| 型号 | 材料 | 最高电压 | 最大电流 | 最大功率 | 频率 | 沟道电阻 |
| Type nummer | Soort | Maximale spanning | Maximale stroom | Maximaal vermogen | Frequentie Schakeltijd | AAN weerstand |
| BFQ10 | N-FET | 30 V | 30 mA | 250 mW | - | - |
| BFW10 | N-FET | 30 V | 20 mA | - | - | - |
| BFW11 | N-FET | 30 V | 10 mA | - | - | - |
| BFW12 | N-FET | 30 V | 5 mA | - | - | - |
| BFW16A | SI-NPN | 25 V | 0,3 A | 1,5 W | 1,2 GHz | - |
| BFS17 | SI-NPN | 15 V | 25 mA | - | 1 GHz | - |
| BFW17A | SI-NPN | 25 V | 0,3 A | 1,5 W | 1,1 GHz | - |
| BFS19 | SI-NPN | 30 V | 30 mA | - | 260 MHz | - |
| BFS20 | SI-NPN | 30 V | 25 mA | - | 450 MHz | - |
| BFS22A | SI-NPN | 3 V | 0,75 A | 4 W | 175 MHz | - |
| BFS23A | SI-NPN | 36 V | 0,5 A | 4,5 W | 500 MHz | - |
| BFT25 | SI-NPN | 8 V | 6,5 mA | 50 mW | 500 MHz | - |
| BFR29 | N-FET | 30 V | 10 mA | - | - | - |
| BFW30 | SI-NPN | 10 V | 0,1 A | 0,25 W | 1,6 GHz | - |
| BFQ33C | SI-NPN | 7 V | 20 mA | 0,14 W | 12,5 GHz | - |
| BFQ34 | SI-NPN | 18 V | 0,15 A | 2,7 W | 4 GHz | - |
| BFX34 | SI-NPN | 60 V | 5 A | 0,87 W | - | - |
| BFR35A | SI-NPN | 12 V | 30 mA | - | 4,9 GHz | - |
| BFR36 | SI-NPN | 40 V | 200 mA | 0,8 W | 1,3 GHz | - |
| BFR37 | SI-NPN | 30 V | 50 mA | 0,25 W | 1,4 GHz | - |
| BFX37 | SI-PNP | 90 V | 0,1 A | 0,36 W | 70 MHz | - |
| BFR38 | SI-PNP | 40 V | 20 mA | 0,2 W | 1 GHz | - |
| BFX38 | SI-PNP | 55 V | 1 A | 0,8 W | - | - |
| BFR39 | SI-NPN | 90 V | 1 A | 0,8 W | 100 MHz | - |
| BFY39 | SI-NPN | 45 V | 0,1 A | 0,3 W | 150 MHz | - |
| BFR40 | SI-NPN | 70 V | 1 A | 0,8 W | 100 MHz | - |
| BFX40 | SI-PNP | 75 V | 1 A | 0,8 W | - | - |
| BFQ43 | SI-NPN | 18 V | 1,2 A | 4 W | 175 MHz | - |
| BFT43 | SI-NPN | 100 V | 1 A | 0,8 W | - | - |
| BFW43 | SI-PNP | 150 V | 0,1 A | 0,4 W | 150 MHz | - |
| BFW44 | SI-PNP | 150 V | 0,1 A | 0,7 W | 50 MHz | - |
| BFT45 | SI-PNP | 250 V | 0,5 A | 0,75 W | 70 MHz | - |
| BFX48 | SI-PNP | 30 V | 0,1 A | 0,36 W | - | - |
| BFY50 | SI-NPN | 80 V | 1 A | 0,7 W | - | - |
| BFY51 | SI-NPN | 60 V | 1 A | 0,7 W | - | - |
| BFY52 | SI-NPN | 40 V | 1 A | 0,8 W | 100 MHz | - |
| BFX55 | SI-NPN | 60 V | 0,4 A | 2,2 W | 700 MHz | - |
| BFY56 | SI-NPN | 60 V | 1 A | 0,8 W | - | - |
| BFY64 | SI-PNP | 40 V | 0,6 A | 0,7 W | - | - |
| BFG65 | SI-NPN | 10 V | 50 mA | 0,3 W | 8 GHz | - |
| BFQ65 | SI-NPN | 10 V | 50 mA | 0,3 W | 8 GHz | - |
| BFT66 | SI-NPN | 15 V | 30 mA | - | 4,5 GHz | - |
| BFQ68 | SI-NPN | 18 V | 0,3 A | 4,5 W | 4 GHz | - |
| BFR79 | SI-PNP | 90 V | 1 A | 0,8 W | 100 MHz | - |
| BFT79 | SI-PNP | 90 V | 1 A | 0,8 W | 100 MHz | - |
| BFR84 | N-FET-DG | 20 V | 50 mA | 0,3 W | - | - |
| BFX85 | SI-NPN | 100 V | 1 A | 0,8 W | - | - |
| BFY88 | SI-NPN | 25 V | 25 mA | - | 850 MHz | - |
| BFX89 | SI-NPN | 15 V | 50 mA | 0,2 W | 1,3 GHz | - |
| BFR90 | SI-NPN | 15 V | 30 mA | - | 5 GHz | - |
| BFR90A | SI-NPN | 15 V | 30 mA | - | 5,5 GHz | - |
| BFY90 | SI-NPN | 15 V | 25 mA | - | 2 GHz | - |
| BFR91 | SI-NPN | 12 V | 50 mA | - | 5 GHz | - |
| BFR91A | SI-NPN | 12 V | 50 mA | - | 6 GHz | - |
| BFR92 | SI-NPN | 15 V | 30 mA | - | 5 GHz | - |
| BFR92A | SI-NPN | 15 V | 30 mA | - | 5,5 GHz | - |
| BFR92R | SI-NPN | 15 V | 30 mA | - | 5 GHz | - |
| BFW92 | SI-NPN | 15 V | 50 mA | 0,3 W | 1,6 GHz | - |
| BFW92A | SI-NPN | 15 V | 25 mA | - | 3,2 GHz | - |
| BFR93A | SI-NPN | 15 V | 50 mA | - | 6 GHz | - |
| BFG94 | SI-NPN | 15 V | 60 mA | 0,7 W | - | - |
| BFR95 | SI-NPN | 25 V | 0,15 A | 1,5 W | 3,5 GHz | - |
| BFT95 | SI-PNP | UHF | 15 V | 25 mA | 3,6 GHz | - |
| BFG96 | SI-NPN | 20 V | 75 mA | 0,7 W | 800 MHz | - |
| BFR96 | SI-NPN | 15 V | 75 mA | - | 5 GHz | - |
| BFR96S | SI-NPN | 15 V | 0,1 A | - | 5,5 GHz | - |
| BFG97 | SI-NPN | 20 V | 0,1 A | 0,5 W | - | - |
| BF115 | SI-NPN | 50 V | 30 mA | 0,15 W | - | - |
| BF120 | SI-NPN | 220 V | 50 mA | 0,3 W | - | - |
| BFG135 | SI-NPN | 25 V | 0,15 A | 1 W | - | - |
| BF152 | SI-NPN | 30 V | 0,2 W | - | 800 MHz | - |
| BF155 | SI-NPN | 40 V | 20 mA | - | 600 MHz | - |
| BF161 | SI-NPN | 50 V | 20 mA | - | 550 MHz | - |
| BFQ162 | SI-NPN | 20 V | 0,5 A | 3 W | 1 GHz | - |
| BF163 | SI-NPN | 40 V | 20 mW | - | 600 MHz | - |
| BF164 | SI-NPN | 40 V | 0,2 W | - | 600 MHz | - |
| BF166 | SI-NPN | 40 V | 20 mA | 0,175 W | 500 MHz | - |
| BF173 | SI-NPN | 40 V | 25 mA | 0,23 W | 600 MHz | - |
| BF180 | SI-NPN | 30 V | 20 mA | 0,15 W | 675 MHz | - |
| BF182 | SI-NPN | 25 V | 20 mA | - | 650 MHz | - |
| BF184 | SI-NPN | 20 V | 30 mA | - | 260 MHz | - |
| BF186 | SI-NPN | 190 V | 0,06 A | 0,8 W | 120 MHz | - |
| BF189 | SI-NPN | 30 V | 25 mA | - | 270 MHz | - |
| BF195 | SI-NPN | 30 V | 30 mA | 0,22 W | 200 MHz | - |
| BFG198 | SI-NPN | 20 V | 0,1 A | 1 W | 8 GHz | - |
| BF199 | SI-NPN | 40 V | 25 mA | 0,3 W | 550 MHz | - |
| BF200 | SI-NPN | 30 V | 20 mA | 0,15 W | 500 MHz | - |
| BF224 | SI-NPN | 45 V | 50 mA | 0,25 W | 450 MHz | - |
| BFQ232 | SI-NPN | 100 V | 0,3 A | - | 1 GHz | - |
| BFQ232A | SI-NPN | 115 V | 0,3 A | - | 800 MHz | - |
| BFQ235A | SI-NPN | 115 V | 0,3 A | 3 W | 800 MHz | - |
| BF240 | SI-NPN | 40 V | 25 mA | 0,25 W | 400 MHz | - |
| BF244A | N-FET | 30 V | 25 mA | 0,3 W | - | - |
| BF244C | N-FET | 30 V | 25 mA | 0,3 W | - | - |
| BF245A | N-FET | 30 V | 25 mA | 0,3 W | - | - |
| BF245B | N-FET | 30 V | 25 mA | 0,3 W | - | - |
| BF245C | N-FET | 30 V | 0,1 A | 0,3 W | 170 MHz | - |
| BF246C | N-FET | 25 V | 25 mA | 0,25 W | - | - |
| BF247B | N-FET | 25 V | 25 mA | 0,25 W | - | - |
| BF247C | N-FET | 25 V | 25 mA | 0,25 W | - | - |
| BFQ252 | SI-PNP | 100 V | 0,3 A | 3 W | - | - |
| BFQ252A | SI-PNP | 115 V | 0,3 A | - | 800 MHz | - |
| BF253 | SI-NPN | 30 V | 30 mA | - | 150 MHz | - |
| BF254 | SI-NPN | 30 V | 30 mA | 0,22 W | 260 MHz | - |
| BF255 | SI-NPN | 20 V | 30 mA | 0,22 W | 200 MHz | - |
| BFQ255 | SI-PNP | 100 V | 0,3 A | 3 W | 1 GHz | - |
| BFQ255A | SI-PNP | 115 V | 0,3 A | 3 W | 800 MHz | - |
| BF256A | N-FET | 30 V | 7 mA | - | - | - |
| BF256B | N-FET | 30 V | 13 mA | - | - | - |
| BF256C | N-FET | 30 V | 10 mA | 0,25 W | - | - |
| BF259 | SI-NPN | 300 V | 0,1 A | 0,8 W | 90 MHz | - |
| BF259S | SI-NPN | 300 V | 0,1 A | 0,8 W | 90 MHz | - |
| BFQ262 | SI-PNP | 100 V | 0,4 A | 5 W | 1 GHz | - |
| BFQ262A | SI-PNP | 115 V | 0,4 A | 5 W | 800 MHz | - |
| BF271 | SI-NPN | 40 V | 30 mA | 240 mW | 1 GHz | - |
| BF299 | SI-NPN | 300 V | 0,1 A | 0,625 W | - | - |
| BF324 | SI-PNP | 30 V | 25 mA | 0,25 W | 450 MHz | - |
| BF343 | SI-PNP | 35 V | 35 mA | 0,25 W | 80 MHz | - |
| BF357 | SI-NPN | 30 V | 0,05 A | - | 1,6 GHz | - |
| BF370 | SI-NPN | 40 V | 0,1 A | 0,5 W | 500 MHz | - |
| BF377 | SI-NPN | 15 V | 25 mA | - | 1,3 GHz | - |
| BF393 | SI-NPN | 300 V | 0,5 A | 0,65 W | - | - |
| BF410B | N-FET | 20 V | 0,7 mA | - | - | - |
| BF410C | N-FET | 20 V | 12 mA | - | - | - |
| BF411 | SI-NPN | 110 V | 0,05 A | 0,3 W | - | - |
| BF417 | SI-NPN | 300 V | 0,2 A | 6 W | 50 MHz | - |
| BF418 | SI-PNP | 300 V | 0,2 A | 6 W | 50 MHz | - |
| BF419 | SI-NPN | 300 V | 0,1 A | 6 W | - | - |
| BF420 | SI-NPN | 300 V | 0,1 A | 0,83 W | - | - |
| BF421 | SI-PNP | 300 V | 0,1 A | 0,83 W | - | - |
| BF424 | SI-PNP | 30 V | 25 mA | - | 300 MHz | - |
| BF435 | SI-PNP | 160 V | 0,2 A | 0,625 W | 80 MHz | - |
| BF440 | SI-PNP | 40 V | 25 mA | - | 250 MHz | - |
| BF441B | SI-PNP | 40 V | 25 mA | - | 250 MHz | - |
| BF450 | SI-PNP | 40 V | 25 mA | 0,25 W | 375 MHz | - |
| BF459 | SI-NPN | 300 V | 0,1 A | 10 W | 90 MHz | - |
| BF462 | SI-NPN | 350 V | 0,5 A | 10 W | 45 MHz | - |
| BF471 | SI-NPN | 300 V | 0,1 A | 2 W | 60 MHz | - |
| BF472 | SI-PNP | 300 V | 30 mA | 2 W | 60 MHz | - |
| BF479 | SI-PNP | 30 V | 50 mA | 0,16 W | 1,4 GHz | - |
| BF487 | SI-NPN | 400 V | 0,05 A | 0,83 W | - | - |
| BF493 | SI-PNP | 300 V | 0,5 A | 0,625 W | - | - |
| BF494 | SI-NPN | 20 V | 30 mA | - | 260 MHz | - |
| BF495C | SI-NPN | 30 V | 30 mA | 0,3 W | 200 MHz | - |
| BF496 | SI-NPN | 30 V | 20 mA | 0,3 W | 550 MHz | - |
| BF506 | SI-PNP | 40 V | 30 mA | 0,3 W | 550 MHz | - |
| BF507 | SI-NPN | 30 V | 20 mA | 0,5 W | 750 MHz | - |
| BF509 | SI-PNP | 40 V | 30 mA | 0,3 W | 750 MHz | - |
| BF516 | SI-PNP | 35 V | 20 mA | - | 850 MHz | - |
| BF569 | SI-PNP | 40 V | 30 mA | 280 mW | 850 MHz | - |
| BF585 | SI-NPN | 350 V | 0,05 A | 5 W | 70 MHz | - |
| BF587 | SI-NPN | 400 V | 0,05 A | 5 W | 70 MHz | - |
| BF622 | SI-NPN | 250 V | 0,1 A | 2 W | - | - |
| BF679 | SI-PNP | 40 V | 30 mA | 0,16 W | 880 MHz | - |
| BF680 | SI-PNP | 40 V | 30 mA | 0,16 W | 750 MHz | - |
| BF689 | SI-NPN | 15 V | 25 mA | 0,2 W | 1 GHz | - |
| BF689K | SI-NPN | 25 V | 25 mA | 0,36 W | 0,2 GHz | - |
| BF758 | SI-NPN | 300 V | 0,5 A | 2 W | - | - |
| BF759 | SI-NPN | 350 V | 0,5 A | 10 W | - | - |
| BF763 | SI-NPN | 15 V | 25 mA | 0,36 W | 1,8 GHz | - |
| BF770A | SI-NPN |
关键词: 欧洲晶体 参数大全 共1条
回复 |
共1条
