| Step 1 修改build.sh vim /root/work/sinlinx/a33/lichee/buildroot/target/sinlinx_board/build.sh 添加下面红色字体修改保存 27 if [ $SINLINX_LCD = "lcd800x480" ]; then 28 sed -i "/export QWS_SIZE/c export QWS_SIZE=800x480" rootfs/etc/profile 29 elif [ $SINLINX_LCD = "lcd1024x600" ]; then 30 sed -i "/export QWS_SIZE/c export QWS_SIZE=1024x600" rootfs/etc/profile 31 else 32 sed -i "/export QWS_SIZE/c export QWS_SIZE=1280x720" rootfs/etc/profile Step 2 修改sinlinx_config.sh vim /root/work/sinlinx/a33/lichee/sinlinx_config.sh 添加下面红色字体修改保存 27 lcds=( 28 "lcd1280x720" 29 "lcd1024x600" 30 "lcd800x480" 31 ) Step 3 复制lcd1280x720.fex文件到/root/work/sinlinx/a33/lichee/sinlinx_config Step 4 重新配置编译镜像文件 ./sinlinx_config.sh ./build.sh ./build.sh pack Step 5 烧写镜像,连接1280x720显示器完美适配 |
共1条
SinA332.0开发板Linux&Qt调整VGA分辨率为1280x720
共1条
| 为遥控小车巧添功能被打赏¥26元 | |
