电子产品世界 » 论坛首页 » 嵌入式开发 » STM32 » binary-tree-zigzag-level-order-traversal
2018-01-19 17:52:07     打赏
Given a binary tree, return the zigzag level order traversal of its nodes' values. (ie, from left to right, then right to left for the next level and alternate between).
For example:
Given binary tree{3,9,20,#,#,15,7},
    3
  9  20
   15   7
return its zigzag level order traversal as:
  [3],
  [20,9],
  [15,7]
confused what"{1,#,2,3}"means? > read more on how binary tree is serialized on OJ.
OJ's Binary Tree Serialization:
The serialization of a binary tree follows a level order traversal, where '#' signifies a path terminator where no node exists below.
Here's an example:
   1
 2   3
   4
     5
The above binary tree is serialized as"{1,2,3,#,#,4,#,#,5}".题意:Z字形打印二叉树思路:层次遍历二叉树。对于偶数层在进行逆转就行;[cpp] view plain copy
  1. class Solution {
  2. public:
  3.     vector<vector<int>> zigzagLevelOrder(TreeNode* root)
  4.     {
  5.         vector<vector<int>> res;
  6.         if (root==NULL)
  7.         {
  8.             return res;
  9.         }
  10.
  11.         queue<TreeNode*> q;
  12.         q.push(root);
  13.
  14.         while (q.size())
  15.         {
  16.             vector<int> level;
  17.             for (int i=0, n=q.size(); i<n; i++)
  18.             {
  19.                 TreeNode* tmp = q.front();
  20.                 q.pop();
  21.
  22.                 level.push_back(tmp);
  23.                 if (tmp->left)
  24.                 {
  25.                     q.push(tmp->left);
  26.                 }
  27.                 if (tmp->right)
  28.                 {
  29.                     q.push(tmp->right);
  30.                 }
  31.             }
  32.             res.push_back(level);
  33.         }
  34.
  35.         for (int i=0; i<res.size(); i++)
  36.         {
  37.             if ((i+1)%2==0)
  38.             {
  39.                 reverse(res[i].begin(), res[i].end());
  40.             }
  41.         }
  42.
  43.         return res;
  44.     }
  45. };
