电子产品世界 » 论坛首页 » 企业专区 » Mouser » 面向 Kintex-7 和 Virtex-7 FPGA GTX 量产芯片 CDR
面向 Kintex-7 和 Virtex-7 FPGA GTX 量产芯片 CDR 属性更新的设计咨询
2015-01-28 14:34:49     打赏
解决方案
本表格提供了在使用 LPM 均衡模式下面向 GTX 量产芯片中基于非加密 8B/10B 编码协议的优化型 CDR 属性值。
属性
值
RX_DEBUG_CFG
12'h000
全速: 线速<= 6.6Gbps (RXOUT_DIV=1)
RXCDR_CFG CDR setting < +/- 200 ppm 72'h03_0000_23FF_1040_0020
CDR setting < +/- 700 ppm 72'h03_8000_23FF_1040_0020
CDR setting < +/- 1250 ppm72'h03_8000_23FF_1040_0020
  半速: 线速 1.6 - 6.25Gbps (RXOUT_DIV=2)
RXCDR_CFG CDR setting < +/- 200 ppm 72'h03_0000_23FF_1020_0020
CDR setting < +/- 700 ppm 72'h03_8000_23FF_1020_0020
CDR setting < +/- 1250 ppm72'h03_8000_23FF_1020_0020
  1/4 速: 线速 0.8 - 3.125Gbps (RXOUT_DIV=4)
RXCDR_CFG CDR setting < +/- 200 ppm 72'h03_0000_23FF_1010_0020
CDR setting < +/- 700 ppm 72'h03_8000_23FF_1010_0020
CDR setting < +/- 1250 ppm72'h03_8000_23FF_1010_0020
  1/8 速: 线速 0.5 - 1.5625Gbps (RXOUT_DIV=8)
RXCDR_CFG
CDR setting < +/- 200 ppm 72'h03_0000_23FF_1008_0020
CDR setting < +/- 700 ppm 72'h03_8000_23FF_1008_0020
CDR setting < +/- 1250 ppm 72'h03_8000_23FF_1008
适用于
器件
Kintex-7
Virtex-7
