电子产品世界 » 论坛首页 » 嵌入式开发 » STM32 » binary-tree-level-order-traversal
2018-01-18 20:26:09     打赏
Given a binary tree, check whether it is a mirror of itself (ie, symmetric around its center).
For example, this binary tree is symmetric:
    1
  2   2
3  4 4  3
But the following is not:
    1
  2   2
   3    3
Note:
Bonus points if you could solve it both recursively and iteratively.
confused what"{1,#,2,3}"means? > read more on how binary tree is serialized on OJ.
OJ's Binary Tree Serialization:
The serialization of a binary tree follows a level order traversal, where '#' signifies a path terminator where no node exists below.
Here's an example:
   1
 2   3
   4
     5
The above binary tree is serialized as"{1,2,3,#,#,4,#,#,5}".
题意:判断二叉树是否是镜像二叉树[cpp] view plain copy
  1. class Solution {
  2. public:
  3.     bool isSymmetirc(TreeNode* root)
  4.     {
  5.         if (root == NULL)
  6.         {
  7.             return true;
  8.         }
  9.
  10.         return check(root->left, root->right);
  11.     }
  12.
  13.     bool check(TreeNode* leftNode, TreeNode* rightNode)
  14.     {
  15.         if (leftNode==NULL && rightNode==NULL)
  16.         {
  17.             return true;
  18.         }
  19.
  20.         if ((leftNode!=NULL && rightNode==NULL)
  21.             || (leftNode==NULL && rightNode!=NULL))
  22.         {
  23.             return false;
  24.         }
  25.
  26.         if (leftNode->val!=rightNode->val)
  27.         {
  28.             return false;
  29.         }
  30.
  31.         return check(leftNode->left, rightNode->right) && check(leftNode->right, rightNode->left);
  32.     }
  33. };
