#include<reg52.h>
#include<intrins.h>
#define uchar unsigned char
#define uint unsigned int
sbit dula=P2^0;
sbit wela=P2^1;
sbit beep=P3^2;
uint num,num1,num2;
uchar code table[]={
0x3f,0x06,0x5b,0x4f,
0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,
0x39,0x5e,0x79,0x71};
void delayus(uint us)
while(us--);
void delay(uint z)
uint a,b;
for(a=0;a<z;z++)
for(b=0;b<110;b++);
void display(uint disnum)
uchar wan,qian,bai,shi,ge;
wan=disnum/10000;
qian=disnum%10000/1000;
bai=disnum%1000/100;
shi=disnum%100/10;
ge=disnum%10;
dula=1;
P0=table[wan];
dula=0;
P0=0xff;
wela=1;
P0=0xf7;
wela=0;
delayus(100);
dula=1;
P0=table[qian];
dula=0;
P0=0xff;
wela=1;
P0=0xef;
wela=0;
delayus(100);
dula=1;
P0=table[bai];
dula=0;
P0=0xff;
wela=1;
P0=0xdf;
wela=0;
delayus(100);
dula=1;
P0=table[shi];
dula=0;
P0=0xff;
wela=1;
P0=0xbf;
wela=0;
delayus(100);
dula=1;
P0=table[ge];
dula=0;
P0=0xff;
wela=1;
P0=0x7f;
wela=0;
delayus(100);
void main()
TH0=(65536-46080)/256;
TL0=(65536-46080)%256;
TMOD=0x01;
EA=1;
ET0=1;
TR0=1;
while(1)
if(num==20)
num=0;
num1++;
num2++;
if(num2==30)
beep=0;
delayus(2000);
beep=1;
num2=0;
if(num1==600)
num1=0;
display(num1);
void T0_timer() interrupt 1
num++;
