电子产品世界 » 论坛首页 » 嵌入式开发 » STM32 » interleaving-string
interleaving-string
2018-01-14 14:09:05     打赏
Given s1, s2, s3, find whether s3 is formed by the interleaving of s1 and s2.
For example,
Given:
s1 ="aabcc",
s2 ="dbbca",
When s3 ="aadbbcbcac", return true.
When s3 ="aadbbbaccc", return false.
题意:s1和s2是否能构成s3
思路:动态规划问题dp[i][j]表示S1前i个字符与S2前j个字符是否构成S3前i+j字符;[cpp] view plain copy
  1. class Solution
  2. {
  3. public:
  4.     bool isInterleve(string s1, string s2, string s3)
  5.     {
  6.         int rows = s1.length();
  7.         int cols = s2.length();
  8.         int lens = s3.length();
  9.
  10.         if ((rows+cols)!=lens)
  11.         {
  12.             return false;
  13.         }
  14.         if (rows==0 || cols==0)
  15.         {
  16.             if ((rows==0 && s2!=s3)
  17.                 || (cols==0 && s1!=s3))
  18.             {
  19.                 return false;
  20.             }
  21.         }
  22.
  23.         vector<vector<int>> dp(rows+1, vector<int>(cols+1, false));
  24.         dp[0][0] = true;
  25.
  26.        //初始化操作
  27.         for (int i=1; i<=rows; i++)
  28.         {
  29.             dp[i][0] = dp[i - 1][0] && (s1[i-1]==s3[i-1]);
  30.         }
  31.
  32.         for (int i = 1; i <= cols; i++)
  33.         {
  34.             dp[0][i] = dp[0][i] && (s2[i - 1] == s3[i - 1]);
  35.         }
  36.
  37.         for (int i=1; i<=rows; i++)
  38.         {
  39.             for (int j=1; j<=cols; j++)
  40.             {
  41.                 //要满足条件,则s3的最后一个要么是s1的最后一个字符
  42.                 //要么是s2的最后一个字符
  43.                 if (s3[i + j - 1] == s1[i - 1] && dp[i - 1][j])
  44.                 {
  45.                     dp[i][j] = true;
  46.                 }
  47.                 else if (s3[i + j - 1] == s2[j - 1] && dp[i][j - 1])
  48.                 {
  49.                     dp[i][j] = true;
  50.                 }
  51.                 else
  52.                     dp[i][j] = false;
  53.             }
  54.         }
  55.
  56.             return dp[rows][cols];
  57.     }
  58. };
