(2) 掌握定时器的编程方法
(3) 掌握使用单片机控制蜂鸣器发出不同声音的思路
蜂鸣器一端连VCC,另一端接三极管NPN的集电极,而单片机的I/O接NPN的基极,这样当单片机输出高电平‘0’时,基极为地电平时,三极管导通,有电流从蜂鸣器流过,蜂鸣器发声。单片机控制蜂鸣器发出不同声音,即控制蜂鸣器发音的频率和控制蜂鸣器发音时间的长短。(图中的三极管是8550,它是PNP型的低点平导通。图中的符号是错误的)
4. 实验原理图
400)this.width=400;if(this.height>400)this.height=400" border=0>
;WWW.MCUBOOK.COM 为你搜集而来。欢迎浏览其他页。
5.实验源程序 ORG 0000H LJMP START ORG 000BH CLR P2.1 INC 20H ;中断服务,中断计数器加1 MOV TH0,#0D8H MOV TL0,#0EFH ;12M晶振,形成10毫秒中断 RETI START: MOV SP,#50H MOV TH0,#0D8H MOV TL0,#0EFH MOV TMOD,#01H MOV IE,#82H MUSIC0: NOP MOV DPTR,#DAT ;表头地址送DPTR MOV 20H,#00H ;中断计数器清0 MOV B,#00H ;表序号清0 MUSIC1: NOP CLR A MOVC A,@A+DPTR ;查表取代码 JZ END0 ;是00H,则结束 CJNE A,#0FFH,MUSIC5 LJMP MUSIC3 MUSIC5: NOP MOV R6,A INC DPTR MOV A,B MOVC A,@A+DPTR ;取节拍代码送R7 MOV R7,A SETB TR0 ;启动计数 MUSIC2: NOP CPL P1.1 MOV A,R6 MOV R3,A LCALL DEL MOV A,R7 CJNE A,20H,MUSIC2 ;中断计数器(20H)=R7否? ;不等,则继续循环 MOV 20H,#00H ;等于,则取下一代码 INC DPTR ; INC B LJMP MUSIC1 MUSIC3: NOP CLR TR0 ;休止100毫秒 MOV R2,#0DH MUSIC4: NOP MOV R3,#0FFH LCALL DEL DJNZ R2,MUSIC4 INC DPTR LJMP MUSIC1 END0: NOP MOV R2,#64H ;歌曲结束,延时1秒后继续 MUSIC6: MOV R3,#00H LCALL DEL DJNZ R2,MUSIC6 LJMP MUSIC0 DEL: NOP DEL3: MOV R4,#02H DEL4: NOP DJNZ R4,DEL4 NOP DJNZ R3,DEL3 RET NOP DAT: db 26h,20h,20h,20h,20h,20h,26h,10h,20h,10h,20h,80h,26h,20h,30h,20h db 30h,20h,39h,10h,30h,10h,30h,80h,26h,20h,20h,20h,20h,20h,1ch,20h db 20h,80h,2bh,20h,26h,20h,20h,20h,2bh,10h,26h,10h,2bh,80h,26h,20h db 30h,20h,30h,20h,39h,10h,26h,10h,26h,60h,40h,10h,39h,10h,26h,20h db 30h,20h,30h,20h,39h,10h,26h,10h,26h,80h,26h,20h,2bh,10h,2bh,10h db 2bh,20h,30h,10h,39h,10h,26h,10h,2bh,10h,2bh,20h,2bh,40h,40h,20h db 20h,10h,20h,10h,2bh,10h,26h,30h,30h,80h,18h,20h,18h,20h,26h,20h db 20h,20h,20h,40h,26h,20h,2bh,20h,30h,20h,30h,20h,1ch,20h,20h,20h db 20h,80h,1ch,20h,1ch,20h,1ch,20h,30h,20h,30h,60h,39h,10h,30h,10h db 20h,20h,2bh,10h,26h,10h,2bh,10h,26h,10h,26h,10h,2bh,10h,2bh,80h db 18h,20h,18h,20h,26h,20h,20h,20h,20h,60h,26h,10h,2bh,20h,30h,20h db 30h,20h,1ch,20h,20h,20h,20h,80h,26h,20h,30h,10h,30h,10h,30h,20h db 39h,20h,26h,10h,2bh,10h,2bh,20h,2bh,40h,40h,10h,40h,10h,20h,10h db 20h,10h,2bh,10h,26h,30h,30h,80h,00H END
