开发板资料下载
飞思卡尔FRDM-KL02Z是一款超低成本开发平台,由基于ARM®Cortex™-M0+处理器构建的Kinetis L系列KL02系列器件组成。
该硬件的特性包括飞思卡尔开放标准串行调试适配器(OpenSDA),可轻松访问MCU I/O,配备电池,低功率运行,采用可搭配扩展板的标准规格,以及用于闪存编程和运行控制的内置调试接口。FRDM-KL02Z受到众多飞思卡尔和第三方开发软件的支持。
产品应用领域: 可穿戴设备,小家电,满足低功耗需求。
描述:
The FRDM-KL02_MiniDock is a microcontroller development board based on the Freescale Freedom platform
Featuring the following:
- Kinetis L Series KL02 family MCU in an 32QFN package
- I/O headers for easy access to MCU I/O pins
- Freescale 3-axis accelerometer sensor, MMA8451Q
- Capacitive touch slider using GPIO method based on TSS lib
- Reset pushbutton
- RGB LED
- On-board serial and debug adapter (OpenSDA)
本资料转自http://www.cecport.com/activity/freescale-sale.shtml
