电子产品世界 » 论坛首页 » 嵌入式开发 » STM32 » construct-binary-tree-from-preorder-and-
construct-binary-tree-from-preorder-and-inorder-traversal
2018-01-20 10:00:29     打赏
Given preorder and inorder traversal of a tree, construct the binary tree.
Note:
You may assume that duplicates do not exist in the tree.
前序和中序重构二叉树;
这里用dfs的思想:
[cpp] view plain copy
  1. class Solution {
  2. public:
  3.     TreeNode *dfs(vector<int> &preorder,int preStart,int preEnd,vector<int> &inorder,int inStart,int inEnd)
  4.     {
  5.         if(preStart > preEnd)
  6.             return NULL;
  7.         TreeNode *root = new TreeNode(preorder[preStart]);
  8.         int middle;
  9.         for(middle=inStart;middle<=inEnd;middle++)
  10.             if(inorder[middle] == root->val)
  11.                 break;
  12.         int leftLen = middle-inStart;
  13.         root->left = dfs(preorder,preStart+1,preStart+leftLen,inorder,inStart,middle-1);
  14.         root->right = dfs(preorder,preStart+leftLen+1,preEnd,inorder,middle+1,inEnd);
  15.         return root;
  16.     }
  17.
  18.     TreeNode *buildTree(vector<int> &preorder, vector<int> &inorder)
  19.     {
  20.         int pre = preorder.size(),in = inorder.size();
  21.         if(pre==0 || in==0 || pre != in)
  22.             return NULL;
  23.         return dfs(preorder,0,pre-1,inorder,0,in-1);
  24.     }
  25. };
Note:
前序和中序重构二叉树;
这里用dfs的思想:
  1. class Solution {
  2. public:
  4.     {
  6.             return NULL;
  8.         int middle;
  11.                 break;
  15.         return root;
  16.     }
  17.
  19.     {
  22.             return NULL;
  24.     }
  25. };
