电子产品世界 » 论坛首页 » 嵌入式开发 » STM32 » 动态扫描
动态扫描
2018-04-17 12:36:15     打赏
用动态扫描和定时器1在数码管上显示出从765432开始以1/10秒的速度往下递减 直至765398并保持此数,与此同时利用定时器0以500MS速度进行流水灯从上至下移动 ,当数码管上数减到停止时,实验板上流水灯出停止然后全部开始闪烁,3秒后(用 T0定时)流水灯全部关闭,数码管上显示出“HELLO”,到此保持住复制代码
#include <reg52.h>
#include <intrins.h>
#define uchar unsigned char
#define uint unsigned int
/**tatle_du数组数据为0,1,2,3,4,5,6,7,8,9,A,B,C,D,E,F,H,L**/
uchar code tatle_du[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,
0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71,
0x76,0x79,0x38,0};
uchar code tatle_we[]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf};
sbit dula=P2^6;
sbit wela=P2^7;
uchar tt,t0,numwe,numdu,temp,bai,shi,ge,flag,flag1;
uint shu;
void display(uchar aa,uchar bb,uchar cc,uchar bai,uchar shi,uchar ge);
void delay(uchar z);
void inter_init();
void main()
    inter_init();
    while(1)
        if(flag1 != 1)
            display(7,6,5,bai,shi,ge);
        else
             display(16,17,18,18,0,19);
/*定时器0流水灯与闪烁*/
void inter0() interrupt 1
    TH0=(65536-50000)/256;
    TL0=(65536-50000)%256;
    tt++;
    /*如果减数不到398,流水灯与减数同时运行,如果到了398开启闪烁*/
    if(flag != 1)
    /*流水灯*/
        if(tt==10)
            tt=0;
            delay(5);
            temp=_crol_(temp,1);
            P1=temp;
    else
    /*使灯闪烁4秒*/
         if(tt%4==0)
             P1=~P1;
         if(tt==80)
            TR0=0;
            P1=0xff;
            flag1=1;
/*定时器1数码管显示*/
void inter1() interrupt 3
    TH1=(65536-50000)/256;
    TL1=(65536-50000)%256;
    t0++;
    if(t0==2)
        t0=0;
        shu--;
        bai=shu/100;
        shi=shu%100/10;
        ge=shu%10;
        if(shu==398)
            TR0=0;    //关闭定时器0,关闭流水灯
            P1=0xff;
            tt=0;
            TR0=1;    //开启定时器0,并填充数据。使灯闪烁
            flag=1;
            TR1=0;    //关闭定时器1保持数据显示
void delay(uchar z)
    uchar x,y;
    for(x=z;x>0;x--)
        for(y=110;y>0;y--);
void inter_init()
    tt=0;
    t0=0;
    flag=0;
    flag1=0;
    shu=432;
    temp=0xfe;
    P1=temp;
    TMOD=0x11;
    EA=1;
    ET0=1;
    ET1=1;
    TR0=1;
    TR1=1;
    dula=1;
    P0=tatle_du[aa];
    dula=0;
    P0=0xff;
    wela=1;
    P0=0xfe;
    wela=0;
    delay(5);
    dula=1;
    P0=tatle_du[bb];
    dula=0;
    P0=0xff;
    wela=1;
    P0=0xfd;
    wela=0;
    delay(5);
    dula=1;
    P0=tatle_du[cc];
    dula=0;
    P0=0xff;
    wela=1;
    P0=0xfb;
    wela=0;
    delay(5);
    dula=1;
    P0=tatle_du[bai];
    dula=0;
    P0=0xff;
    wela=1;
    P0=0xf7;
    wela=0;
    delay(5);
    dula=1;
    P0=tatle_du[shi];
    dula=0;
    P0=0xff;
    wela=1;
    P0=0xef;
    wela=0;
    delay(5);
    dula=1;
    P0=tatle_du[ge];
    dula=0;
    P0=0xff;
    wela=1;
    P0=0xdf;
    wela=0;
    delay(5);
复制代码
