电子产品世界 » 论坛首页 » 高校专区 » 坤创E-Geek/天科大新电社 » 求助! 独立按键显示1-4 出现了问题,
2019-01-29 09:58:48     打赏
#include<reg52.h>
#define uchar unsigned char
#define uint unsigned int
sbit key1=P3^0;
sbit key2=P3^1;
sbit key3=P3^2;
sbit key4=P3^3;
sbit PH595SRCLK=P2^6;
sbit PH595RCLK=P2^5;
sbit PH595SER=P2^7;
uchar code smgwei[]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};
uchar code smgduan[]={0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F,0x77,0x7C,0x39,0x5E,0x79,0x71,0x76,0x00};
void anjian1();
void anjian2();
void anjian3();
void anjian4();
void DelayMs(uint n)
 uchar j;
 while(n--)
  for(j=0;j<113;j++);
void send595(uchar dat)
 if(dat&0x80)
  PH595SER=1;
 else
  PH595SER=0;
 PH595SRCLK=0;
 PH595SRCLK=1;
 PH595SRCLK=0;
 dat=dat<<1;
void smgqingling()
     send595(0x00);
   send595(0x00);
   PH595RCLK=0;
   PH595RCLK=1;
void keyscan()
 if(key1==0)
  DelayMs(10);
  if(key1==0)
    anjian1();
  while(!key1);
 else if(key2==0)
  DelayMs(10);
  if(key2==0)
    anjian2();
  while(!key2);
 else if(key3==0)
  DelayMs(10);
  if(key3==0)
    anjian3();
  while(!key3);
 else if(key4==0)
  DelayMs(10);
  if(key4==0)
    anjian4();
  while(!key4);
void anjian1()
 send595(smgwei[0]);
 send595(smgduan[1]);
 PH595RCLK=0;
 PH595RCLK=1;
void anjian2()
 send595(smgwei[1]);
 send595(smgduan[2]);
 PH595RCLK=0;
 PH595RCLK=1;
void anjian3()
 send595(smgwei[2]);
 send595(smgduan[3]);
 PH595RCLK=0;
 PH595RCLK=1;
void anjian4()
 send595(smgwei[3]);
 send595(smgduan[4]);
 PH595RCLK=0;
 PH595RCLK=1;
void main()
 while(1)
  smgqingling();
  keyscan();
用小红版做这个独立按键显示1-4  自我感觉没有什么差错,但是在板子上显示不出来,请求各位大神看一下是哪里出现了问题,谢谢!
