电子产品世界 » 论坛首页 » 嵌入式开发 » FPGA » FPGA实现二进制转BCD码
FPGA实现二进制转BCD码
2019-07-20 09:16:42     打赏
Verilog代码:
  1. module Binary_to_BCD
  2.   #(parameter INPUT_WIDTH,
  3.     parameter DECIMAL_DIGITS)
  4.   (
  5.    input                         i_Clock,
  6.    input [INPUT_WIDTH-1:0]       i_Binary,
  7.    input                         i_Start,
  8.    //
  9.    output [DECIMAL_DIGITS*4-1:0] o_BCD,
  10.    output                        o_DV
  11.    );
  12.
  13.   parameter s_IDLE              = 3'b000;
  14.   parameter s_SHIFT             = 3'b001;
  15.   parameter s_CHECK_SHIFT_INDEX = 3'b010;
  16.   parameter s_ADD               = 3'b011;
  17.   parameter s_CHECK_DIGIT_INDEX = 3'b100;
  18.   parameter s_BCD_DONE          = 3'b101;
  19.
  20.   reg [2:0] r_SM_Main = s_IDLE;
  21.
  22.   // The vector that contains the output BCD
  23.   reg [DECIMAL_DIGITS*4-1:0] r_BCD = 0;
  24.
  25.   // The vector that contains the input binary value being shifted.
  26.   reg [INPUT_WIDTH-1:0]      r_Binary = 0;
  27.
  28.   // Keeps track of which Decimal Digit we are indexing
  29.   reg [DECIMAL_DIGITS-1:0]   r_Digit_Index = 0;
  30.
  31.   // Keeps track of which loop iteration we are on.
  32.   // Number of loops peRFormed = INPUT_WIDTH
  33.   reg [7:0]                  r_Loop_Count = 0;
  34.   wire [3:0]                 w_BCD_Digit;
  35.   reg                        r_DV = 1'b0;
  36.
  37.   always @(posedge i_Clock)
  38.     begin
  39.       case (r_SM_Main)
  40.
  41.         // Stay in this state until i_Start comes along
  42.         s_IDLE :
  43.           begin
  44.             r_DV <= 1'b0;
  45.
  46.             if (i_Start == 1'b1)
  47.               begin
  48.                 r_Binary  <= i_Binary;
  49.                 r_SM_Main <= s_SHIFT;
  50.                 r_BCD     <= 0;
  51.               end
  52.             else
  53.               r_SM_Main <= s_IDLE;
  54.           end
  55.
  56.
  57.         // Always shift the BCD Vector until we have shifted all bits through
  58.         // Shift the most significant bit of r_Binary into r_BCD lowest bit.
  59.         s_SHIFT :
  60.           begin
  61.             r_BCD     <= r_BCD << 1;
  62.             r_BCD[0]  <= r_Binary[INPUT_WIDTH-1];
  63.             r_Binary  <= r_Binary << 1;
  64.             r_SM_Main <= s_CHECK_SHIFT_INDEX;
  65.           end
  66.
  67.
  68.         // Check if we are done with shifting in r_Binary vector
  69.         s_CHECK_SHIFT_INDEX :
  70.           begin
  71.             if (r_Loop_Count == INPUT_WIDTH-1)
  72.               begin
  73.                 r_Loop_Count <= 0;
  74.                 r_SM_Main    <= s_BCD_DONE;
  75.               end
  76.             else
  77.               begin
  78.                 r_Loop_Count <= r_Loop_Count + 1;
  79.                 r_SM_Main    <= s_ADD;
  80.               end
  81.           end
  82.
  83.
  84.         // Break down each BCD Digit individually.  Check them one-by-one to
  85.         // see if they are greater than 4.  If they are, increment by 3.
  86.         // Put the result back into r_BCD Vector.
  87.         s_ADD :
  88.           begin
  89.             if (w_BCD_Digit > 4)
  90.               begin
  91.                 r_BCD[(r_Digit_Index*4)+:4] <= w_BCD_Digit + 3;
  92.               end
  93.
  94.             r_SM_Main <= s_CHECK_DIGIT_INDEX;
  95.           end
  96.
  97.
  98.         // Check if we are done incrementing all of the BCD Digits
  99.         s_CHECK_DIGIT_INDEX :
  100.           begin
  101.             if (r_Digit_Index == DECIMAL_DIGITS-1)
  102.               begin
  103.                 r_Digit_Index <= 0;
  104.                 r_SM_Main     <= s_SHIFT;
  105.               end
  106.             else
  107.               begin
  108.                 r_Digit_Index <= r_Digit_Index + 1;
  109.                 r_SM_Main     <= s_ADD;
  110.               end
  111.           end
  112.
  113.
  114.
  115.         s_BCD_DONE :
  116.           begin
  117.             r_DV      <= 1'b1;
  118.             r_SM_Main <= s_IDLE;
  119.           end
  120.
  121.
  122.         default :
  123.           r_SM_Main <= s_IDLE;
  124.
  125.       endcase
  126.     end // always @ (posedge i_Clock)
  127.
  128.   assign w_BCD_Digit = r_BCD[r_Digit_Index*4 +: 4];
  129.
  130.   assign o_BCD = r_BCD;
  131.   assign o_DV  = r_DV;
  132.
  133. endmodule // Binary_to_BCD
复制代码VHDL代码:
  1. library ieee;
  2. use ieee.std_logic_1164.all;
  3. use ieee.numeric_std.all;
  4. entity Binary_to_BCD is
  5.   generic (
  6.     g_INPUT_WIDTH    : in positive;
  7.     g_DECIMAL_DIGITS : in positive
  8.     );
  9.   port (
  10.     i_Clock  : in std_logic;
  11.     i_Start  : in std_logic;
  12.     i_Binary : in std_logic_vector(g_INPUT_WIDTH-1 downto 0);
  13.
  14.     o_BCD : out std_logic_vector(g_DECIMAL_DIGITS*4-1 downto 0);
  15.     o_DV  : out std_logic
  16.     );
  17. end entity Binary_to_BCD;
  18. architecture rtl of Binary_to_BCD is
  19.   type t_BCD_State is (s_IDLE, s_SHIFT, s_CHECK_SHIFT_INDEX, s_ADD,
  20.                        s_CHECK_DIGIT_INDEX, s_BCD_DONE);
  21.   signal r_SM_Main : t_BCD_State := s_IDLE;
  22.   -- The vector that contains the output BCD
  23.   signal r_BCD : std_logic_vector(g_DECIMAL_DIGITS*4-1 downto 0) := (others => '0');
  24.   -- The vector that contains the input binary value being shifted.
  25.   signal r_Binary : std_logic_vector(g_INPUT_WIDTH-1 downto 0) := (others => '0');
  26.
  27.   -- Keeps track of which Decimal Digit we are indexing
  28.   signal r_Digit_Index : natural range 0 to g_DECIMAL_DIGITS-1 := 0;
  29.   -- Keeps track of which loop iteration we are on.
  30.   -- Number of loops performed = g_INPUT_WIDTH
  31.   signal r_Loop_Count : natural range 0 to g_INPUT_WIDTH-1  := 0;
  32.
  33. begin
  34.   Double_Dabble : process (i_Clock)
  35.     variable v_Upper     : natural;
  36.     variable v_Lower     : natural;
  37.     variable v_BCD_Digit : unsigned(3 downto 0);
  38.   begin
  39.     if rising_edge(i_Clock) then
  40.       case r_SM_Main is
  41.         -- Stay in this state until i_Start comes along
  42.         when s_IDLE =>
  43.           if i_Start = '1' then
  44.             r_BCD     <= (others => '0');
  45.             r_Binary  <= i_Binary;
  46.             r_SM_Main <= s_SHIFT;
  47.           else
  48.             r_SM_Main <= s_IDLE;
  49.           end if;
  50.         -- Always shift the BCD Vector until we have shifted all bits through
  51.         -- Shift the most significant bit of r_Binary into r_BCD lowest bit.
  52.         when s_SHIFT =>
  53.           r_BCD     <= r_BCD(r_BCD'left-1 downto 0) & r_Binary(r_Binary'left);
  54.           r_Binary  <= r_Binary(r_Binary'left-1 downto 0) & '0';
  55.           r_SM_Main <= s_CHECK_SHIFT_INDEX;
  56.         -- Check if we are done with shifting in r_Binary vector
  57.         when s_CHECK_SHIFT_INDEX =>
  58.           if r_Loop_Count = g_INPUT_WIDTH-1 then
  59.             r_Loop_Count <= 0;
  60.             r_SM_Main    <= s_BCD_DONE;
  61.           else
  62.             r_Loop_Count <= r_Loop_Count + 1;
  63.             r_SM_Main    <= s_ADD;
  64.           end if;
