电子产品世界 » 论坛首页 » DIY与开源设计 » 电子DIY » 刷配列
共15条 1/2 1 2 › 跳转至页
刷配列
2016-12-11 18:54:21     打赏
有一个神奇的网站
http://www.keyboard-layout-editor.com/
我选择的近似的keycool84
好消息,可以用羞弟帮大家做好的配列,不同的在基础上进行小改
http://www.keyboard-layout-editor.com/#/gists/59b6b11f355227b1bb4d457c52bfc73f
2016-12-11 18:55:46     打赏
需要的资料,已更新为XD配列资料
Raw data
["Esc","F1","F2","F3","F4","F5","F6","F7","F8","F9","F10","F11","F12","ScrLk","Fn4","Delete"],
["~\n`","!\n1","@\n2","#\n3","$\n4","%\n5","^\n6","&\n7","*\n8","(\n9",")\n0","_\n-","+\n=",{w:2},"Backspace","Home"],
[{w:1.5},"Tab","Q","W","E","R","T","Y","U","I","O","P","{\n[","}\n]",{w:1.5},"|\n\\","Page Up"],
[{w:1.75},"Caps Lock","A","S","D","F","G","H","J","K","L",":\n;","\"\n'",{w:2.25},"Enter","Page Down"],
[{w:2.25},"Shift","Z","X\n\n\n\nScrLk","C\n\n\n\nFn2","V\n\n\n\nFn1","B\n\n\n\nFn3","N","M","\n.","?\n/",{w:1.75},"RShift","↑\n\n\n\nFn3","End\n\n\n\nFn1"],
[{w:1.25},"Ctrl",{w:1.25},"Win",{w:1.25},"Alt",{w:6.25},"Space","RAlt","Fn0","RCtrl","←\n\n\n\nFn5","↓\n\n\n\nFn2","→\n\n\n\nFn6"]
2016-12-11 18:59:24     打赏
打开另一个神奇的网站
https://kai.tkg.io/   (也有一说是https://tkg.io/还有别的,傻傻分不清)
通常->键盘->设定->选择XD84
2016-12-11 19:05:51     打赏
然后选择层->层模式->简单(这里要选简单,详见后边的Fn定义)贴入刚才的Raw data,
羞弟下面是黄色的,说是有冲突,不懂,先不管,先刷了看吧
Fn定义怎么来的,直接右上角:工具->导入即可
"0":["ACTION_LAYER_MOMENTARY",1],"1":["ACTION_BACKLIGHT_TOGGLE"],"2":["ACTION_BACKLIGHT_DECREASE"],"3":["ACTION_BACKLIGHT_INCREASE"],"4":["ACTION_FUNCTION",3,0],"5":["ACTION_FUNCTION",1,0],"6":["ACTION_FUNCTION",2,0]
2017/6/4新版
"0":["ACTION_LAYER_MOMENTARY",1],"1":["ACTION_BACKLIGHT_TOGGLE"],"2":["ACTION_BACKLIGHT_DECREASE"],"3":["ACTION_BACKLIGHT_INCREASE"],"4":["ACTION_FUNCTION",0,3],"5":["ACTION_FUNCTION",0,1],"6":["ACTION_FUNCTION",0,2],"7":["ACTION_NO"],"8":["ACTION_NO"],"9":["ACTION_NO"]
2016-12-11 19:05:59     打赏
下载前要先复位一下键盘,然后就可以下载了,
复位有两种方式,吊丝用镊子,土豪用磁铁.
一会儿就搞定了。记得固件要选自定义,用活动群里的临时固件,否则会出现楼下的情况
2016-12-11 19:06:04     打赏
又一个神奇的网站,大家大多用国外的,不记得地址了,找了一个国内的
http://keyboard.51240.com/en__keyboard/
以下选择了自定义固件就不会出现了
测了2、5、6行,第二行问题不大,第五行错位了,第六行就不忍直视了
2016-12-11 19:06:09     打赏
这层楼可以不看了,继续就可以了
误解,求助羞弟,得到了羞弟神奇的配列和一段程序
kimera_core_20161107_1_rgb_on_led4.hex
终于变成了绿色
2016-12-11 19:06:14     打赏
果真差不多了
2016-12-11 19:06:20     打赏
楼上刷固件前操作
还不会定义Fn,羞弟又给了一个宝贝,直接工具->导入即可
2016-12-11 19:06:26     打赏
选择多合一是一个错误,切忌
只显示F0和F4是不是网站的bug?还是有什么讲究?
共15条 1/2 1 2 › 跳转至页
