条件赋值语句
LRBRAR IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
ENTITY YMQ3to8 IS
PORT ( DIN: IN STD_LOGIC_VETOR(2 DOWNTO 0;
DOUT : OUT BIT_VECTOR(7 DOWNTO 0);
END YMQ38;
ARCHITECTURE BHV OF YMQ38 IS
BEGIN
PROCESS(DIN)
BEGIN
WITH CONV_TNTEGER(DIN) SECLET
DOUT<=”00000001”WHEN 0,
”00000010”WHEN 1,
”00000100”WHEN2,
”00001000”WHEN3,
”00010000”WHEN4,
”00100000”WHEN5,
”01000000”WHEN6
”10000000”WHEN 7,
NAFFECTED WHEN OTHERS;
END BHV
IF_ELSE语句
LRBRAR IEEE;
ENTITY YMQ3to8 IS
END YMQ38;
BEGIN
IF CON_INTEGER(DIN)=0 THEN DOUT<=”00000001”;
ELSIF CON_INTEGER(DIN)=1 THEN DOUT<=”00000010”
ELSIF CON_INTEGER(DIN)=2 THEN DOUT<=”00000100”
ELSIF CON_INTEGER(DIN)=3 THEN DOUT<=”00001000”
ELSIF CON_INTEGER(DIN)=4 THEN DOUT<=”00010000”
ELSIF CON_INTEGER(DIN)=5 THEN DOUT<=”00100000”
ELSIF CON_INTEGER(DIN)=6 THEN DOUT<=”01000000”
ELSIF CON_INTEGER(DIN)=7THEN DOUT<=”10000000”
END IF;
END PROCESS;
END BHV
CASE语句
LRBRAR IEEE;
ENTITY YMQ3to8 IS
END YMQ38;
BEGIN
PROCESS(DIN)
BEGIN
CASE CONV_TNTEGER(DIN) IS
WHEN 0=>DOUT<=”00000001”;
WHEN 1=>DOUT<=”00000010”;
WHEN2=>DOUT<=”00000100”;
WHEN 3=>DOUT<=”00001000”;
WHEN 4=>DOUT<=”00010000”;
WHEN 5=>DOUT<=”00100000”;
WHEN 6=>DOUT<=”01000000”;
WHEN 7=>DOUT<=”10000000”;
WHEN OTHERS =>NULL
END CASE;
移位操作
LRBRAR IEEE;
ENTITY YMQ3to8 IS
END YMQ38;
BEGIN
DOUT<=”00000001” SLL CONV_INTEGR(DIN);
END BHV
条件赋值语句
LRBRAR IEEE;
ENTITY YMQ3to8 IS
END YMQ38;
BEGIN
PROCESS(DIN)
BEGIN
”00000010”WHEN 1,
”00000100”WHEN2,
”00001000”WHEN3,
”00010000”WHEN4,
”00100000”WHEN5,
”01000000”WHEN6
”10000000”WHEN 7,
END BHV
IF_ELSE语句
LRBRAR IEEE;
ENTITY YMQ3to8 IS
END YMQ38;
BEGIN
END IF;
END PROCESS;
END BHV
LRBRAR IEEE;
ENTITY BJQ7 IS
PORT (INPUT: IN STD_LOGIC_VECTOR(6 DOWNTO 0;
OUTPUT: OUT STD_LOGIC_VECTOR(2 DOWNTO 0);
Y: OUT STD_LOGIC;
END BJQ7;
ARCHITECTURE BHV OF BJQ7 IS
BEGIN
PROCESS(INPUT)
VARIABLE Q : STD_LOGIC_VECTOR(2DOWNTO 0);
BEGIN
Q :=”000”;
FOR n in 0 TO 6 LOOP
IF (INPUT(n)=’1’) THEN Q:=Q+1;
END IF;
END LOOP;
OUTPUT<=Q;
IF (OUTPUT>=4) Y<=’1’ ELSE Y<=’0’;
END IF;
END PROCESS
 我要赚赏金 STM32
STM32 MCU
MCU 通讯及无线技术
通讯及无线技术 物联网技术
物联网技术 电子DIY
电子DIY 板卡试用
板卡试用 基础知识
基础知识 软件与操作系统
软件与操作系统 我爱生活
我爱生活 小e食堂
小e食堂
