电子产品世界 » 论坛首页 » 高校专区 » 漓东e学堂 » RGB灯的渐变
RGB灯的渐变
2014-12-04 22:42:31     打赏
  • #include "stm32f10x.h"
  • #include "stm32_eval.h"
  • #include <stdio.h>
  • #define VREF 3.3
  • GPIO_InitTypeDef   GPIO_InitStructure;
  • USART_InitTypeDef USART_InitStructure;
  • USART_ClockInitTypeDef USART_ClockInitStructure;
  • void USART_int(long BaudRate)
  •     RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_USART1,ENABLE);
  •        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
  •     GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  •     GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  •     GPIO_Init(GPIOA, &GPIO_InitStructure);
  •     GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
  •     GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
  •   USART_InitStructure.USART_BaudRate = BaudRate;//??????
  •   USART_InitStructure.USART_WordLength = USART_WordLength_8b;//???????8bit
  •   USART_InitStructure.USART_StopBits = USART_StopBits_1;//????1
  •   USART_InitStructure.USART_Parity = USART_Parity_No;//????
  •   USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//??????none
  •   USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;//??????????
  •     USART_ClockInitStructure.USART_Clock = USART_Clock_Disable;
  •     USART_ClockInitStructure.USART_CPOL = USART_CPOL_Low;
  •     USART_ClockInitStructure.USART_CPHA = USART_CPHA_2Edge;
  •     USART_ClockInitStructure.USART_LastBit = USART_LastBit_Disable;
  •     USART_ClockInit(USART1, &USART_ClockInitStructure);
  •   USART_Init(USART1, &USART_InitStructure);
  •   USART_Cmd(USART1, ENABLE);
  •     USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
  • void PWM_Config()
  • {uint16_t PrescalerValue = 0;
  •     TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
  • TIM_OCInitTypeDef  TIM_OCInitStructure;
  •   RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);
  •   RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO  , ENABLE);
  •         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3;
  •         TIM_Cmd(TIM2, ENABLE);
  •   PrescalerValue = (uint16_t) (SystemCoreClock / 24000000) - 1;
  •   TIM_TimeBaseStructure.TIM_Period = 0x07FF;
  •   TIM_TimeBaseStructure.TIM_Prescaler = PrescalerValue;
  •   TIM_TimeBaseStructure.TIM_ClockDivision = 0;
  •   TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
  •   TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);
  •   TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
  •   TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
  •   TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
  •   TIM_OCInitStructure.TIM_Pulse = 0xFFFF;
  •   TIM_OC2Init(TIM2, &TIM_OCInitStructure);
  •   TIM_OC3Init(TIM2, &TIM_OCInitStructure);
  •   TIM_OC4Init(TIM2, &TIM_OCInitStructure);
  •   TIM_ARRPreloadConfig(TIM2, ENABLE);
  • void delay_us(u32 n)
  •     u8 j;
  •     while(n--)
  •     for(j=0;j<10;j++);
  • void  delay_ms(u32 n)
  •     while(n--)
  •     delay_us(1000);
  • void PWM_TEST()
  • { unsigned int temp0=0,temp1=0,temp2=0;
  •     printf("PWM-RGB TEST......\r\n");
  •     while(1)
  •         for(temp0=0;temp0<2047;temp0++)
  •         TIM_SetCompare2(TIM2, temp1);
  •             delay_us(1000);
  •     if (temp1>=2047)
  •         delay_ms(1000);
  •         temp0=0;
  •     for(temp1=1;temp1<2047;temp1++)
  •         TIM_SetCompare3(TIM2, temp0);
  •             delay_us(1000);
  •     if (temp0>=2047)
  •         delay_ms(1000);
  •         temp1=0;
  •         for(temp2=0;temp2<2047;temp2++)
  •         TIM_SetCompare4(TIM2, temp2);
  •             delay_us(1000);
  •     if (temp2>=2047)
  •         delay_ms(1000);
  •         temp2=0;
  •     for(temp0=0,temp1=0;temp0<2047||temp1<2047;temp0++,temp1++)
  •           TIM_SetCompare2(TIM2, temp0);
  •                 TIM_SetCompare3(TIM2, temp1);
  •             delay_us(1000);}
  •     if (temp0>=2047)
  •         delay_ms(1000);
  •         temp0=0;
  •     if (temp1>=2047)
  •         delay_ms(2000);
  •         temp1=0;
  •     for(temp0=0,temp2=0;temp0<2047||temp2<2047;temp0++,temp2++)
  •             delay_us(1000);}
  •     if (temp0>=2047)
  •         delay_ms(1000);
  •         temp0=0;
  •     if (temp2>=2047)
  •         delay_ms(1000);
  •         temp2=0;
  •     for(temp1=0,temp2=0;temp1<2047||temp2<2047;temp1++,temp2++)
  •             delay_us(1000);}
  •     if (temp1>=2047)
  •         delay_ms(1000);
  •         temp1=0;
  •     if (temp2>=2047)
  •         delay_ms(1000);
  •         temp2=0;
  •     for(temp0=0,temp1=0,temp2=0;temp0<2047||temp1<2047||temp2<2047;temp0++,temp1++,temp2++)
  •             delay_us(1000);}
  •             if (temp0>=2047)
  •         delay_ms(1000);
  •         temp0=0;
  •     if (temp1>=2047)
  •         delay_ms(1000);
  •         temp1=0;
  •     if (temp2>=2047)
  •         delay_ms(1000);
  •         temp2=0;
  • int main(void)
  •   RCC_Configuration();
  • USART_int(115200);
  •     printf(" config done...\r\n");
  •     PWM_Config();
  •     delay_ms(1000);
  •     while(1)
  •         PWM_TEST();
  • #ifdef  USE_FULL_ASSERT
  • void assert_failed(uint8_t* file, uint32_t line)
  •   while (1)
  • #ifdef __GNUC__
  •   /* With GCC/RAISONANCE, small printf (option LD Linker->Libraries->Small printf
  •      set to 'Yes') calls __io_putchar() */
  •   #define PUTCHAR_PROTOTYPE int __io_putchar(int ch)
  • #else
  •   #define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f)
  • #endif /* __GNUC__ */
  • PUTCHAR_PROTOTYPE
  •   USART_SendData(EVAL_COM1, (uint8_t) ch);
  •   while (USART_GetFlagStatus(EVAL_COM1, USART_FLAG_TC) == RESET)
  •   return ch;
  •   while (1)
  • 共1条 1/1 1 跳转至页
