |||||
| BDX95 | SI-NPN | 100 V | 8 A | 90 W | 4 MHz | - | |||||
| BDT96A | SI-PNP | 100 V | 10 A | 90 W | 4 MHz | - | |||||
| BDX96 | SI-PNP | 100 V | 8 A | 90 W | 4 MHz | - | |||||
| BD109 | SI-NPN | 60 V | 3 A | 15 W | - | - | |||||
| BD115 | SI-NPN | 245 V | 0,15 A | 0,8 W | - | - | |||||
| BD129 | SI-NPN | 400 V | 0,5 A | 17,5 W | - | - | |||||
| BD131 | SI-NPN | 70 V | 3 A | 15 W | 60 MHz | - | |||||
| BD132 | SI-PNP | 45 V | 3 A | 15 W | 60 MHz | - | |||||
| BD139 | SI-NPN | 80 V | 1,5 A | 12,5 W | 50 MHz | - | |||||
| BD140 | SI-PNP | 80 V | 1,5 A | 12,5 W | 50 MHz | - | |||||
| BD141 | SI-NPN | 140 V | 8 A | 117 W | - | - | |||||
| BD142 | SI-NPN | 50 V | 15 A | 117 W | - | - | |||||
| BD159 | SI-NPN | 375 V | 0,5 A | 20 W | - | - | |||||
| BD160 | SI-NPN | 250 V | 5 A | 25 W | - | - | |||||
| BD179 | SI-NPN | 80 V | 3 A | 30 W | - | - | |||||
| BD180 | SI-PNP | 80 V | 3 A | 30 W | 2 MHz | - | |||||
| BD183 | SI-NPN | 85 V | 15 A | 117 W | - | - | |||||
| BD201 | SI-NPN | 60 V | 8 A | 55 W | - | - | |||||
| BD201F | SI-NPN | 60 V | 8 A | 32 W | - | - | |||||
| BD204F | SI-PNP | 60 V | 8 A | 60 W | 7 MHz | - | |||||
| BD230 | SI-NPN | 100 V | 1,5 A | 12,5 W | - | - | |||||
| BD231 | SI-PNP | 100 V | 1,5 A | 12,5 W | - | - | |||||
| BD232 | SI-NPN | 300 V | 0,25 A | 7 W | - | - | |||||
| BD237 | SI-NPN | 100 V | 2 A | 25 W | 3 MHz | - | |||||
| BD238 | SI-PNP | 100 V | 2 A | 25 W | 3 MHz | - | |||||
| BD239C | SI-NPN | 100 V | 2 A | 30 W | 3 MHz | - | |||||
| BD240 | SI-PNP | 45 V | 2 A | 30 W | - | - | |||||
| BD240C | SI-PNP | 100 V | 2 A | 30 W | 3 MHz | - | |||||
| BD241C | SI-NPN | 100 V | 3 A | 40 W | 3 MHz | - | |||||
| BD241D | SI-NPN | 120 V | 3 A | 40 W | 3 MHz | - | |||||
| BD242C | SI-PNP | 100 V | 3 A | 40 W | 3 MHz | - | |||||
| BD243C | SI-NPN | 100 V | 6 A | 65 W | 3 MHz | - | |||||
| BD243F | SI-NPN | 200 V | 6 A | 65 W | 3 MHz | - | |||||
| BD244C | SI-PNP | 100 V | 6 A | 65 W | 3 MHz | - | |||||
| BD244F | SI-PNP | 200 V | 6 A | 65 W | 3 MHz | - | |||||
| BD250C | SI-PNP | 100 V | 25 A | 125 W | 3 MHz | - | |||||
| BD277 | SI-PNP | 45 V | 7 A | 70 W | 10 MHz | - | |||||
| BD302 | SI-PNP | 60 V | 8 A | 55 W | 3 MHz | - | |||||
| BD303 | SI-NPN | 60 V | 8 A | 55 W | 3 MHz | - | |||||
| BD314 | SI-PNP | 80 V | 10 A | 150 W | - | - | |||||
| BD317 | SI-NPN | 100 V | 16 A | 200 W | 1 MHz | - | |||||
| BD318 | SI-PNP | 100 V | 16 A | 200 W | - | - | |||||
| BD329 | SI-NPN | 32 V | 3 A | 15 W | 130 MHz | - | |||||
| BD330 | SI-PNP | 32 V | 3 A | 15 W | - | - | |||||
| BD335 | N-DARL | 100 V | 6 A | 60 W | - | - | |||||
| BD336 | P-DARL | 100 V | 6 A | 60 W | - | - | |||||
| BD337 | N-DARL+D | 120 V | 6 A | 60 W | 10 MHz | - | |||||
| BD362 | SI-PNP | 32 V | 3 A | 15 W | - | - | |||||
| BD371B | SI-NPN | 60 V | 1,5 A | 2,5 W | - | - | |||||
| BD385 | SI-NPN | 60 V | 1 A | 10 W | 250 MHz | - | |||||
| BD387 | SI-NPN | 80 V | 1 A | 10 W | 250 MHz | - | |||||
| BD410 | SI-NPN | 500 V | 1 A | 20 W | - | - | |||||
| BD411 | N-DARL | 50 V | 2 A | 10 W | - | - | |||||
| BD441 | SI-NPN | 80 V | 4 A | 36 W | 3 MHz | - | |||||
| BD442 | SI-PNP | 80 V | 4 A | 36 W | 3 MHz | - | |||||
| BD515 | SI-NPN | 45 V | 2 A | 10 W | 160 MHz | - | |||||
| BD537 | SI-NPN | 80 V | 8 A | 50 W | - | - | |||||
| BD538 | SI-PNP | 80 V | 4 A | 50 W | 3 MHz | - | |||||
| BD539 | SI-NPN | 40 V | 5 A | 45 W | - | - | |||||
| BD543C | SI-NPN | 100 V | 8 A | 70 W | 3 MHz | - | |||||
| BD545 | SI-NPN | 40 V | 15 A | 85 W | 3 MHz | - | |||||
| BD637 | SI-NPN | 100 V | 2 A | 3O W | 3 MHz | - | |||||
| BD638 | SI-PNP | 100 V | 2 A | 30 W | 3 MHz | - | |||||
| BD648 | P-DARL | 80 V | 8 A | 62,5 W | - | - | |||||
| BD651 | N-DARL | 120 V | 8 A | 62,5 W | - | - | |||||
| BD652 | P-DARL | 120 V | 8 A | 62,5 W | - | - | |||||
| BD679A | N-DARL+D | 80 V | 4 A | 40 W | - | - | |||||
| BD680A | P-DARL+D | 80 V | 4 A | 40 W | - | - | |||||
| BD681 | N-DARL+D | 100 V | 4 A | 40 W | - | - | |||||
| BD682 | P-DARL+D | 100 V | 4 A | 40 W | - | - | |||||
| BD683 | N-DARL | 120 V | 4 A | 40 W | - | - | |||||
| BD684 | P-DARL | 120 V | 4 A | 40 W | - | - | |||||
| BD711 | SI-NPN | 100 V | 12 A | 75 W | - | - | |||||
| BD712 | SI-PNP | 100 V | 12 A | 75 W | - | - | |||||
| BD722 | SI-PNP | 80 V | 4 A | 36 W | 3 MHz | - | |||||
| BD743C | SI-NPN | 110 V | 15 A | 90 W | 5 MHz | - | |||||
| BD744C | SI-PNP | 110 V | 15 A | 90 W | 5 MHz | - | |||||
| BD750 | SI-PNP | 100 V | 20 A | 200 W | - | - | |||||
| BD751 | SI-NPN | 100 V | 20 A | 200 W | - | - | |||||
| BD791 | SI-NPN | 100 V | 4 A | 15 W | - | - | |||||
| BD792 | SI-PNP | 100 V | 4 A | 15 W | - | - | |||||
| BD801 | SI-NPN | 100 V | 8 A | 65 W | 3 MHz | - | |||||
| BD829 | SI-NPN | 100 V | 1 A | 8 W | - | - | |||||
| BD830 | SI-PNP | 100 V | 1 A | 8 W | 75 MHz | - | |||||
| BD839 | SI-NPN | 45 V | 1,5 A | 10 W | 125 MHz | - | |||||
| BD843 | SI-NPN | 100 V | 1,5 A | 10 W | 150 MHz | - | |||||
| BD877 | N-DARL | 80 V | 1 A | 9 W | 200 MHz | - | |||||
| BD879 | N-DARL | 100 V | 1 A | 9 W | 200 MHz | - | |||||
| BD880 | P-DARL | 100 V | 1 A | - | 200 MHz | - | |||||
| BD901 | N-DARL+D | 100 V | 8 A | 70 W | - | - | |||||
| BD902 | P-DARL | 100 V | 8 A | 70 W | - | - | |||||
| BD911 | SI-NPN | 100 V | 15 A | 90 W | - | - | |||||
| BD912 | SI-PNP | 100 V | 15 A | 90 W | - | - | |||||
| BD939F | SI-NPN | 120 V | 3 A | 19 W | 3 MHz | - | |||||
| BD941 | SI-NPN | 140 V | 3 A | 30 W | 3 MHz | - | |||||
| BD942 | SI-PNP | 140 V | 3 A | 30 W | 3 MHz | - | |||||
| BD943 | SI-NPN | 22 V | 5 A | 40 W | 3 MHz | - | |||||
| BD948 | SI-PNP | 45 V | 5 A | 40 W | 3 MHz | - | |||||
| BD951 | SI-NPN | 80 V | 5 A | 40 W | 3 MHz | - | |||||
| BD956 | SI-PNP | 120 V | 5 A | 40 W | 3 MHz | - | |||||
| BD139-16 |
关键词: 欧洲晶体 参数大全 共1条
共1条
