3-5 1)顺序赋值语句:
LIBRARY IEEE;
USE IEEE.SID_LOGIC_1164.ALL;
USE IEEE.SID_LOGIC_UNSIGNED.ALL;
ENTITY(DIN:IN STD_LOGIC_VECTOR(2 DOWNTO 0);
DOUT:OUT BIT_VECTOR(7 DOWNTO 0));
END DECODER 3 TO 8;
ARCHICTURE BHV OF DECODER 3 TO 8 IS
BEGIN
WITH CONV_INTEGER(DIN)SELECT
DOUT<= “00000001” WHEN 0,
DOUT<= “00000010” WHEN 1,
DOUT<= “00000100” WHEN 2,
DOUT<= “00001000” WHEN 3,
DOUT<= “00010000” WHEN 4,
DOUT<= “00100000” WHEN 5,
DOUT<= “01000000” WHEN 6,
DOUT<= “10000000” WHEN 7;
UNAFFECTER WHEN OTHERS;
END BHV;
2)CASE语句:
LIBRARY IEEE;
END DECODER 3 TO 8;
BEGIN
PROCESS(DIN)
BEGIN
CASE CONV_INTEGER(DIN) IS
WHEN 0=> DOUT <= “00000001”;
WHEN 1=> DOUT <= “00000010”;
WHEN 2=> DOUT <= “00000100”;
WHEN 3=> DOUT <= “00001000”;
WHEN 4=> DOUT <= “00010000”;
WHEN 5=> DOUT <= “00100000”;
WHEN 6=> DOUT <= “01000000”;
WHEN 7=> DOUT <= “10000000”;
WHEN OTHERS => NULL;
END CASE;
END PROCESS;
END BHV;
3)if-else 语句:
LIBRARY IEEE;
END DECODER 3 TO 8;
BEGIN
PROCESS(DIN)
BEGIN
IF CONV_INTEGER(DIN)=0 THEN DOUT<= “00000001”;
ELSIF CONV_INTEGER(DIN)=1 THEN DOUT<= “00000010”;
ELSIF CONV_INTEGER(DIN)=2 THEN DOUT<= “00000100”;
ELSIF CONV_INTEGER(DIN)=3 THEN DOUT<= “00001000”;
ELSIF CONV_INTEGER(DIN)=4 THEN DOUT<= “00010000”;
ELSIF CONV_INTEGER(DIN)=5 THEN DOUT<= “00100000”;
ELSIF CONV_INTEGER(DIN)=6 THEN DOUT<= “01000000”;
ELSIF CONV_INTEGER(DIN)=7 THEN DOUT<= “10000000”;
END IF;
END PROCESS;
END BHV;
4)移位操作法:
LIBRARY IEEE;
END DECODER 3 TO 8;
BEGIN
DOUT<= “00000001”SLLCONV_INTEGER(DIN);
END BHV;
3-14七人表决器:
LRBRAR IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
ENTITY BJQ7 IS
PORT (INPUT: IN STD_LOGIC_VECTOR(6 DOWNTO 0;
OUTPUT:OUT STD_LOGIC_VECTOR(2 DOWNTO 0);
Y: OUT STD_LOGIC);
END BJQ7;
ARCHITECTURE BHV OF BJQ7 IS
BEGIN
PROCESS(INPUT)
VARIABLE Q : STD_LOGIC_VECTOR(2DOWNTO 0);
BEGIN
Q :=”000”;
FOR n in 0 TO 6 LOOP
IF (INPUT(n)=’1’) THEN Q:=Q+1;
END IF;
END LOOP;
OUTPUT<=Q;
IF (OUTPUT>=4) Y<=’1’ ELSE Y<=’0’;
END IF;
END PROCESS
END ARCHITECTURE BHV
 我要赚赏金 STM32
STM32 MCU
MCU 通讯及无线技术
通讯及无线技术 物联网技术
物联网技术 电子DIY
电子DIY 板卡试用
板卡试用 基础知识
基础知识 软件与操作系统
软件与操作系统 我爱生活
我爱生活 小e食堂
小e食堂
