电子产品世界 » 论坛首页 » DIY与开源设计 » 开源硬件 » 【跟二叔玩bananapi】之六:球猫师傅的SINAAPP
2014-12-22 22:37:04     打赏
球猫注册了一个sinaapp,二叔也学着做,
先看hello world
http://sae.sina.com.cn/doc/python/tutorial.html#hello-world
不过代码要用到svn给的例子用的linux,没办法,上BPI,
svn co https://svn.sinaapp.com/helloworld
说什么没装svn
-bash: svn: command not found
那么apt-get install svn
说什么没有svn
Reading package lists... Done
Building dependency tree
Reading state information... Done
E: Unable to locate package svn
没办法,问百度,原来要用
apt-get install subversion
然后执行
cd 2s2s
mdkir 1
cd 1
vi config.yaml
version: 1
vi index.wsgi
import sae
def app(environ, start_response):
    status = '200 OK'
    response_headers = [('Content-type', 'text/plain')]
    start_response(status, response_headers)
    return ['Hello, Uncle Li!']
application = sae.create_wsgi_app(app)
下一步就是上载了,学名叫部署
cd ..
svn add 1/
A         1
A         1/index.wsgi
A         1/config.yaml
svn ci -m "initialize project"
Adding         1
Adding         1/config.yaml
Adding         1/index.wsgi
Transmitting file data ..
Committed revision 1.
好啦,开始打开浏览器
哇靠,出来了,香蕉派素个好东东!
