电子产品世界 » 论坛首页 » 嵌入式开发 » FPGA » FFT C语言实现
FFT C语言实现
2014-08-15 14:09:23     打赏
最近在做传感信号处理遇到了循环相关问题,快速循环相关算法,先将两组信号FFT变换到频域,进行复数乘积,再IFFT逆变回来即可。傅立叶变换是信号处理的基本模块,这里将这段代码拿出来分享一下,希望对同行有所用。
Dit2FFT.c文件
*File name        : dit2fft.c
*Deion    : FFT calculation. Decimation in time FFT, radix-2.
*Current version: v2.3 -- get a simple version, remove unnecessary code
*History version:
*                 v2.2 -- modify the sin/cos table data, and the static
*                 v2.1 -- modify the  name
*                 v2.0 -- separate the bit-reverse block
*                  v1.9 -- rewrite the bit-reverse block
*                 v1.8 -- rewrite the twiddle factor generation, and test fft,ifft
*                  v1.7 -- fix the twiddle factor bug, and test the four
*                          combinations
*                  v1.6 -- adjust the DIT2_FLOAT to DIT2_FLOAT32
*                 v1.5 -- change DIT2_UINT16 to DIT2_UINT, and extend its scope
*                 v1.4 -- change the name of s
*                 v1.3 -- add the sin/cos table
*                   v1.2 -- add ifft
*                  v1.1 -- add bit-reverse in-place
*                  v1.0 -- achieve the basic  of FFT
*Author            : Wiracle
*Date            :2008-10-23
/*inlcude the head file*/
/* the NULL define needed*/
//#include <stdlib.h>
* caculate the magnitude and phase
* -- sqrt()
* -- atan()
#include <math.h>
#include "Alg_Dit2FFT.h"
/*the sin(x)/cos(x) table*/
DIT2_FLOAT sin_table[21] = {
0.0,                   // sin(-2*pi/(2^0))
0.0,                   // sin(-2*pi/(2^1))
-1.0,                   // sin(-2*pi/(2^2))
-0.70710678118655,       // sin(-2*pi/(2^3))
-0.38268343236509,       // sin(-2*pi/(2^4))
-0.19509032201613,       // sin(-2*pi/(2^5))
-0.09801714032956,       // sin(-2*pi/(2^6))
-0.04906767432742,       // sin(-2*pi/(2^7))
-0.02454122852291,       // sin(-2*pi/(2^8))
-0.01227153828572,       // sin(-2*pi/(2^9))
-0.00613588464915,       // sin(-2*pi/(2^10))
-0.00306795676297,       // sin(-2*pi/(2^11))
-0.00153398018628,       // sin(-2*pi/(2^12))
-0.00076699031874,       // sin(-2*pi/(2^13))
-0.00038349518757,       // sin(-2*pi/(2^14))
-0.00019174759731,       // sin(-2*pi/(2^15))
-0.00009587379910,       // sin(-2*pi/(2^16))
-0.00004793689960,       // sin(-2*pi/(2^17))
-0.00002396844981,       // sin(-2*pi/(2^18))
-0.00001198422491,       // sin(-2*pi/(2^19))
-0.00000599211245       // sin(-2*pi/(2^20))
DIT2_FLOAT cos_table[21] = {
1.0,                   //cos(-2*pi/(2^0))
-1.0,                   //cos(-2*pi/(2^1))
0.0,                   //cos(-2*pi/(2^2))
0.70710678118655,       //cos(-2*pi/(2^3))
0.92387953251129,       //cos(-2*pi/(2^4))
0.98078528040323,       //cos(-2*pi/(2^5))
0.99518472667220,       //cos(-2*pi/(2^6))
0.99879545620517,       //cos(-2*pi/(2^7))
0.99969881869620,       //cos(-2*pi/(2^8))
0.99992470183914,       //cos(-2*pi/(2^9))
0.99998117528260,       //cos(-2*pi/(2^10))
0.99999529380958,       //cos(-2*pi/(2^11))
0.99999882345170,       //cos(-2*pi/(2^12))
0.99999970586288,       //cos(-2*pi/(2^13))
0.99999992646572,       //cos(-2*pi/(2^14))
0.99999998161643,       //cos(-2*pi/(2^15))
0.99999999540411,       //cos(-2*pi/(2^16))
0.99999999885103,       //cos(-2*pi/(2^17))
0.99999999971276,       //cos(-2*pi/(2^18))
0.99999999992819,       //cos(-2*pi/(2^19))
0.99999999998205       //cos(-2*pi/(2^20))
static DIT2_UINT DIT2_Idx(DIT2_UINT in);
* name  : DIT2_Rvs
*Input          : DIT2_FFT pointer
*Deion    : Bitreverse the input data, including real and imag part
*    typedef  struct DIT2_FFT_STRUCT
*        DIT2_FLOAT *real_in;    --input and output buffer
*        DIT2_FLOAT *imag_in;    --input and output buffer(can be NULL)
*        DIT2_FLOAT *real_out;      --unused
*        DIT2_FLOAT *imag_out;      --unused
*        DIT2_FLOAT *mag;           --unused
*        DIT2_FLOAT *phase;         --unused
*        DIT2_UINT size;         --the FFT size, must be 2^N
*        DIT2_UINT stage;           --unused
*        DIT2_UINT transform;       --unused
*    }DIT2_FFT;
#pragma CODE_SECTION(DIT2_Rvs,"ramfuncs");
void DIT2_Rvs(DIT2_FFT *fft)
    DIT2_UINT i,j,k,n;
    DIT2_FLOAT tw_real,tw_imag;
    /*para check*/
    if ((fft->real_in == NULL) || (fft->imag_in == NULL))
        while (1);
* 1.loop along the array -- i
* 2.find the bit-reversed index -- k
* 3.check if i < k, if so, swap the X and X[k]
    for (i = 0; i < fft->size; i++)
        k = 0;
        n = i;
        for (j = 0; j < fft->stage; j++)
            k = (k<<1) | (n&1);
            n >>= 1;
        if (i < k)
            tw_real = fft->real_in;
            tw_imag = fft->imag_in;
            fft->real_in = fft->real_in[k];
            fft->imag_in = fft->imag_in[k];
            fft->real_in[k] = tw_real;
            fft->imag_in[k] = tw_imag;
* name  : DIT2_Fft
*Input          : DIT2_FFT *fft
*Deion    : used when uncommenting DIT2_BIT_INVERSE_IN_PLACE which achives
*                 the bit-reversed in-place. As the following, the real part of
*                 the inputsequence buffer is pointed by real_in, where the
*                 output--magnitude info is also in. The imaginary part of the
*                 input sequence buffer is pointed by image_in, where the output--
*                 phase info is alse in.
*        DIT2_UINT stage;     --N
*        DIT2_UINT transform; --DIT2_FORWARD_TRANSFORM or DIT2_INVERSE_TRANSFORM
*    }DIT2_FFT;
#pragma CODE_SECTION(DIT2_Fft,"ramfuncs");
void DIT2_Fft(DIT2_FFT *fft)
    DIT2_UINT i,j,k,n;
    DIT2_UINT block_size,block_end;
    DIT2_FLOAT cos1,sin1,cos2,sin2;
    DIT2_FLOAT tw_real,tw_imag;    //temperary t-w
    DIT2_INT16 ang_factor;
    /*para check*/
    if ((fft->imag_in == NULL) || (fft->real_in == NULL))
        while (1);
    /*transform direction*/
    switch (fft->transform)
        case DIT2_FORWARD_TRANSFORM:
            ang_factor = DIT2_FORWARD_TRANSFORM;
            break;
        case DIT2_INVERSE_TRANSFORM:
            ang_factor = DIT2_INVERSE_TRANSFORM;
            break;
        default:
            break;
    /*fft*/
    block_end = 1;
* The external loop:
*    find the cos(t-w)/sin(t-w) -- t-w = -2*pi/N
    for (block_size = 2; block_size <= fft->size; block_size <<= 1)
        i = DIT2_Idx(block_size);
        cos1 = cos_table;
        sin1 = sin_table;
        if (ang_factor == DIT2_INVERSE_TRANSFORM)
            sin1 = -sin1;
* prepare the first t-w
        for (i = 0; i < fft->size; i += block_size)
            cos2 = 1;//cos(0)
            sin2 = 0;//sin(0)
            for (j = i, n = 0; n < block_end; j++, n++)
                k = j + block_end;
                tw_real = fft->real_in[k]*cos2 - fft->imag_in[k]*sin2;
                tw_imag = fft->real_in[k]*sin2 + fft->imag_in[k]*cos2;
                /*lower elem*/
                fft->real_in[k] = fft->real_in[j] - tw_real;
                fft->imag_in[k] = fft->imag_in[j] - tw_imag;
                /*uper elem*/
                fft->real_in[j] = fft->real_in[j] + tw_real;
                fft->imag_in[j] = fft->imag_in[j] + tw_imag;
                /*adjust cos(t-w)/sin(t-w)*/
                tw_real = cos2*cos1 - sin2*sin1;//cos(n+1) = cos(n)cos(1) - sin(n)sin(1)
                tw_imag = cos2*sin1 + sin2*cos1;//sin(n+1) = sin(n)cos(1) + sin(1)cos(n)
                cos2 = tw_real;//cos2 = cos(n+1)
                sin2 = tw_imag;//sin2 = sin(n+1)
        block_end  = block_size;
    /*inverse transform*/
    if (fft->transform == DIT2_INVERSE_TRANSFORM)
            fft->real_in /= fft->size;
            fft->imag_in /= fft->size;
    return;
* name  : DIT2_Mag
*Deion    : calculate the magnitude and phase info of the output sequence,
*                 used when uncommenting the MACROA--
*                #define DIT2_BIT_INVERSE_IN_PLACE
*        DIT2_FLOAT *real_in;   --output magnitude info
*        DIT2_FLOAT *imag_in;   --output phase info
*    }DIT2_FFT;
#pragma CODE_SECTION(DIT2_Mag,"ramfuncs");
void DIT2_Mag(DIT2_FFT *fft)
    DIT2_UINT i;
    DIT2_FLOAT  mag,rad;
    /*para check*/
    if ((fft->real_in == NULL) ||(fft->imag_in == NULL))
        while (1);
        mag = sqrt(fft->real_in * fft->real_in + fft->imag_in * fft->imag_in);
        rad = atan2(fft->imag_in,fft->real_in);
        fft->real_in = mag*2.0/fft->size;
        fft->imag_in = rad;
    fft->real_in[0] /= 2.0;
    return;
* name  : DIT2_Idx
*Input          : DIT2_UINT in -- the blocksize value
*Output         : the index in sin_table/cos_table
*Deion    : calculate the index in sin_table/cos_table to lookup the table
*                 according the current blocksize. Only used when uncomment the
*                 MACRO--#define DIT2_SIN_COS_TABALE
#pragma CODE_SECTION(DIT2_Idx,"ramfuncs");
    DIT2_UINT i;
    for (i=0; ; i++)
        if (in & (1 << i))
            return(i);
Dit2FFT.h文件
*File name        : Alg_Dit2FFT.h
*History version:
*                          combinations
*                   v1.2 -- add ifft
*Author            : Wiracle
*Date            :2008-10-23
#ifndef _ALG_DIT2FFT_H_
#define _ALG_DIT2FFT_H_
//#include "App_TypeDefDataStruct.h"
typedef  unsigned int       DIT2_UINT16;
typedef  int                DIT2_INT16;
typedef  unsigned long      DIT2_UINT32;
typedef  long               DIT2_INT32;
typedef  long long          DIT2_INT64;
typedef  unsigned long long DIT2_UINT64;
typedef  float              DIT2_FLOAT32;
typedef  long double        DIT2_FLOAT64;
/*config the type used */
typedef  DIT2_FLOAT32       DIT2_FLOAT;
typedef  DIT2_UINT32        DIT2_UINT;
typedef  DIT2_INT32         DIT2_INT;
//FFT运算数据结构
typedef struct st_DIT2_FFT
    DIT2_FLOAT32 *real_in;    //input and output buffer
    DIT2_FLOAT32 *imag_in;    //input and output buffer
    DIT2_UINT16 size;    //FFT size ,must be 2^N
    DIT2_UINT16 stage;    //蝶形次数
    DIT2_UINT16 transform; //0: FFT运算  1:IFFT运算
}DIT2_FFT;
/*choose the FFT direction*/
#define DIT2_FORWARD_TRANSFORM 0U
#define DIT2_INVERSE_TRANSFORM 1U
//#include "..\Sources_Application\App_TypeDefDataStruct.h"
extern DIT2_FLOAT sin_table[];
extern DIT2_FLOAT cos_table[];
* name  : DIT2_Rvs
extern void DIT2_Rvs(DIT2_FFT *fft);
* name  : DIT2_Fft
*Deion    : Calculate the FFT or IFFT
extern void DIT2_Fft(DIT2_FFT *fft);
* name  : DIT2_Mag
extern void DIT2_Mag(DIT2_FFT *fft);
#endif // end of #ifndef _ALG_DIT2FFT_H_
app_main.c  文件
// TI File $Revision: /main/14 $
// Checkin $Date: April 21, 2008   15:41:07 $
#include "DSP28x_Project.h"     // Device Headerfile and Examples Include File
#include "SoftTimer.h"
#include "stdlib.h"
#define PI 3.1415926
// Prototype statements for s found within this file.
interrupt void cpu_timer1_isr(void);
SOFT_TIMER_LINK timer_1;
SOFT_TIMER_LINK timer_2;
#pragma DATA_SECTION(sig_real,"ZONE7DATA");
float sig_real[8192];
#pragma DATA_SECTION(sig_imag,"ZONE7DATA");
float sig_imag[8192];
DIT2_FFT dit2_fft;
void init_fft(void);
void init_ifft(void);
void main(void)
    init_fft();
    DIT2_Rvs(&dit2_fft);
    DIT2_Fft(&dit2_fft);
    //DIT2_Mag(&dit2_fft);
    init_ifft();
    for(;;)
void init_fft(void)
    int i;
    float omg_o;
    dit2_fft.real_in = sig_real;
    dit2_fft.imag_in = sig_imag;
    dit2_fft.transform = 1;
    dit2_fft.size = 8192;
    dit2_fft.stage = 13;
    omg_o = 2*PI/dit2_fft.size;
    for(i=0;i<dit2_fft.size;i++)
        sig_real = sin(2*omg_o*i) + 2*sin(50*omg_o*i);// + 4*sin(100*omg_o*i)+ 8*sin(1000*omg_o*i) ;
        sig_imag = 0;
    dit2_fft.transform = 0;
// No more.
