电子产品世界 » 论坛首页 » 综合技术 » 基础知识 » 爱华((AIWA)HS-JS215型随身听集成电路工作参数
2014-06-12 10:38:08     打赏
1.TA8155F工作参数
引
脚
工作电压(V)在路电阻(kΩ)引
脚
工作电压(V)在路电阻(kΩ)引
脚
工作电压(V)在路电阻(kΩ)引
脚
工作电压(V)在路电阻(kΩ)
FMAMPLAYR测B测FMAMPLAYR测B测FMAMPLAYR测B测FMAMPLAYR测B测
12.62.62.34.36.470.10.10.35.59.0130.50.50.56.09.2190005.47.5
20.60.60.66.011.580.60.550.95.910.5140.50.50.56.08.72000000
30.60.60.66.010.590.550.550.95.910.5152.62.600.50.7210005.47.0
40.850.850.855.88.4100.10.10.35.58.8160.20.20.185.89.0220006.27.4
50.850.850.855.88.0110.1006.05.3170.20.150.185.89.0232.62.62.34.36.5
60.850.850.855.67.5122.62.62.34.36.4180.0500.056.27.5240005.78.5
2.TA7688F工作参数
引
脚
工作电压(V)在路电阻(kΩ)引
脚
工作电压(V)在路电阻(kΩ)引
脚
工作电压(V)在路电阻(kΩ)引
脚
工作电压(V)在路电阻(kΩ)
11.651.581.354.45.050006.17.593.13.12.71.01.1133.13.12.71.01.1
21.721.681.455.56.162.62.42.154.44.7101.81.751.555.56.8141.71.421.425.25.8
31.721.671.455.25.871.81.751.505.57.2112.72.62.34.46.4151.71.451.455.36.2
41.651.61.404.04.6800000122.42.351.955.57.5161.651.351.354.04.5
3.TA8122F工作参数
引
脚
工作电压(V)在路电阻(kΩ)引
脚
工作电压(V)在路电阻(kΩ)引
脚
工作电压(V)在路电阻(kΩ)引
脚
工作电压(V)在路电阻(kΩ)
FMAMR测B测FMAMR测B测FMAMR测B测FMAMR测B测
10.800.951.172.62.73.83.9130.90.854.34.5191.50.755.37.8
2000082.62.750.91.0140.90.94.34.5202.52.70.50.6
31.31.95.27.590000151.81.95.26.3212.12.555.67.4
41.31.95.27.510005.8∞161.12.755.57.8222.62.650.50.6
51.151.25.57.5110.505.2∞172.62.755.67.0232.62.650.50.6
62.652.80.50.7121.751.955.87.2180.450.45.97.5242.52.603.83.9
注:上述参数均是由指针式500型万用表测得的,“R”表示黑表笔接地,用红表笔测各引脚的电阻值;“B”表示红表笔接地,用黑表笔测各引脚的电阻值
关键词: 爱华((     工作参数
