电子产品世界 » 论坛首页 » 高校专区 » 漓东e学堂 » 24号的作业本KEIL 的安装
共11条 1/2 1 2 › 跳转至页
24号的作业本KEIL 的安装
2014-10-23 10:20:36     打赏
2014-10-24 09:10:44     打赏
1.      @file    GPIO/IOToggle/main.c
2.        * @author  MCD Application Team
3.        * @version V3.5.0
4.        * @date    08-April-2011
5.        * @brief   Main program body.
6.        ******************************************************************************
7.        * @attention
8.        *
9.        * THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
10.    * WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE
11.    * TIME. AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY
12.    * DIRECT, INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING
13.    * FROM THE CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE
14.    * CODING INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
15.  * <h2><center>&copy; COPYRIGHT 2011 STMicroelectronics</center></h2>
16.
1.      /* Includes ------------------------------------------------------------------*/
2.      #include "stm32f10x.h"
3.      #include "stm32_eval.h"
4.      GPIO_InitTypeDef GPIO_InitStructure;//定义了一个初始化结构体,其中包括端口引脚、速度、模式
5.
6.      void RCC_Configuration(void)
7.      {
8.        RCC_DeInit();
9.
10.    RCC_HSICmd(ENABLE);//时钟使能配置
11.    while(RCC_GetFlagStatus(RCC_FLAG_HSIRDY) == RESET);//检查制定的RCC标志位设置与否
12.
13.    RCC_SYSCLKConfig(RCC_SYSCLKSource_HSI);//时钟源相关配置
14.
15.    RCC_HSEConfig(RCC_HSE_OFF);
16.    RCC_LSEConfig(RCC_LSE_OFF);
17.    RCC_PLLConfig(RCC_PLLSource_HSI_Div2,RCC_PLLMul_9); //  72HMz
18.    RCC_PLLCmd(ENABLE);//使能PLL
19.    while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET);
20.    RCC_ADCCLKConfig(RCC_PCLK2_Div4);
21.    RCC_PCLK2Config(RCC_HCLK_Div1);//设置高速AHB时钟
22.    RCC_PCLK1Config(RCC_HCLK_Div2);//设置低速AHB时钟
23.    RCC_HCLKConfig(RCC_SYSCLK_Div1);//设置AHB时钟
24.    RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
25.    while(RCC_GetSYSCLKSource() != 0x08);//PLL作为系统时钟
26.      RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD|RCC_APB2Periph_AFIO, ENABLE);
27.   GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);//disable JTAG
28.    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;//选择配置的引脚
29.    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
30.    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
31.    GPIO_Init(GPIOD, &GPIO_InitStructure);
32.      GPIO_ResetBits(GPIOD,GPIO_Pin_2);
33.  }
34.
35.  void GPIO_INIT()
36.  {
37.  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);
38.    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;//选择PIN0-PIN7
39.    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
40.    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;//引脚推拉输出
41.    GPIO_Init(GPIOC, &GPIO_InitStructure);//初始化
42.  }
43.
44.  void delay_us(u32 n)
45.  {
46.      u8 j;
47.      while(n--)
48.      for(j=0;j<10;j++);
49.  }
50.
51.  void  delay_ms(u32 n)
52.  {
53.      while(n--)
54.      delay_us(1000);
55.  }
2014-10-30 23:53:41     打赏
  7.   * @attention
  8.   *
  15.   *
  16.   * <h2><center>&copy; COPYRIGHT 2011 STMicroelectronics</center></h2>
  17.   ******************************************************************************
  18.   */
  19.
  20. /* Includes ------------------------------------------------------------------*/
  21. #include "stm32f10x.h"
  22. #include "stm32_eval.h"
  23. GPIO_InitTypeDef GPIO_InitStructure;
    5.
    7. {
    8.   RCC_DeInit();
    9.
    12.
    14.
    33.
    34. }
    35. void chushihua()
    36. {
    37.         //按键初始化
    38.     RCC_Configuration();
    39.     RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);
    40.   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;
    41.   GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
    42.   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
    43.     GPIO_Init(GPIOC, &GPIO_InitStructure);
    44.     //数码管初始化
    45.     RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);
    46.   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14|GPIO_Pin_15;
    47.   GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
    48.   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
    49.   GPIO_Init(GPIOB, &GPIO_InitStructure);
    50.     GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14);
    51.
    52.
    53. }
    54. void delay_us(u32 n)    //延时函数
    55. {
    56.     u8 j;
    57.     while(n--)
    58.     for(j=0;j<10;j++);
    59. }
    60.
    61. void  delay_ms(u32 n)
    62. {
    63.     while(n--)
    64.     delay_us(1000);
      1. nt main (void)
      2. {
      3.     char i,j,num;   //定义变量
      4.
      5.
      6.           GPIO();
      7.
      8.         while(1){
      9.             if(!GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_10))    //s3键按下
      10.            {delay_ms(80);    //延时,防抖
      11.            if(!GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_10)){j++;}}   //s3自加1
      12.         if(j%2==0){      // 如果j是偶数
      13.              if(!GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_8))      //s1键按下
      14.            {delay_ms(80);
      15.            if(!GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_8)){i++;}    //s1键按下i自加1
      16.            }
      17.                             if(i>30){i=0;}   //30个循环
      18.         GPIO_ResetBits(GPIOB,GPIO_Pin_1);    //关闭PB1
      19.         GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14);  //关闭数码管管脚
      20.
      21.         switch(i)
      22.         {
      23.          case 0 :
      24.              GPIO_SetBits(GPIOB,GPIO_Pin_1);
      25.              GPIO_ResetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14);
      26.          break;
      27.          case 1 :
      28.              GPIO_SetBits(GPIOB,GPIO_Pin_1);
      29.              GPIO_ResetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12);
      30.          break;
      31.             case 2 :
      32.              GPIO_SetBits(GPIOB,GPIO_Pin_1);
      33.              GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_13|GPIO_Pin_14);
      34.             break;
      35.             case 3 :
      36.              GPIO_SetBits(GPIOB,GPIO_Pin_1);
      37.              GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14);
      38.             break;
      39.             case 4 :
      40.              GPIO_SetBits(GPIOB,GPIO_Pin_1);
      41.              GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12);
      42.             break;
      43.             case 5 :
      44.              GPIO_SetBits(GPIOB,GPIO_Pin_1);
      45.              GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_12|GPIO_Pin_14);
      46.             break;
      47.             case 6 :
      48.              GPIO_SetBits(GPIOB,GPIO_Pin_1);
      49.              GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14);
      50.             break;
      51.             case 7 :
      52.              GPIO_SetBits(GPIOB,GPIO_Pin_1);
      53.              GPIO_ResetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12);
      54.             break;
      55.             case 8 :
      56.              GPIO_SetBits(GPIOB,GPIO_Pin_1);
      57.              GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14);
      58.             break;
      59.             case 9 :
      60.              GPIO_SetBits(GPIOB,GPIO_Pin_1);
      61.              GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14);
      62.             break;
      63.             case 10 :
      64.              GPIO_SetBits(GPIOB,GPIO_Pin_1);
      65.              GPIO_ResetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14);
      66.              delay_ms(1);
      67.              GPIO_ResetBits(GPIOB,GPIO_Pin_1);
      68.              GPIO_SetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14);
      69.
      70.                   GPIO_SetBits(GPIOB,GPIO_Pin_15);
      71.                   GPIO_ResetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12);
      72.                   delay_ms(1);
      73.                   GPIO_ResetBits(GPIOB,GPIO_Pin_15);
      74.                   GPIO_SetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12);
      75.             break;
      76.             case 11 :
      77.              GPIO_SetBits(GPIOB,GPIO_Pin_1);
      78.              GPIO_ResetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12);
      79.              delay_ms(1);
      80.              GPIO_ResetBits(GPIOB,GPIO_Pin_1);
      81.              GPIO_SetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12);
      82.
      83.                   GPIO_SetBits(GPIOB,GPIO_Pin_15);
      84.                   GPIO_ResetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12);
      85.                   delay_ms(1);
      86.                   GPIO_ResetBits(GPIOB,GPIO_Pin_15);
      87.                   GPIO_SetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12);
      88.             break;
      89.             case 12 :
      90.              GPIO_SetBits(GPIOB,GPIO_Pin_1);
      91.              GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_13|GPIO_Pin_14);
      92.              delay_ms(1);
      93.              GPIO_ResetBits(GPIOB,GPIO_Pin_1);
      94.              GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_13|GPIO_Pin_14);
      95.
      96.                     GPIO_SetBits(GPIOB,GPIO_Pin_15);
      97.                   GPIO_ResetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12);
      98.                   delay_ms(1);
      99.                   GPIO_ResetBits(GPIOB,GPIO_Pin_15);
      100.                   GPIO_SetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12);
      101.             break;
      102.             case 13 :
      103.              GPIO_SetBits(GPIOB,GPIO_Pin_1);
      104.              GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14);
      105.              delay_ms(1);
      106.              GPIO_ResetBits(GPIOB,GPIO_Pin_1);
      107.              GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14);
      108.
      109.                   GPIO_SetBits(GPIOB,GPIO_Pin_15);
      110.                   GPIO_ResetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12);
      111.                   delay_ms(1);
      112.                   GPIO_ResetBits(GPIOB,GPIO_Pin_15);
      113.                   GPIO_SetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12);
      114.             break;
      115.             case 14 :
      116.              GPIO_SetBits(GPIOB,GPIO_Pin_1);
      117.              GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12);
      118.              delay_ms(1);
      119.              GPIO_ResetBits(GPIOB,GPIO_Pin_1);
      120.              GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12);
      121.
      122.                         GPIO_SetBits(GPIOB,GPIO_Pin_15);
      123.                   GPIO_ResetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12);
      124.                   delay_ms(1);
      125.                   GPIO_ResetBits(GPIOB,GPIO_Pin_15);
      126.                   GPIO_SetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12);
      127.             break;
      128.             case 15 :
      129.              GPIO_SetBits(GPIOB,GPIO_Pin_1);
      130.              GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_12|GPIO_Pin_14);
      131.              delay_ms(80);
      132.              GPIO_ResetBits(GPIOB,GPIO_Pin_1);
      133.              GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_12|GPIO_Pin_14);
      134.
      135.                   GPIO_SetBits(GPIOB,GPIO_Pin_15);
      136.                   GPIO_ResetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12);
      137.                   delay_ms(100);
      138.                   GPIO_ResetBits(GPIOB,GPIO_Pin_15);
      139.                   GPIO_SetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12);
      140.             break;
      141.             case 16 :
      142.              GPIO_SetBits(GPIOB,GPIO_Pin_1);
      143.              GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14);
      144.              delay_ms(80);
      145.              GPIO_ResetBits(GPIOB,GPIO_Pin_1);
      146.              GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14);
      147.
      148.                   GPIO_SetBits(GPIOB,GPIO_Pin_15);
      149.                   GPIO_ResetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12);
      150.                   delay_ms(100);
      151.                   GPIO_ResetBits(GPIOB,GPIO_Pin_15);
      152.                   GPIO_SetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12);
      153.             break;
      154.             case 17 :
      155.              GPIO_SetBits(GPIOB,GPIO_Pin_1);
      156.              GPIO_ResetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12);
      157.              delay_ms(80);
      158.              GPIO_ResetBits(GPIOB,GPIO_Pin_1);
      159.             GPIO_SetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12);
      160.
      161.                   GPIO_SetBits(GPIOB,GPIO_Pin_15);
      162.                   GPIO_ResetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12);
      163.                   delay_ms(100);
      164.                   GPIO_ResetBits(GPIOB,GPIO_Pin_15);
      165.                   GPIO_SetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12);
      166.             break;
      167.             case 18 :
      168.              GPIO_SetBits(GPIOB,GPIO_Pin_1);
      169.              GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14);
      170.              delay_ms(80);
      171.              GPIO_ResetBits(GPIOB,GPIO_Pin_1);
      172.              GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14);
      173.
      174.                   GPIO_SetBits(GPIOB,GPIO_Pin_15);
      175.                   GPIO_ResetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12);
      176.                   delay_ms(100);
      177.                   GPIO_ResetBits(GPIOB,GPIO_Pin_15);
      178.                   GPIO_SetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12);
      179.             break;
      180.             case 19 :
      181.              GPIO_SetBits(GPIOB,GPIO_Pin_1);
      182.              GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14);
      183.              delay_ms(80);
      184.              GPIO_ResetBits(GPIOB,GPIO_Pin_1);
      185.              GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14);
      186.
      187.                   GPIO_SetBits(GPIOB,GPIO_Pin_15);
      188.                   GPIO_ResetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12);
      189.                   delay_ms(100);
      190.                   GPIO_ResetBits(GPIOB,GPIO_Pin_15);
      191.                   GPIO_SetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12);
      192.             break;
      193.             case 20 :
      194.              GPIO_SetBits(GPIOB,GPIO_Pin_1);
      195.              GPIO_ResetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14);
      196.              delay_ms(80);
      197.              GPIO_ResetBits(GPIOB,GPIO_Pin_1);
      198.              GPIO_SetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14);
      199.
      200.                   GPIO_SetBits(GPIOB,GPIO_Pin_15);
      201.                   GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_13|GPIO_Pin_14);
      202.                   delay_ms(100);
      203.                   GPIO_ResetBits(GPIOB,GPIO_Pin_15);
      204.                   GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_13|GPIO_Pin_14);
      205.             break;
      206.             case 21 :
      207.              GPIO_SetBits(GPIOB,GPIO_Pin_1);
      208.              GPIO_ResetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12);
      209.              delay_ms(80);
      210.              GPIO_ResetBits(GPIOB,GPIO_Pin_1);
      211.              GPIO_SetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12);
      212.
      213.                   GPIO_SetBits(GPIOB,GPIO_Pin_15);
      214.                   GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_13|GPIO_Pin_14);
      215.                   delay_ms(100);
      216.                   GPIO_ResetBits(GPIOB,GPIO_Pin_15);
      217.                   GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_13|GPIO_Pin_14);
      218.             break;
      219.             case 22 :
      220.              GPIO_SetBits(GPIOB,GPIO_Pin_1);
      221.              GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_13|GPIO_Pin_14);
      222.              delay_ms(80);
      223.              GPIO_ResetBits(GPIOB,GPIO_Pin_1);
      224.              GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_13|GPIO_Pin_14);
      225.
      226.                     GPIO_SetBits(GPIOB,GPIO_Pin_15);
      227.                   GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_13|GPIO_Pin_14);
      228.                   delay_ms(100);
      229.                   GPIO_ResetBits(GPIOB,GPIO_Pin_15);
      230.                   GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_13|GPIO_Pin_14);
      231.             break;
      232.             case 23 :
      233.              GPIO_SetBits(GPIOB,GPIO_Pin_1);
      234.              GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14);
      235.              delay_ms(80);
      236.             GPIO_ResetBits(GPIOB,GPIO_Pin_1);
      237.             GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14);
      238.
      239.                   GPIO_SetBits(GPIOB,GPIO_Pin_15);
      240.                   GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_13|GPIO_Pin_14);
      241.                   delay_ms(100);
      242.                   GPIO_ResetBits(GPIOB,GPIO_Pin_15);
      243.                   GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_13|GPIO_Pin_14);
      244.                         break;
      245.             case 24 :
      246.              GPIO_SetBits(GPIOB,GPIO_Pin_1);
      247.              GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12);
      248.              delay_ms(80);
      249.              GPIO_ResetBits(GPIOB,GPIO_Pin_1);
      250.              GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12);
      251.
      252.                         GPIO_SetBits(GPIOB,GPIO_Pin_15);
      253.                   GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_13|GPIO_Pin_14);
      254.                   delay_ms(100);
      255.                   GPIO_ResetBits(GPIOB,GPIO_Pin_15);
      256.                   GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_13|GPIO_Pin_14);
      257.             break;
      258.             case 25 :
      259.              GPIO_SetBits(GPIOB,GPIO_Pin_1);
      260.              GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_12|GPIO_Pin_14);
      261.              delay_ms(80);
      262.             GPIO_ResetBits(GPIOB,GPIO_Pin_1);
      263.            GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_12|GPIO_Pin_14);
      264.
      265.                   GPIO_SetBits(GPIOB,GPIO_Pin_15);
      266.                   GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_13|GPIO_Pin_14);
      267.                   delay_ms(100);
      268.                   GPIO_ResetBits(GPIOB,GPIO_Pin_15);
      269.                   GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_13|GPIO_Pin_14);
      270.             break;
      271.             case 26 :
      272.              GPIO_SetBits(GPIOB,GPIO_Pin_1);
      273.              GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14);
      274.              delay_ms(80);
      275.             GPIO_ResetBits(GPIOB,GPIO_Pin_1);
      276.             GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14);
      277.
      278.                   GPIO_SetBits(GPIOB,GPIO_Pin_15);
      279.                   GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_13|GPIO_Pin_14);
      280.                   delay_ms(100);
      281.                   GPIO_ResetBits(GPIOB,GPIO_Pin_15);
      282.                   GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_13|GPIO_Pin_14);
      283.             break;
      284.             case 27 :
      285.              GPIO_SetBits(GPIOB,GPIO_Pin_1);
      286.              GPIO_ResetBits (GPIOB,GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12);
      287.              delay_ms(80);
      288.             GPIO_ResetBits(GPIOB,GPIO_Pin_1);
      289.             GPIO_SetBits (GPIOB,GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12);
      290.
      291.                   GPIO_SetBits(GPIOB,GPIO_Pin_15);
      292.                   GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_13|GPIO_Pin_14);
      293.                   delay_ms(100);
      294.                   GPIO_ResetBits(GPIOB,GPIO_Pin_15);
      295.                   GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_13|GPIO_Pin_14);
      296.             break;
      297.             case 28 :
      298.              GPIO_SetBits(GPIOB,GPIO_Pin_1);
      299.              GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14);
      300.              delay_ms(80);
      301.              GPIO_ResetBits(GPIOB,GPIO_Pin_1);
      302.             GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14);
      303.
      304.                   GPIO_SetBits(GPIOB,GPIO_Pin_15);
      305.                   GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_13|GPIO_Pin_14);
      306.                   delay_ms(100);
      307.                   GPIO_ResetBits(GPIOB,GPIO_Pin_15);
      308.                   GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_13|GPIO_Pin_14);
      309.             break;
      310.             case 29 :
      311.             GPIO_SetBits(GPIOB,GPIO_Pin_1);
      312.              GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14);
      313.              delay_ms(80);
      314.             GPIO_ResetBits(GPIOB,GPIO_Pin_1);
      315.             GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14);
      316.
      317.                   GPIO_SetBits(GPIOB,GPIO_Pin_15);
      318.                   GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_13|GPIO_Pin_14);
      319.                   delay_ms(100);
      320.                   GPIO_ResetBits(GPIOB,GPIO_Pin_15);
      321.                   GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_13|GPIO_Pin_14);
      322.             break;
      323.             case 30 :
      324.              GPIO_SetBits(GPIOB,GPIO_Pin_1);
      325.              GPIO_ResetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14);
      326.              delay_ms(80);
      327.              GPIO_ResetBits(GPIOB,GPIO_Pin_1);
      328.              GPIO_SetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14);
      329.
      330.                   GPIO_SetBits(GPIOB,GPIO_Pin_15);
      331.                   GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14);
      332.                   delay_ms(100);
      333.                   GPIO_ResetBits(GPIOB,GPIO_Pin_15);
      334.                   GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14);
      335.             break;
      336. }
      337.
      338.
      339.           }
      340.                 else{
      341.                               if(!GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_9))     //s2键按下
      342.            {delay_ms(80);
      343.            if(!GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_9)){num++;}}
      344.            if(num>30){num=0;}
      345.         GPIO_ResetBits(GPIOB,GPIO_Pin_1);
      346.         GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14);
      347.
      348.         switch(num)
2014-11-27 21:39:27     打赏
void function(void)
    int display[10],shift=0,flag=0,i=0;//shift作为S4的标识位,flag作为S1的标识位,数组display保存数码管0-9个数字的显示组合
    display[0]=GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14;
    display[1]=GPIO_Pin_9|GPIO_Pin_12;
    display[2]=GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_13|GPIO_Pin_14;
    display[3]=GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14;
    display[4]=GPIO_Pin_5|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12;
    display[5]=GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_12|GPIO_Pin_14;
    display[6]=GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14;
    display[7]=GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12;
    display[8]=GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14;
    display[9]=GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14;
2014-11-27 22:22:02     打赏
  3. #include <stdio.h>
  4. /** @addtogroup STM32F10x_StdPeriph_Examples
  5.   * @{
  6. /** @addtogroup EXTI_Config
  7.   * @{
  8. /* Private typedef ---------------------------------------------------------
  9. /* Private define ---------------------------------------------------------
  10. /* Private macro -------------------------------------------------------------*/
  11. /* Private variables ---------------------------------------------------------*/
  12. EXTI_InitTypeDef   EXTI_InitStructure;
  13. GPIO_InitTypeDef   GPIO_InitStructure;
  14. NVIC_InitTypeDef   NVIC_InitStructure;
  15. USART_InitTypeDef USART_InitStructure;
  16. USART_ClockInitTypeDef USART_ClockInitStructure;
  17. /* Private function prototypes -----------------------------------------------*/
  18. void EXTIkeyS1_Config(void);
  19. void EXTIkeyS2_Config(void);
  20. void EXTIkeyS3_Config(void);
  21. void EXTIkeyS4_Config(void);
  22. void RCC_Configuration(void)
  23. {
  24.   RCC_DeInit();
  25.
  26.   RCC_HSICmd(ENABLE);
  27.   while(RCC_GetFlagStatus(RCC_FLAG_HSIRDY) == RESET);
  28.
  29.   RCC_SYSCLKConfig(RCC_SYSCLKSource_HSI);
  30.
  31.   RCC_HSEConfig(RCC_HSE_OFF);
  32.   RCC_LSEConfig(RCC_LSE_OFF);
  33.   RCC_PLLConfig(RCC_PLLSource_HSI_Div2,RCC_PLLMul_9); //  72HMz
  34.   RCC_PLLCmd(ENABLE);
  35.   while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET);
  36.   RCC_ADCCLKConfig(RCC_PCLK2_Div4);
  37.   RCC_PCLK2Config(RCC_HCLK_Div1);
  38.   RCC_PCLK1Config(RCC_HCLK_Div2);
  39.   RCC_HCLKConfig(RCC_SYSCLK_Div1);
  40.   RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
  41.   while(RCC_GetSYSCLKSource() != 0x08);
  42.     RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD|RCC_APB2Periph_AFIO, ENABLE);
  43.  GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);//disable JTAG
  44. RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD|RCC_APB2Periph_AFIO, ENABLE);
  45.  GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);//disable JTAG
  46.   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
  49.   GPIO_Init(GPIOD, &GPIO_InitStructure);
  50.     GPIO_ResetBits(GPIOD,GPIO_Pin_2);
  51.     RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC|RCC_APB2Periph_AFIO, ENABLE);
  52.  GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);//disable JTAG
  53.   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;
  54.   GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  55.   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  56.   GPIO_Init(GPIOC, &GPIO_InitStructure);
  57.     GPIO_ResetBits(GPIOC,GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7);
  58. }
  59.
  60. void USART_int(long BaudRate)
  61. {
  62.     RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_USART1,ENABLE);
  63.        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
  64.     GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;
  65.     GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  66.     GPIO_Init(GPIOA, &GPIO_InitStructure);
  67.     /* PA10 USART1_Rx  */
  68.     GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
  69.     GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
  70.     GPIO_Init(GPIOA, &GPIO_InitStructure);
  71.   /* USARTx configured as follow:
  72.         - BaudRate = 115200 baud
  73.         - Word Length = 8 Bits
  74.         - One Stop Bit
  75.         - No parity
  76.         - Hardware flow control disabled (RTS and CTS signals)
  77.         - Receive and transmit enabled
  78.   */
  79.   USART_InitStructure.USART_BaudRate = BaudRate;//??????
  80.   USART_InitStructure.USART_WordLength = USART_WordLength_8b;//???????8bit
  81.   USART_InitStructure.USART_StopBits = USART_StopBits_1;//????1
  82.   USART_InitStructure.USART_Parity = USART_Parity_No;//????
  83.   USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;none
  84.   USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;//??????????
  85.     USART_ClockInitStructure.USART_Clock = USART_Clock_Disable;
  86.     USART_ClockInitStructure.USART_CPOL = USART_CPOL_Low;
  87.     USART_ClockInitStructure.USART_CPHA = USART_CPHA_2Edge;
  88.     USART_ClockInitStructure.USART_LastBit = USART_LastBit_Disable;
  89.     USART_ClockInit(USART1, &USART_ClockInitStructure);
  90.   USART_Init(USART1, &USART_InitStructure);
  91.   USART_Cmd(USART1, ENABLE);
  92.     USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
  93.  USART_Cmd(USART1, ENABLE);
  94.
  95.   /* Configure four bit for preemption priority */
  96.   NVIC_PriorityGroupConfig(NVIC_PriorityGroup_4);
  97.   /* Enable the USART1 Interrupt */
  98.   NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn; //
  99.   NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 15;
  100.   NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  101.   NVIC_Init(&NVIC_InitStructure);
  102. }
  103.
  104. /* Private functions ---------------------------------------------------------*/
  105.
  106. /**
  107.   * @brief  Main program.
  108.   * @param  None
  109.   * @retval None
  110.   */
  111. int main(void)
  112. {RCC_Configuration();
  113.
  114.   /* Configure PA.00 in interrupt mode */
  115.   EXTIkeyS1_Config();
  116.
  117.   /* Configure PB.09 or PG.08 in interrupt mode */
  118.   EXTIkeyS2_Config();
  119.     EXTIkeyS3_Config();
  120.   EXTIkeyS4_Config();
  121. USART_int(115200);
  122.     printf("Config done,waiting for interrupt......\r\n");
  123.
  124.   while (1)
  125.   {
  126.   }
  127. }
  128.
  129. /**
  130.   * @brief  Configure PA.00 in interrupt mode
  131.   * @param  None
  132.   * @retval None
  133.   */
  134. void EXTIkeyS1_Config(void)
  135. {
  136.   /* Enable GPIOA clock */
  137.   RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);
  138.
  139.   /* Configure PA.00 pin as input floating */
  140.   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;    //GPIOC.8 中断线以及中断初始化配置 下降沿触发
  141.   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
  142.   GPIO_Init(GPIOC, &GPIO_InitStructure);
  143.
  144.   /* Enable AFIO clock */
  145.   RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO, ENABLE);
  146.
  147.   /* Connect EXTI0 Line to PA.00 pin */
  148.   GPIO_EXTILineConfig(GPIO_PortSourceGPIOC, GPIO_PinSource8);
  149.
  150.   /* Configure EXTI0 line */
  151.   EXTI_InitStructure.EXTI_Line = EXTI_Line8;
  152.   EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
  153.   EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Falling;
  154.   EXTI_InitStructure.EXTI_LineCmd = ENABLE;
  155.   EXTI_Init(&EXTI_InitStructure);
  156.
  157.   /* Enable and set EXTI0 Interrupt to the lowest priority */
  158.   NVIC_InitStructure.NVIC_IRQChannel = EXTI9_5_IRQn;   //使能按键所在的外部中断通道
  159.   NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0x0F;
  160.   NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0x0F;
  161.   NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;   //使能外部中断通道
  162.   NVIC_Init(&NVIC_InitStructure);
  163. }
  164.
  165. void EXTIkeyS2_Config(void)
  166. {
  167.   /* Enable GPIOA clock */
  168.   RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);
  169.
  170.   /* Configure PA.00 pin as input floating */
  171.   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;   // GPIOC.9 中断线以及中断初始化配置 下降沿触发
  172.   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
  173.   GPIO_Init(GPIOC, &GPIO_InitStructure);
  174.
  175.   /* Enable AFIO clock */
  176.   RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO, ENABLE);
  177.
  178.   /* Connect EXTI0 Line to PA.00 pin */
  179.   GPIO_EXTILineConfig(GPIO_PortSourceGPIOC, GPIO_PinSource9);
  180.
  181.   /* Configure EXTI0 line */
  182.   EXTI_InitStructure.EXTI_Line = EXTI_Line10;
    1. //GPIOC.10 中断线以及中断初始化配置 下降沿触发
    2.
  183.   EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
  184.   EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Falling;
  185.   EXTI_InitStructure.EXTI_LineCmd = ENABLE;
  186.   EXTI_Init(&EXTI_InitStructure);
  187.
  188.   /* Enable and set EXTI0 Interrupt to the lowest priority */
  189.   NVIC_InitStructure.NVIC_IRQChannel = EXTI9_5_IRQn;  //使能按键所在的外部中断通道
  190.   NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0x0F;
  191.   NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0x0F;
  192.   NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  193.   NVIC_Init(&NVIC_InitStructure);
  194. }
  195.
  196. /**
  197.   * @brief  Configure PB.09 or PG.08 in interrupt mode
  198.   * @param  None
  199.   * @retval None
  200.   */
  201. void EXTIkeyS3_Config(void)
  202. {
  203.   /* Enable GPIOB clock */
  204.   RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);
  205.
  206.   /* Configure PB.09 pin as input floating */
  207.   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10|GPIO_Pin_11;
  208.   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
  209.   GPIO_Init(GPIOC, &GPIO_InitStructure);
  210.
  211.   /* Enable AFIO clock */
  212.   RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO, ENABLE);
  213.   /* Connect EXTI9 Line to PB.09 pin */
  214.   GPIO_EXTILineConfig(GPIO_PortSourceGPIOC, GPIO_PinSource10);
  215.
  216.   /* Configure EXTI9 line */
  217.   EXTI_InitStructure.EXTI_Line = EXTI_Line10|EXTI_Line11;
  218.   EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
  219.   EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Falling;
  220.   EXTI_InitStructure.EXTI_LineCmd = ENABLE;
  221.   EXTI_Init(&EXTI_InitStructure);
  222.
  223.   /* Enable and set EXTI9_5 Interrupt to the lowest priority */
  224.   NVIC_InitStructure.NVIC_IRQChannel = EXTI15_10_IRQn;    //使能按键所在的外部中断通道
  225.   NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0x0F;
  226.   NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0x0F;
  227.   NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  228.
  229.   NVIC_Init(&NVIC_InitStructure);
  230. }
  231. void EXTIkeyS4_Config(void)
  232. {
  233.   /* Enable GPIOB clock */
  234.   RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);
  235.
  236.   /* Configure PB.09 pin as input floating */
  237.   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11;
  238.   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
  239.   GPIO_Init(GPIOC, &GPIO_InitStructure);
  240.
  241.   /* Enable AFIO clock */
  242.   RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO, ENABLE);
  243.   /* Connect EXTI9 Line to PB.09 pin */
  244.   GPIO_EXTILineConfig(GPIO_PortSourceGPIOC, GPIO_PinSource11);
  245.
  246.   /* Configure EXTI9 line */
  247.   EXTI_InitStructure.EXTI_Line = EXTI_Line11;
  248.   EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
  249.   EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Falling;
  250.   EXTI_InitStructure.EXTI_LineCmd = ENABLE;
  251.   EXTI_Init(&EXTI_InitStructure);
  252.
  253.   /* Enable and set EXTI9_5 Interrupt to the lowest priority */
  254.   NVIC_InitStructure.NVIC_IRQChannel = EXTI15_10_IRQn;
  255.   NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0x0F;
  256.   NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0x0F;
  257.   NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  258.
  259.   NVIC_Init(&NVIC_InitStructure);
  260. }
  261. /******************************************************************************/
  262. /*            STM32F10x Peripherals Interrupt Handlers                        */
  263. /******************************************************************************/
  264.
  265. /**
  266.   * @brief  This function handles External lines 9 to 5 interrupt request.
  267.   * @param  None
  268.   * @retval None
  269.   */
  270. void EXTI9_5_IRQHandler(void)
  271. {
  272.     if(EXTI_GetITStatus(EXTI_Line8) != RESET)
  273.   {
  274.     /* Toggle LED1 */
  275.      GPIO_SetBits(GPIOC,GPIO_Pin_0|GPIO_Pin_1);
  276. printf("S1 interrupt ......\r\n");
  277.     /* Clear the  EXTI line 0 pending bit */
  278.     EXTI_ClearITPendingBit(EXTI_Line8);
  279.         }
  280.     if(EXTI_GetITStatus(EXTI_Line9) != RESET)
  281.         {
  282.      GPIO_SetBits(GPIOC,GPIO_Pin_2|GPIO_Pin_3);
  283. printf("S2 interrupt ......\r\n");
  284.     /* Clear the  EXTI line 0 pending bit */
  285.     EXTI_ClearITPendingBit(EXTI_Line9);
  286.     }
  287.
  288. }
  289. void EXTI15_10_IRQHandler(void)
  290. {
  291.   if(EXTI_GetITStatus(EXTI_Line10) != RESET)
  292.   {
  293.     /* Toggle LED2 */
  294.      GPIO_SetBits(GPIOC,GPIO_Pin_4|GPIO_Pin_5);
  295. printf("S3 interrupt ......\r\n");
  296.     /* Clear the  EXTI line 9 pending bit */
  297.     EXTI_ClearITPendingBit(EXTI_Line10);
  298.   }
  299.     if(EXTI_GetITStatus(EXTI_Line11) != RESET)
  300.   {
  301.     /* Toggle LED2 */
  302.      GPIO_SetBits(GPIOC,GPIO_Pin_6|GPIO_Pin_7);
  303. printf("S4 interrupt ......\r\n");
  304.     /* Clear the  EXTI line 9 pending bit */
  305.     EXTI_ClearITPendingBit(EXTI_Line11);
  306.   }
  307. }
  308. #ifdef  USE_FULL_ASSERT
  309.
  310. /**
  311.   * @brief  Reports the name of the source file and the source line number
  312.   *         where the assert_param error has occurred.
  313.   * @param  file: pointer to the source file name
  314.   * @param  line: assert_param error line source number
  315.   * @retval None
  316.   */
  317. void assert_failed(uint8_t* file, uint32_t line)
  318. {
  319.   /* User can add his own implementation to report the file name and line number,
  320.      ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  321.
  322.   /* Infinite loop */
  323.   while (1)
  324.   {
  325.   }
  326. }
  327. #endif
  328. #ifdef __GNUC__
  329.   /* With GCC/RAISONANCE, small printf (option LD Linker->Libraries->Small printf
  330.      set to 'Yes') calls __io_putchar() */
  331.   #define PUTCHAR_PROTOTYPE int __io_putchar(int ch)
  332. #else
  333.   #define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f)
  334. #endif /* __GNUC__ */
  335. /**
  336.   * @brief  Retargets the C library printf function to the USART.
  337.   * @param  None
  338.   * @retval None
  339.   */
  340. PUTCHAR_PROTOTYPE
  341. {
  342.   /* Place your implementation of fputc here */
  343.   /* e.g. write a character to the USART */
  344.   USART_SendData(EVAL_COM1, (uint8_t) ch);
  345.
  346.   /* Loop until the end of transmission */
  347.   while (USART_GetFlagStatus(EVAL_COM1, USART_FLAG_TC) == RESET)
  348.   {}
  349.   return ch;
  350. }
  351. #ifdef  USE_FULL_ASSERT
  352. /**
  353.   * @brief  Reports the name of the source file and the source line number
  354.   *         where the assert_param error has occurred.
  355.   * @param  file: pointer to the source file name
  356.   * @param  line: assert_param error line source number
  357.   * @retval None
  358.   */
  359. void assert_failed(uint8_t* file, uint32_t line)
  360. {
  361.   /* User can add his own implementation to report the file name and line number,
  362.      ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  363.   /* Infinite loop */
  364.   while (1)
  365.   {
  366.   }
  367. }
  368. #endif
2014-12-23 20:16:56     打赏
  4. #include <stdio.h>
  5. /** @addtogroup STM32F10x_StdPeriph_Examples
  6.   * @{
  7.   */
  8.
  9. /** @addtogroup EXTI_Config
  10.   * @{
  11.   */
  12.
  13. /* Private typedef -----------------------------------------------------------*/
  14. /* Private define ------------------------------------------------------------*/
  15. /* Private macro -------------------------------------------------------------*/
  16. /* Private variables ---------------------------------------------------------*/
  17. EXTI_InitTypeDef   EXTI_InitStructure;
  18. GPIO_InitTypeDef   GPIO_InitStructure;
  19. NVIC_InitTypeDef   NVIC_InitStructure;
  20. USART_InitTypeDef USART_InitStructure;
  21. USART_ClockInitTypeDef USART_ClockInitStructure;
  22. TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
  23. TIM_OCInitTypeDef  TIM_OCInitStructure;
  24. long flag,temp,num;
  25. void RCC_Configuration(void)
  26. {/*
  27.   RCC_DeInit();
  28.
  29.   RCC_HSICmd(ENABLE);
  30.   while(RCC_GetFlagStatus(RCC_FLAG_HSIRDY) == RESET);
  31.
  32.   RCC_SYSCLKConfig(RCC_SYSCLKSource_HSI);
  33.
  34.   RCC_HSEConfig(RCC_HSE_OFF);
  35.   RCC_LSEConfig(RCC_LSE_OFF);
  36.   RCC_PLLConfig(RCC_PLLSource_HSI_Div2,RCC_PLLMul_9); //  72HMz
  37.   RCC_PLLCmd(ENABLE);
  38.   while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET);
  39.   RCC_ADCCLKConfig(RCC_PCLK2_Div4);
  40.   RCC_PCLK2Config(RCC_HCLK_Div1);
  41.   RCC_PCLK1Config(RCC_HCLK_Div2);
  42.   RCC_HCLKConfig(RCC_SYSCLK_Div1);
  43.   RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
  44.   while(RCC_GetSYSCLKSource() != 0x08);
  45. */
  46.     SystemInit();
  47.     RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD|RCC_APB2Periph_AFIO, ENABLE);
  48.   GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);//disable JTAG
  49.    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD|RCC_APB2Periph_AFIO, ENABLE);
  50.    GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);//disable JTAG
  51.   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
  52.   GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  53.   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  54.   GPIO_Init(GPIOD, &GPIO_InitStructure);
  55.     GPIO_ResetBits(GPIOD,GPIO_Pin_2);
  56.     RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC|RCC_APB2Periph_AFIO, ENABLE);
  57.  GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);//disable JTAG
  58.   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;
  59.   GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  60.   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  61.   GPIO_Init(GPIOC, &GPIO_InitStructure);
  62.     GPIO_SetBits(GPIOC,GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7);
  63.     RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);
  64.     RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE);
  65.     RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM7, ENABLE);
  66.
  67.
  68.
  69. }
  70.
  71.
  72. void USART_int(long BaudRate)
  73. {
  74.     RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_USART1,ENABLE);
  75.        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
  76.     GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;
  77.     GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  78.     GPIO_Init(GPIOA, &GPIO_InitStructure);
  79.     /* PA10 USART1_Rx  */
  80.     GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
  81.     GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
  82.     GPIO_Init(GPIOA, &GPIO_InitStructure);
  83.   /* USARTx configured as follow:
  84.         - BaudRate = 115200 baud
  85.         - Word Length = 8 Bits
  86.         - One Stop Bit
  87.         - No parity
  88.         - Hardware flow control disabled (RTS and CTS signals)
  89.         - Receive and transmit enabled
  90.   */
  91.   USART_InitStructure.USART_BaudRate = BaudRate;//??????
  92.   USART_InitStructure.USART_WordLength = USART_WordLength_8b;//???????8bit
  93.   USART_InitStructure.USART_StopBits = USART_StopBits_1;//????1
  94.   USART_InitStructure.USART_Parity = USART_Parity_No;//????
  95.   USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//??????none
  96.   USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;//??????????
  97.     USART_ClockInitStructure.USART_Clock = USART_Clock_Disable;
  98.   USART_ClockInitStructure.USART_CPOL = USART_CPOL_Low;
  99.   USART_ClockInitStructure.USART_CPHA = USART_CPHA_2Edge;
  100.   USART_ClockInitStructure.USART_LastBit = USART_LastBit_Disable;
  101.   USART_ClockInit(USART1, &USART_ClockInitStructure);
  102.   USART_Init(USART1, &USART_InitStructure);
  103.   USART_Cmd(USART1, ENABLE);
  104.     USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
  105.   USART_Cmd(USART1, ENABLE);
  106. }
  107.
  108. void NVIC_Configuration(void)
  109. {
  110.   NVIC_InitTypeDef NVIC_InitStructure;
  111.
  112.   /* Enable the TIM2 global Interrupt */
  113.   NVIC_InitStructure.NVIC_IRQChannel = TIM2_IRQn;
  114.   NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
  115.   NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
  116.   NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  117.   NVIC_Init(&NVIC_InitStructure);
  118.
  119.     NVIC_InitStructure.NVIC_IRQChannel = TIM3_IRQn;
  120.   NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
  121.   NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
  122.   NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  123.     NVIC_Init(&NVIC_InitStructure);
  124.
  125.     NVIC_InitStructure.NVIC_IRQChannel = TIM7_IRQn;
  126.   NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
  127.   NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
  128.   NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  129.       NVIC_Init(&NVIC_InitStructure);
  130.
  131.     /* Time base configuration */
  132.   TIM_TimeBaseStructure.TIM_Period = 24000;
  133.   TIM_TimeBaseStructure.TIM_Prescaler = 0;
  134.   TIM_TimeBaseStructure.TIM_ClockDivision = 0;
  135.   TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
  136.
  137.
  138.     /*NVIC_InitStructure.NVIC_IRQChannel =TIM8_CC_IRQn;
  139.   NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
  140.   NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
  141.   NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  142.       NVIC_Init(&NVIC_InitStructure);*/
  143. }
  144.
  145. /* Private functions ---------------------------------------------------------*/
  146.
  147. /**
  148.   * @brief  Main program.
  149.   * @param  None
  150.   * @retval None
  151.   */
  152.
  153. void delay_us(u32 n)
  154. {
  155.     u8 j;
  156.     while(n--)
  157.     for(j=0;j<10;j++);
  158. }
  159.
  160. void  delay_ms(u32 n)
  161. {
  162.     while(n--)
  163.     delay_us(1500);
  164. }
  165.
  166.
  167. int main(void)
  168. {
  169.   /*!< At this stage the microcontroller clock setting is already configured,
  170.        this is done through SystemInit() function which is called from startup
  171.        file (startup_stm32f10x_xx.s) before to branch to application main.
  172.        To reconfigure the default setting of SystemInit() function, refer to
  173.        system_stm32f10x.c file
  174.      */
  175.
  176.   /* System Clocks Configuration */
  177.
  178.   RCC_Configuration();
  179.
  180. NVIC_Configuration();
  181. USART_int(115200);
  182.     printf(" config done...\r\n");
  183.
  184.
  185.   TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);
  186.   TIM_ITConfig(TIM2,TIM_IT_Update,ENABLE );
  187.
  188.
  189.      TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure);
  190.   TIM_ITConfig(TIM3,TIM_IT_Update,ENABLE );
  191.
  192.      TIM_TimeBaseInit(TIM7, &TIM_TimeBaseStructure);
  193.   TIM_ITConfig(TIM7,TIM_IT_Update,ENABLE );
  194.
  195.
  196.
  197.   /* TIM2 enable counter */
  198.   TIM_Cmd(TIM2, ENABLE);
  199.      TIM_Cmd(TIM3, ENABLE);
  200.          TIM_Cmd(TIM7, ENABLE);
  201.
  202.   while (1){
  203.         if(flag == 2000)
  204.         {printf("TIM2 interrupt......\r\n");
  205.  GPIO_ResetBits(GPIOC,GPIO_Pin_2|GPIO_Pin_3);
  206.         delay_ms(150);
  207.         GPIO_ResetBits(GPIOC,GPIO_Pin_2|GPIO_Pin_3);
  208.           flag = 0;
  209.   }
  210.
  211.         if(temp == 3000)
  212.
  213.         {printf("TIM3 interrupt......\r\n");
  214.             GPIO_ResetBits(GPIOC,GPIO_Pin_6|GPIO_Pin_7);
  215.         delay_ms(150);
  216.         GPIO_ResetBits(GPIOC,GPIO_Pin_6|GPIO_Pin_7);
  217.          temp = 0;
  218.
  219.
  220.
  221.   }
  222.
  223. }
  224.
  225.
  226. }
  227. void TIM2_IRQHandler(void) //TIM3 ??
  228. {
  229. if (TIM_GetITStatus(TIM2, TIM_IT_Update) != RESET) //?? TIM3 ????????
  230. {
  231. TIM_ClearITPendingBit(TIM2, TIM_IT_Update ); //?? TIM3 ??????
  232.     flag++;
  233.
  234. }
  235. }
  236. void TIM3_IRQHandler(void) //TIM3 ??
  237. {
  238. if (TIM_GetITStatus(TIM3, TIM_IT_Update) != RESET) //?? TIM3 ????????
  239. {
  240. TIM_ClearITPendingBit(TIM3, TIM_IT_Update ); //?? TIM3 ??????
  241.     temp++;
  242.
  243. }
  244. }
  245.
  246.
  247.
  248.
  249.
  250.
  251. #ifdef  USE_FULL_ASSERT
  252.
  253. /**
  254.   * @brief  Reports the name of the source file and the source line number
  255.   *         where the assert_param error has occurred.
  256.   * @param  file: pointer to the source file name
  257.   * @param  line: assert_param error line source number
  258.   * @retval None
  259.   */
  260. void assert_failed(uint8_t* file, uint32_t line)
  261. {
  262.   /* User can add his own implementation to report the file name and line number,
  263.      ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  264.
  265.   /* Infinite loop */
  266.   while (1)
  267.   {
  268.   }
  269. }
  270.
  271. #endif
  272.
  273. /**
  274.   * @}
  275.   */
  276.
  277. /**
  278.   * @}
  279.   */
  280.
  281. #ifdef __GNUC__
  282.   /* With GCC/RAISONANCE, small printf (option LD Linker->Libraries->Small printf
  283.      set to 'Yes') calls __io_putchar() */
  284.   #define PUTCHAR_PROTOTYPE int __io_putchar(int ch)
  285. #else
  286.   #define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f)
  287. #endif /* __GNUC__ */
  288.
  289.
  290.
  291. /**
  292.   * @brief  Retargets the C library printf function to the USART.
  293.   * @param  None
  294.   * @retval None
  295.   */
  296. PUTCHAR_PROTOTYPE
  297. {
  298.   /* Place your implementation of fputc here */
  299.   /* e.g. write a character to the USART */
  300.   USART_SendData(EVAL_COM1, (uint8_t) ch);
  301.
  302.   /* Loop until the end of transmission */
  303.   while (USART_GetFlagStatus(EVAL_COM1, USART_FLAG_TC) == RESET)
  304.   {}
  305.
  306.   return ch;
  307. }
  308.
  309. #ifdef  USE_FULL_ASSERT
  310.
  311. /**
  312.   * @brief  Reports the name of the source file and the source line number
  313.   *         where the assert_param error has occurred.
  314.   * @param  file: pointer to the source file name
  315.   * @param  line: assert_param error line source number
  316.   * @retval None
  317.   */
  318. void assert_failed(uint8_t* file, uint32_t line)
  319. {
  320.   /* User can add his own implementation to report the file name and line number,
  321.      ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  322.
  323.   /* Infinite loop */
  324.   while (1)
  325.   {
  326.   }
  327. }
  328.
  329. #endif
  330.
  331. /******************* (C) COPYRIGHT 2011 STMicroelectronics *****END OF FILE****/
2014-12-25 22:58:50     打赏
  3. #include    "stdio.h"
  4. #include "math.h"
  5. #define buff_size  16;
  6. char rx_buff[], rx_buff_count=0;
  7. GPIO_InitTypeDef  GPIO_InitStructure;
  8. USART_InitTypeDef  USART_InitStructure;
  10. USART_ClockInitTypeDef  USART_ClockInitStructure;
  11. void RCC_Configuration(void)
  12. {
  13.     RCC_DeInit();
  14.     RCC_HSICmd(ENABLE);
  15.     while(RCC_GetFlagStatus(RCC_FLAG_HSIRDY) == RESET);
  16.     RCC_SYSCLKConfig(RCC_SYSCLKSource_HSI);
  17.     RCC_HSEConfig(RCC_HSE_OFF);
  18.     RCC_LSEConfig(RCC_LSE_OFF);
  19.     RCC_PLLConfig(RCC_PLLSource_HSI_Div2,RCC_PLLMul_9); //  72HMz
  20.     RCC_PLLCmd(ENABLE);
  21.     while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET);
  22.     RCC_ADCCLKConfig(RCC_PCLK2_Div4);
  23.     RCC_PCLK2Config(RCC_HCLK_Div1);
  24.     RCC_PCLK1Config(RCC_HCLK_Div2);
  25.     RCC_HCLKConfig(RCC_SYSCLK_Div1);
  26.     RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
  27.     while(RCC_GetSYSCLKSource() != 0x08);
  28.     RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD|RCC_APB2Periph_AFIO, ENABLE);
  29.     GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);//disable JTAG
  30.     GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
  31.     GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  32.     GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  33.     GPIO_Init(GPIOD, &GPIO_InitStructure);
  34.     GPIO_ResetBits(GPIOD,GPIO_Pin_2);
  35. }
  36. void GPIO_INIT()
  37. {
  38.     RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);
  39.
  40.     GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;
  42.     GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  44. }
  45. void USART_int(long BaudRate)
  46. {
  47.      RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_USART1,ENABLE);
  48.    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
  49.    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;
  50.    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  51.    GPIO_Init(GPIOA, &GPIO_InitStructure);
  52.    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
  53.    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
  54.    GPIO_Init(GPIOA, &GPIO_InitStructure);
  55.   /* USARTx configured as follow:
  56.         - BaudRate = 115200 baud
  57.         - Word Length = 8 Bits
  58.         - One Stop Bit
  59.         - No parity
  60.         - Hardware flow control disabled (RTS and CTS signals)
  61.         - Receive and transmit enabled
  62.   */
  63.     USART_InitStructure.USART_BaudRate = BaudRate;
  64.     USART_InitStructure.USART_WordLength = USART_WordLength_8b;
  65.     USART_InitStructure.USART_StopBits = USART_StopBits_1;
  66.     USART_InitStructure.USART_Parity = USART_Parity_No;
  67.     USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
  68.     USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
  69.     USART_ClockInitStructure.USART_Clock = USART_Clock_Disable;
  70.   USART_ClockInitStructure.USART_CPOL = USART_CPOL_Low;
  71.   USART_ClockInitStructure.USART_CPHA = USART_CPHA_2Edge;
  72.   USART_ClockInitStructure.USART_LastBit = USART_LastBit_Disable;
  73.     USART_ClockInit(USART1, &USART_ClockInitStructure);
  74.     USART_Init(USART1, &USART_InitStructure);
  75.     USART_Cmd(USART1, ENABLE);
  76.     USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
  77.     USART_Cmd(USART1, ENABLE);
  78.   /* Configure four bit for preemption priority */
  79.     NVIC_PriorityGroupConfig(NVIC_PriorityGroup_4);
  80.   /* Enable the USART1 Interrupt */
  81.     NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;
  82.     NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 15;
  83.     NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  84.     NVIC_Init(&NVIC_InitStructure);//?????
  85. }
  86. /*delay_us*/
  87. void delay_us(u32 n)
  88. {
  89.     u8 j;
  90.     while(n--)
  91.     for(j=0;j<10;j++);
  92. }
  93. /*delay_ms*/
  94. void  delay_ms(u32 n)
  95. {
  96.     while(n--)
  97.     delay_us(1000);
  98. }
  99. void USART_SendStr(char *str)
  100. {
  101.    while((*str)!='\0')
  102.     {
  103.         USART_SendData(USART1,*str++);
  104.         while(USART_GetFlagStatus(USART1, USART_FLAG_TXE) == RESET);
  105.     }
  106. }
  107. unsigned int translate(char *S,char j)
  108. {
  109.     unsigned int a[4],sum=0;
  110.     char i;
  111.     for(i=0;i<j;i++)
  112.     {
  113.         a[i]=S[5+j-1-i]-48;
  114.         sum+=a[i]*pow(10,i);
  115.     }
  116.     return sum;
  117. }
  118. void func(char *S,char LEN)
  119. {
  120.     char count;//
  121.     unsigned int sum,i,j,k;
  122.     if((LEN!=6)&(LEN!=7)&(LEN!=8)&(LEN!=9))
  123.     {USART_SendStr("\r\n Erro input!!!\r\n");}
  124.     else
  125.     {
  126.         count=LEN-5;
  127.         sum = translate(S,count);
  128.         GPIO_SetBits(GPIOC,0x000000ff);
  129.         for(k=0;k<3;k++)
  130.         {
  131.             i=0x00000100;
  132.             for(j=1;j<=8;j++)
  133.             {
  134.                 i>>=1;
  135.                 GPIO_ResetBits(GPIOC,i);
  136.                 delay_ms(50);
  137.                 GPIO_SetBits(GPIOC,i);
  138.                 delay_ms(sum);
  139.             }
  140.         }
  141.     }
  142. }
  143.
  144. void input_ASK()
  145. {
  146.     char j;
  147.     func(rx_buff,rx_buff_count);
  148.     rx_buff_count=0;
  149.     for (j=0;j<rx_buff_count;j++)
  150.     {rx_buff[j]='\0';}
  151.     USART_SendStr("\n>");
  152. }
  153.
  154. int main(void)
  155. {
  156.     RCC_Configuration();
  157.     GPIO_INIT();
  158.     USART_int(9600);
  159.     GPIO_ResetBits(GPIOC,0x000000ff);  //LED灯亮
  160.     delay_ms(200);
  161.     GPIO_SetBits(GPIOC,0x000000ff); //LED灯灭
  162.     USART_SendStr("SyStem booting......\r\n");
  163.     USART_SendStr("\n>");//
  164.     while(1)
  165.         {}
  166. }
  167.
  168. void USART1_IRQHandler(void)
  169. {
  170.   while(USART_GetFlagStatus(USART1, USART_FLAG_RXNE) == RESET)
  171.   {  }
  172.     if(USART_ReceiveData(USART1)==0x0d)
  173.     {input_ASK();}
  174.     else
  175.     {
  176.         USART_SendData(USART1,USART_ReceiveData(USART1));
  177.         rx_buff[rx_buff_count]= USART_ReceiveData(USART1);
  178.         rx_buff_count++;
  179.     }
  180.     USART_ClearFlag(USART1, USART_FLAG_RXNE);
2014-12-25 23:04:31     打赏
  5.   * @{
  6.   */
  7. /** @addtogroup EXTI_Config
  8.   * @{
  9.   */
  10. /* Private typedef-
  11. /* Private define -*/
  12. /* Private macro -*/
  13. /* Private variables -*/
  14. EXTI_InitTypeDef   EXTI_InitStructure;
  15. GPIO_InitTypeDef   GPIO_InitStructure;
  16. NVIC_InitTypeDef   NVIC_InitStructure;
  17. USART_InitTypeDef USART_InitStructure;
  18. USART_ClockInitTypeDef USART_ClockInitStructure;
  19. TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
  20. TIM_OCInitTypeDef  TIM_OCInitStructure;
  21. long flag,temp,num;
  23. {
  24.   RCC_DeInit();
  25.   RCC_HSICmd(ENABLE);
  26.   while(RCC_GetFlagStatus(RCC_FLAG_HSIRDY) == RESET);
  27.   RCC_SYSCLKConfig(RCC_SYSCLKSource_HSI);
  28.   RCC_HSEConfig(RCC_HSE_OFF);
  29.   RCC_LSEConfig(RCC_LSE_OFF);
  30.   RCC_PLLConfig(RCC_PLLSource_HSI_Div2,RCC_PLLMul_9);
  31.   RCC_PLLCmd(ENABLE);
  32.   while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET);
  33.   RCC_ADCCLKConfig(RCC_PCLK2_Div4);
  34.   RCC_PCLK2Config(RCC_HCLK_Div1);
  35.   RCC_PCLK1Config(RCC_HCLK_Div2);
  36.   RCC_HCLKConfig(RCC_SYSCLK_Div1);
  37.   RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
  38.   while(RCC_GetSYSCLKSource() != 0x08);
  39.     SystemInit();
  40.     RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD|RCC_APB2Periph_AFIO, ENABLE)
  41.   GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);
  44.   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
  45.   GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  46.   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  47.   GPIO_Init(GPIOD, &GPIO_InitStructure);
  48.     GPIO_ResetBits(GPIOD,GPIO_Pin_2);
  49.     RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC|RCC_APB2Periph_AFIO, ENABLE);
  51.   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;
  54.   GPIO_Init(GPIOC, &GPIO_InitStructure);
  55.     GPIO_SetBits(GPIOC,GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7);
  56.       RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);
  57.         RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE);
  58.             RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM7, ENABLE);
  59.
  60. }
  61.
  62.
  63. void USART_int(long BaudRate)
  64. {
  65.     RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_USART1,ENABLE);
  66.        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
  67.     GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;
  68.     GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  69.     GPIO_Init(GPIOA, &GPIO_InitStructure);
  70.     /* PA10 USART1_Rx  */
  71.     GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
  73.     GPIO_Init(GPIOA, &GPIO_InitStructure);
  74.   /* USARTx configured as follow:
  75.         - BaudRate = 115200 baud
  76.         - Word Length = 8 Bits
  77.         - One Stop Bit
  78.         - No parity
  79.         - Hardware flow control disabled (RTS and CTS signals)
  80.         - Receive and transmit enabled
  81.   */
  82.   USART_InitStructure.USART_BaudRate = BaudRate;
  83.   USART_InitStructure.USART_WordLength = USART_WordLength_8b;
  84.   USART_InitStructure.USART_StopBits = USART_StopBits_1;
  85.   USART_InitStructure.USART_Parity = USART_Parity_No;
  86.   USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
  87.   USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
  88.     USART_ClockInitStructure.USART_Clock = USART_Clock_Disable;
  89.     USART_ClockInitStructure.USART_CPOL = USART_CPOL_Low;
  90.     USART_ClockInitStructure.USART_CPHA = USART_CPHA_2Edge;
  91.     USART_ClockInitStructure.USART_LastBit = USART_LastBit_Disable;
  92.     USART_ClockInit(USART1, &USART_ClockInitStructure);
  93.   USART_Init(USART1, &USART_InitStructure);
  94.   USART_Cmd(USART1, ENABLE);
  95.     USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
  96.  USART_Cmd(USART1, ENABLE);
  97. }
  98.
  99. void NVIC_Configuration(void)
  100. {
  101.   NVIC_InitTypeDef NVIC_InitStructure;
  102.
  103.   /* Enable the TIM2 global Interrupt */
  104.   NVIC_InitStructure.NVIC_IRQChannel = TIM2_IRQn;
  105.   NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
  106.   NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
  107.   NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  108.   NVIC_Init(&NVIC_InitStructure);
  109.
  110.       NVIC_InitStructure.NVIC_IRQChannel = TIM3_IRQn;
  111.   NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
  112.   NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
  113.   NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  114.       NVIC_Init(&NVIC_InitStructure);
  115.
  116.       NVIC_InitStructure.NVIC_IRQChannel = TIM7_IRQn;
  117.   NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
  118.   NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
  119.   NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  120.       NVIC_Init(&NVIC_InitStructure);
  121.
  122.     /* Time base configuration */
  123.   TIM_TimeBaseStructure.TIM_Period = 24000;
  124.   TIM_TimeBaseStructure.TIM_Prescaler = 0;
  125.   TIM_TimeBaseStructure.TIM_ClockDivision = 0;
  126.   TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
  127.
  128.
  129.     /*NVIC_InitStructure.NVIC_IRQChannel =TIM8_CC_IRQn;
  130.   NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
  131.   NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
  132.   NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  133.       NVIC_Init(&NVIC_InitStructure);*/
  134. }
  135.
  136. /* Private functions ---------------------------------------------------------*/
  137.
  138. /**
  139.   * @brief  Main program.
  140.   * @param  None
  141.   * @retval None
  142.   */
  143.
  144. void delay_us(u32 n)
  145. {
  146.     u8 j;
  147.     while(n--)
  148.     for(j=0;j<10;j++);
  149. }
  150.
  151. void  delay_ms(u32 n)
  152. {
  153.     while(n--)
  154.     delay_us(1000);
  155. }
  156.
  157.
  158. int main(void)
  159. {
  160.   /*!< At this stage the microcontroller clock setting is already configured,
  161.        this is done through SystemInit() function which is called from startup
  162.        file (startup_stm32f10x_xx.s) before to branch to application main.
  163.        To reconfigure the default setting of SystemInit() function, refer to
  164.        system_stm32f10x.c file
  165.      */
  166.
  167.   /* System Clocks Configuration */
  168.
  169.   RCC_Configuration();
  170.
  171. NVIC_Configuration();
  172. USART_int(115200);
  173.     printf(" config done...\r\n");
  174.
  175.
  176.   TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);
  177.   TIM_ITConfig(TIM2,TIM_IT_Update,ENABLE );
  178.
  179.
  180.      TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure);
  181.   TIM_ITConfig(TIM3,TIM_IT_Update,ENABLE );
  182.
  183.      TIM_TimeBaseInit(TIM7, &TIM_TimeBaseStructure);
  184.   TIM_ITConfig(TIM7,TIM_IT_Update,ENABLE );
  185.
  186.
  187.
  188.   /* TIM2 enable counter */
  189.   TIM_Cmd(TIM2, ENABLE);
  190.      TIM_Cmd(TIM3, ENABLE);
  191.          TIM_Cmd(TIM7, ENABLE);
  192.
  193.   while (1){
  194.         if(flag == 2000)
  195.         {printf("TIM2 interrupt......\r\n");
  196.  GPIO_ResetBits(GPIOC,GPIO_Pin_1|GPIO_Pin_0);
  197.         delay_ms(150);
  198.         GPIO_ResetBits(GPIOC,GPIO_Pin_1|GPIO_Pin_0);
  199.           flag = 0;
  200.   }
  201.
  202.         if(temp == 3000)
  203.
  204.         {printf("TIM3 interrupt......\r\n");
  205.             GPIO_ResetBits(GPIOC,GPIO_Pin_6|GPIO_Pin_7);
  206.         delay_ms(150);
  207.         GPIO_ResetBits(GPIOC,GPIO_Pin_6|GPIO_Pin_7);
  208.          temp = 0;
  209.
  210.
  211.
  212.   }
  213.
  214. }
  215.
  216.
  217. }
  218. void TIM2_IRQHandler(void)
  219. {
  220. if (TIM_GetITStatus(TIM2, TIM_IT_Update) != RESET)
  221. {
  222. TIM_ClearITPendingBit(TIM2, TIM_IT_Update );
  223.     flag++;
  224.
  225. }
  226. }
  227. void TIM3_IRQHandler(void)
  228. {
  229. if (TIM_GetITStatus(TIM3, TIM_IT_Update) != RESET)
  230. {
  231. TIM_ClearITPendingBit(TIM3, TIM_IT_Update );
  232.     temp++;
  233.
  234. }
  235. #ifdef  USE_FULL_ASSERT
  236.
  237. /**
  238.   * @brief  Reports the name of the source file and the source line number
  239.   *         where the assert_param error has occurred.
  240.   * @param  file: pointer to the source file name
  241.   * @param  line: assert_param error line source number
  242.   * @retval None
  243.   */
  244. void assert_failed(uint8_t* file, uint32_t line)
  245. {
  246.   /* User can add his own implementation to report the file name and line number,
  247.      ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  248.
  249.   /* Infinite loop */
  250.   while (1)
  251.   {
  252.   }
  253. }
  254.
  255. #endif
  256.
  257. /**
  258.   * @}
  259.   */
  260.
  261. /**
  262.   * @}
  263.   */
  264.
  265. #ifdef __GNUC__
  266.   /* With GCC/RAISONANCE, small printf (option LD Linker->Libraries->Small printf
  267.      set to 'Yes') calls __io_putchar() */
  268.   #define PUTCHAR_PROTOTYPE int __io_putchar(int ch)
  269. #else
  270.   #define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f)
  271. #endif /* __GNUC__ */
  272.
  273.
  274.
  275. /**
  276.   * @brief  Retargets the C library printf function to the USART.
  277.   * @param  None
  278.   * @retval None
  279.   */
  280. PUTCHAR_PROTOTYPE
  281. {
  282.   /* Place your implementation of fputc here */
  283.   /* e.g. write a character to the USART */
  284.   USART_SendData(EVAL_COM1, (uint8_t) ch);
  285.
  286.   /* Loop until the end of transmission */
  287.   while (USART_GetFlagStatus(EVAL_COM1, USART_FLAG_TC) == RESET)
  288.   {}
  289.
  290.   return ch;
  291. }
  292.
  293. #ifdef  USE_FULL_ASSERT
  294.
  295. /**
  296.   * @brief  Reports the name of the source file and the source line number
  297.   *         where the assert_param error has occurred.
  298.   * @param  file: pointer to the source file name
  299.   * @param  line: assert_param error line source number
  300.   * @retval None
  301.   */
  302. void assert_failed(uint8_t* file, uint32_t line)
  303. {
  304.   /* User can add his own implementation to report the file name and line number,
  305.      ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  306.
  307.   /* Infinite loop */
  308.   while (1)
  309.   {
  310.   }
  311. }
  312.
  313. #endif
2014-12-25 23:13:59     打赏
  3. #include
  4. volatile int flag;
  5. #define Set_B20()    GPIO_SetBits(GPIOC, GPIO_Pin_12)//上拉关闭pc12
  6. #define Reset_B20()  GPIO_ResetBits(GPIOC, GPIO_Pin_12)//下拉打开pc12
  7. #define Read_B20()   GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_12)//读pc状态
  8. unsigned char Error_Flag=0;
  9. unsigned char zf=0;
  10. GPIO_InitTypeDef   GPIO_InitStructure;
  11. USART_InitTypeDef USART_InitStructure;
  12. USART_ClockInitTypeDef USART_ClockInitStructure;
  13. void delay_us(u32 n)
  14. {
  15.     u8 j;
  16.     while(n--)
  17.     for(j=0;j<10;j++);
  18. }
  19. void  delay_ms(u32 n)
  20. {
  21.     while(n--)
  22.     delay_us(1000);
  23. }
  24.
  25. void SysTick_Configuration(void)
  26. {
  27.   /* Setup SysTick Timer for 10 msec interrupts  */
  28.   if (SysTick_Config(48000))
  29.   {
  30.     /* Capture error */
  31.     while (1);
  32.   }
  33.  /* Configure the SysTick handler priority */
  34.   NVIC_SetPriority(SysTick_IRQn, 0x0);
  35. }
  36.
  37. void RCC_Configuration(void)
  38. {
  39.     RCC_DeInit();//将RCC寄存器重设为缺省值
  40.   RCC_HSICmd(ENABLE);//使能内部高速晶振
  41.   while(RCC_GetFlagStatus(RCC_FLAG_HSIRDY) == RESET);//HSI晶振返回reset
  42.   RCC_SYSCLKConfig(RCC_SYSCLKSource_HSI);//选择HSI作为系统时钟
  43.   RCC_HSEConfig(RCC_HSE_OFF);//HSE晶振关
  44.   RCC_LSEConfig(RCC_LSE_OFF);//LSE晶振关
  45.   RCC_PLLConfig(RCC_PLLSource_HSI_Div2,RCC_PLLMul_9); //  72HMz
  46.   RCC_PLLCmd(ENABLE);//使能PLL状态
  47.   while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET);
  48.   RCC_ADCCLKConfig(RCC_PCLK2_Div4);//ADC时钟=PCLK/4
  49.   RCC_PCLK2Config(RCC_HCLK_Div1);//APB2时钟=HCLK
  50.   RCC_PCLK1Config(RCC_HCLK_Div2);//APB1时钟=HCLK/2
  51.   RCC_HCLKConfig(RCC_SYSCLK_Div1);//AHB时钟=系统时钟
  52.   RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);//选择PLL作为系统时钟
  53.   while(RCC_GetSYSCLKSource() != 0x08);
  54.   RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD|RCC_APB2Periph_AFIO, ENABLE);
  55.   GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);//disable JTAG
  56.   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
  57.   GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  58.   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  59.   GPIO_Init(GPIOD, &GPIO_InitStructure);
  60.   GPIO_ResetBits(GPIOD,GPIO_Pin_2);//关闭蜂鸣器
  61.
  62.     RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC|RCC_APB2Periph_AFIO, ENABLE);
  63.   GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);//disable JTAG
  64.   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;
  65.   GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  66.   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  67.   GPIO_Init(GPIOC, &GPIO_InitStructure);
  68.     GPIO_SetBits(GPIOC,GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7);
  69.     RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);
  70. }
  71.
  73. {
  76.     GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  86.         - One Stop Bit
  87.         - No parity
  90.   */
  92.   USART_InitStructure.USART_BaudRate = BaudRate;
  93.   USART_InitStructure.USART_WordLength = USART_WordLength_8b;
  94.   USART_InitStructure.USART_StopBits = USART_StopBits_1;
  95.   USART_InitStructure.USART_Parity = USART_Parity_No;
  96.   USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
  97.   USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
  98.   USART_ClockInitStructure.USART_Clock = USART_Clock_Disable;
  99.   USART_ClockInitStructure.USART_CPOL = USART_CPOL_Low;
  100.   USART_ClockInitStructure.USART_CPHA = USART_CPHA_2Edge;
  101.   USART_ClockInitStructure.USART_LastBit = USART_LastBit_Disable;
  102.   USART_ClockInit(USART1, &USART_ClockInitStructure);
  103.   USART_Init(USART1, &USART_InitStructure);
  104.   USART_Cmd(USART1, ENABLE);
  105.   USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
  106.   USART_Cmd(USART1, ENABLE);
  107. }
  108.
  109. void delay_18b20(u32 nus)
  110. {
  111.     u16 i;
  112.     while(nus--)
  113.         for(i=12;i>0;i--);
  114. }
  115.
  116. void Init18B20(void)
  117. {
  118.   u8 aa=0;
  119.   u8 count =0;
  120.     RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);
  121.   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12;
  122.   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_OD;
  123.   GPIO_Init(GPIOC, &GPIO_InitStructure);
  124.   Set_B20() ;
  125.   delay_18b20(1);
  126.   Reset_B20();
  127.
  128.   delay_18b20(480);
  129.   Set_B20();
  130.   delay_18b20(480);
  131.     count=0;
  132.     aa=Read_B20();
  133.     while(!aa && count<100)
  134.    {
  135.     aa=Read_B20();
  136.     count++;
  137.    }
  138.    if(count>=99)
  139.         Error_Flag=1;
  140.     else
  141.         Error_Flag=0;
  142.
  143. }
  144.
  145. unsigned char Read18B20(void)
  146. {
  147. unsigned char i=0;
  148. unsigned char date=0;
  149. u8 tempp;
  150.    for(i=8;i>0;i--)
  151.    {
  152.    Reset_B20();
  153.    date>>=1;
  154.    delay_18b20(1);
  155.    Set_B20();
  156.    delay_18b20(1);
  157.    tempp=Read_B20();
  158.    if(tempp)
  159.    date|=0x80;
  160.      delay_18b20(60);
  161.     }
  162.     return(date);
  163. }
  164. void Write18B20(unsigned char date)
  165. {
  166.     unsigned char i=0;
  167.     for (i=8; i>0; i--)
  168.     {
  169.         Reset_B20();
  170.         delay_18b20(1);
  171.         if(date & 0x01)
  172.         {
  173.             Set_B20();
  174.         }
  175.         else
  176.         {   Reset_B20();}
  177.         delay_18b20(60);
  178.         date>>=1;
  179.         Set_B20();
  180.         delay_18b20(1);
  181.
  182.     }
  183.     delay_18b20(15);
  184. }
  185.
  186.  float Read_T()
  187. {
  188.     unsigned char TUp,TDown;
  189.     unsigned char fTemp;
  190.     u8 TT=0;
  191.
  192.     float Temp = 0;
  193.     Init18B20();
  194.     Write18B20(0xcc);
  195.     Write18B20(0x44);
  196.     Init18B20();
  197.     Write18B20(0xcc);
  198.     Write18B20(0xbe);
  199.     TDown = Read18B20();
  200.     TUp = Read18B20();
  201.
  202.     if(TUp>0x7f)
  203.     {
  204.         TDown=~TDown;
  205.         TUp=~TUp+1;
  206.         TUp/=8;
  207.         zf=1;
  208.     }
  209.     else
  210.         zf=0;
  211.
  212.     fTemp=TDown&0x0f;
  213.     TUp<<=4;
  214.     TDown>>=4;
  215.     TT=TUp|TDown;
  216.     Temp=TT+(float)fTemp/16;
  217.     return(Temp);
  218. }
  219.
  220. int main(void)
  221. {
  222.   char ID[8];
  223.   int i;
  224.   RCC_Configuration();
  225.   USART_int(115200);
  226.   SysTick_Configuration();
  227.   printf(" config done...\r\n");
  228.
  229.   delay_ms(1000);
  230.   Init18B20();
  231.   Write18B20(0x33);
  232.   delay_18b20(20);
  233.   for(i=0;i<8;i++)
  234. {
  235.     ID[i] = Read18B20();
  236. }
  237.   while(1)
  238.     {
  239.             if(flag == 300)
  240.         {
  241.           printf("At the moment of ID is:")   ;
  242.           for(i=0;i<8;i++)
  243.         {
  244.           printf("%u",ID[i]);
  245.         }
  246.           printf("\r\n")  ;
  247.         }
  248.         if(flag == 500)
  249.         {
  250.           printf("The Temperature is:%f\r\n",Read_T());
  251.           printf("===================================================\r\n");
  252.     }
  253.     }
  254. }
  255.
  256.
  257. #ifdef  USE_FULL_ASSERT
  258. void assert_failed(uint8_t* file, uint32_t line)
  259. {
  260.   while (1)
  261.   {
  262.   }
  263. }
  264.
  265. #endif
  266.
  267. #ifdef __GNUC__
  268.   /* With GCC/RAISONANCE, small printf (option LD Linker->Libraries->Small printf
  269.      set to 'Yes') calls __io_putchar() */
  270.   #define PUTCHAR_PROTOTYPE int __io_putchar(int ch)
  271. #else
  272.   #define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f)
  273. #endif /* __GNUC__ */
  274.
  275. PUTCHAR_PROTOTYPE
  276. {
  277.   /* Place your implementation of fputc here */
  278.   /* e.g. write a character to the USART */
  279.   USART_SendData(EVAL_COM1, (uint8_t) ch);
  280.
  281.   /* Loop until the end of transmission */
  282.   while (USART_GetFlagStatus(EVAL_COM1, USART_FLAG_TC) == RESET)
  283.   {}
  284.
  285.   return ch;
  286. }
  287.
  288. #ifdef  USE_FULL_ASSERT
  289. void assert_failed(uint8_t* file, uint32_t line)
  290. {
  291.   while (1)
  292.   {
  293.   }
  294. }
  295.
  296. #endif
2014-12-25 23:14:30     打赏
  1. #include "stm32f10x.h"
  2. #include "stm32_eval.h"
  3. #include
  4. #include "spi_flash.h"
  5. #define VREF 3.3
  6.
  8. {
  9.     u8 j;
  10.     while(n--)
  11.     for(j=0;j<10;j++);
  12. }
  13.
  14. void  delay_ms(u32 n)
  15. {
  16.     while(n--)
  17.     delay_us(1000);
  18. }
  19.
  20.
  21. #define TxBufferSize1   (countof(TxBuffer1) - 1)
  22. #define RxBufferSize1   (countof(TxBuffer1) - 1)
  23. #define countof(a)      (sizeof(a) / sizeof(*(a)))
  24. #define  BufferSize (countof(Tx_Buffer)-1)
  25. typedef enum { FAILED = 0, PASSED = !FAILED} TestStatus;
  26. #define  FLASH_WriteAddress     0x00000
  27. #define  FLASH_ReadAddress      FLASH_WriteAddress
  28. #define  FLASH_SectorToErase    FLASH_WriteAddress
  29. #define  sFLASH_ID              0xEF3015     //W25X16
  30. //#define  sFLASH_ID              0xEF4015   //W25Q16
  31. #define buff_size  16;
  32. char rx_buff[],rx_buff_count=0;
  33. /* ???????? */
  34. uint8_t Tx_Buffer[4096] ;
  35. uint8_t Rx_Buffer[BufferSize];
  36. __IO uint32_t DeviceID = 0;
  37. __IO uint32_t FlashID = 0;
  38. __IO TestStatus TransferStatus1 = FAILED;
  39.
  40. // ??????
  41. void Delay(__IO uint32_t nCount);
  42. TestStatus Buffercmp(uint8_t* pBuffer1, uint8_t* pBuffer2, uint16_t BufferLength);
  43.
  44. /** @addtogroup STM32F10x_StdPeriph_Examples
  45.   * @{
  46.   */
  47.
  48. /** @addtogroup EXTI_Config
  49.   * @{
  50.   */
  51.
  52. /* Private typedef -----------------------------------------------------------*/
  53. /* Private define ------------------------------------------------------------*/
  54. /* Private macro -------------------------------------------------------------*/
  55. /* Private variables ---------------------------------------------------------*/
  56. GPIO_InitTypeDef   GPIO_InitStructure;
  57. USART_InitTypeDef USART_InitStructure;
  58. USART_ClockInitTypeDef USART_ClockInitStructure;
  59.
  60. char *int_to_string(int number,char *strnum)//整形数据转换为字符型
  61. {
  62. int j=0,i=0,n=0;
  63. char temp;
  64. while(number>0)
  65. {
  66. *(strnum+j)=number%10+48;
  67. j++;
  68. number=number/10;
  69. n++;
  70. }
  71.
  72.
  73. for(i=0;iLibraries->Small printf
  74.      set to 'Yes') calls __io_putchar() */
  75.   #define PUTCHAR_PROTOTYPE int __io_putchar(int ch)
  76. #else
  77.   #define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f)
  78. #endif /* __GNUC__ */
  79.
  80.
  81.
  82. /**
  83.   * @brief  Retargets the C library printf function to the USART.
  84.   * @param  None
  85.   * @retval None
  86.   */
  87. PUTCHAR_PROTOTYPE
  88. {
  89.   /* Place your implementation of fputc here */
  90.   /* e.g. write a character to the USART */
  91.   USART_SendData(EVAL_COM1, (uint8_t) ch);
  92.
  93.   /* Loop until the end of transmission */
  94.   while (USART_GetFlagStatus(EVAL_COM1, USART_FLAG_TC) == RESET)
  95.   {}
  96.
  97.   return ch;
  98. }
  99.
  100. #ifdef  USE_FULL_ASSERT
  101.
  102. /**
  103.   * @brief  Reports the name of the source file and the source line number
  104.   *         where the assert_param error has occurred.
  105.   * @param  file: pointer to the source file name
  106.   * @param  line: assert_param error line source number
  107.   * @retval None
  108.   */
  109. void assert_failed(uint8_t* file, uint32_t line)
  110. {
  111.   /* User can add his own implementation to report the file name and line number,
  112.      ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  113.
  114.   /* Infinite loop */
  115.   while (1)
  116.   {
  117.   }
  118. }
  119.
  120. #endif
共11条 1/2 1 2 › 跳转至页
