1 驱动源文件
2 Makefile
3 应用测试
#include <linux/module.h>
#include <linux/init.h>
#include <linux/types.h>
#include <linux/fs.h>
#include <linux/mm.h>
#include <linux/cdev.h>
#include <linux/errno.h>
#include <linux/sched.h>
#include <linux/io.h>
#include <asm/system.h>
#include <asm/uaccess.h>
#define sddev_MAJOR 200
static unsigned char dev_inc = 0;
static char devbuffer[256];
int dev_open(struct inode *inode,struct file *filp)
if(dev_inc > 0)
return -ERESTARTSYS;
dev_inc++;
return 0;
int dev_release(struct inode *inode,struct file *filp)
dev_inc--;
return 0;
ssize_t dev_read(struct file *filp,char __user *buf,size_t count,loff_t *f_pos)
if(copy_to_user(buf,devbuffer,count))
count = -EFAULT;
return count;
ssize_t dev_write(struct file *file,const char __user *buf,size_t count,loff_t *f_pos)
if(copy_from_user(devbuffer + *f_pos, buf, count))
count = -EFAULT;
return count;
void dev_exit_module(void)
unregister_chrdev(sddev_MAJOR,"sddev");
printk("dev_exit_module!\n");
static const struct file_operations dev_fops={
.owner = THIS_MODULE,
.open = dev_open,
.write = dev_write,
.read = dev_read,
.release = dev_release,
int dev_init_module(void)
int ret;
ret = register_chrdev(sddev_MAJOR,"sddev",&dev_fops);
if(ret < 0)
printk("Unable to register sddev device driver!\n");
return ret;
return 0;
module_init(dev_init_module);
module_exit(dev_exit_module);
MODULE_LICENSE("Dual BSD/GPL");
2
ifneq ($(KERNELRELEASE),)
obj-m := sddev.o
else
KERNELDIR ?= /lib/modules/$(shell uname -r)/build
PWD := $(shell pwd)
all:
make -C $(KERNELDIR) M=$(PWD) modules
clean:
rm -f *.ko *.o *.mod.c *.symvers
endif
3
#include <stdio.h>
#include <fcntl.h>
int main(void)
int fd;
int i;
char data[256];
int retval;
fd = open("/dev/sddev",O_RDWR);
if(fd == -1)
printf("error open\n");
exit(-1);
printf("open /dev/sddev OK!\n");
retval = write(fd, "safwwwwwweeeeeee",16);
if(retval == -1)
printf("write error\n");
exit(-1);
retval = read(fd, data,16);
if(retval == -1)
printf("read error!\n");
exit(-1);
data[retval]=0;
printf("read OK! %s\n",data);
close(fd);
return 0;
